[1/6]add ar8031 or ar 8035 phy support
Wed Jul 13 14:41:43 UTC 2016
I think this should be the checked-out version of specific freebsd,
with the populated $FreeBSD$ tag? See what other files are using.
On Tue, Jul 5, 2016 at 3:14 AM, yao0718 <29171383 at qq.com> wrote:
> diff -ruN ./rtems-libbsd/freebsd/sys/dev/mii/atphy.c
> ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphy.c
> --- ./rtems-libbsd/freebsd/sys/dev/mii/atphy.c 1970-01-01 08:00:00.000000000
> +0800
> +++ ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphy.c 2016-07-05
> 10:57:44.540734400 +0800
> @@ -0,0 +1,378 @@
> +#include <machine/rtems-bsd-kernel-space.h>
> + * Copyright (c) 2008, Pyun YongHyeon <yongari at FreeBSD.org>
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice unmodified, this list of conditions, and the following
> + *    disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
> WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#include <sys/cdefs.h>
> +__FBSDID("$FreeBSD$");
> + * Driver for the Attansic/Atheros F1 10/100/1000 PHY.
> +#include <sys/param.h>
> +#include <sys/systm.h>
> +#include <sys/kernel.h>
> +#include <sys/module.h>
> +#include <sys/socket.h>
> +#include <sys/bus.h>
> +#include <net/if.h>
> +#include <net/if_media.h>
> +#include <dev/mii/mii.h>
> +#include <dev/mii/miivar.h>
> +#include <rtems/bsd/local/miidevs.h>
> +#include <dev/mii/atphyreg.h>
> +#include <rtems/bsd/local/miibus_if.h>
> +static int atphy_probe(device_t);
> +static int atphy_attach(device_t);
> +static device_method_t atphy_methods[] = {
> + /* Device interface. */
> + DEVMETHOD(device_probe, atphy_probe),
> + DEVMETHOD(device_attach, atphy_attach),
> + DEVMETHOD(device_detach, mii_phy_detach),
> + DEVMETHOD(device_shutdown, bus_generic_shutdown),
> + DEVMETHOD_END
> +static devclass_t atphy_devclass;
> +static driver_t atphy_driver = {
> + "atphy",
> + atphy_methods,
> + sizeof(struct mii_softc)
> +DRIVER_MODULE(atphy, miibus, atphy_driver, atphy_devclass, 0, 0);
> +static int atphy_service(struct mii_softc *, struct mii_data *, int);
> +static void atphy_status(struct mii_softc *);
> +static void atphy_reset(struct mii_softc *);
> +static uint16_t atphy_anar(struct ifmedia_entry *);
> +static int atphy_setmedia(struct mii_softc *, int);
> +static const struct mii_phydesc atphys[] = {
> + MII_PHY_DESC(xxATHEROS, F1),
> + MII_PHY_DESC(xxATHEROS, F1_7),
> + MII_PHY_DESC(xxATHEROS, AR8021),
> +/* MII_PHY_DESC(xxATHEROS, AR8035),*/
> + MII_PHY_DESC(xxATHEROS, F2),
> + MII_PHY_END
> +static const struct mii_phy_funcs atphy_funcs = {
> + atphy_service,
> + atphy_status,
> + atphy_reset
> +static int
> +atphy_probe(device_t dev)
> + return (mii_phy_dev_probe(dev, atphys, BUS_PROBE_DEFAULT));
> +static int
> +atphy_attach(device_t dev)
> + mii_phy_dev_attach(dev, MIIF_NOMANPAUSE, &atphy_funcs, 1);
> + return (0);
> +static int
> +atphy_service(struct mii_softc *sc, struct mii_data *mii, int cmd)
> + struct ifmedia_entry *ife = mii->mii_media.ifm_cur;
> + uint16_t anar, bmcr, bmsr;
> + switch (cmd) {
> + case MII_POLLSTAT:
> + break;
> + case MII_MEDIACHG:
> + if (IFM_SUBTYPE(ife->ifm_media) == IFM_AUTO ||
> +    IFM_SUBTYPE(ife->ifm_media) == IFM_1000_T) {
> + atphy_setmedia(sc, ife->ifm_media);
> + break;
> + bmcr = 0;
> + switch (IFM_SUBTYPE(ife->ifm_media)) {
> + case IFM_100_TX:
> + bmcr = BMCR_S100;
> + break;
> + case IFM_10_T:
> + bmcr = BMCR_S10;
> + break;
> + case IFM_NONE:
> + bmcr = PHY_READ(sc, MII_BMCR);
> + * XXX
> + * Due to an unknown reason powering down PHY resulted
> + * in unexpected results such as inaccessibility of
> + * hardware of freshly rebooted system. Disable
> + * powering down PHY until I got more information for
> + * Attansic/Atheros PHY hardwares.
> + PHY_WRITE(sc, MII_BMCR, bmcr | BMCR_ISO);
> + goto done;
> + default:
> + return (EINVAL);
> + anar = atphy_anar(ife);
> + if ((ife->ifm_media & IFM_FDX) != 0) {
> + bmcr |= BMCR_FDX;
> + if ((ife->ifm_media & IFM_FLOW) != 0 ||
> +    (sc->mii_flags & MIIF_FORCEPAUSE) != 0)
> + anar |= ANAR_PAUSE_TOWARDS;
> + if ((sc->mii_extcapabilities & (EXTSR_1000TFDX |
> +    EXTSR_1000THDX)) != 0)
> + PHY_WRITE(sc, MII_100T2CR, 0);
> + PHY_WRITE(sc, MII_ANAR, anar | ANAR_CSMA);
> + * Reset the PHY so all changes take effect.
> + PHY_WRITE(sc, MII_BMCR, bmcr | BMCR_RESET | BMCR_AUTOEN |
> +    BMCR_STARTNEG);
> +done:
> + break;
> + case MII_TICK:
> + * Only used for autonegotiation.
> + if (IFM_SUBTYPE(ife->ifm_media) != IFM_AUTO) {
> + sc->mii_ticks = 0;
> + break;
> + * Check for link.
> + * Read the status register twice; BMSR_LINK is latch-low.
> + bmsr = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
> + if (bmsr & BMSR_LINK) {
> + break;
> + /* Announce link loss right after it happens. */
> + if (sc->mii_ticks++ == 0)
> + break;
> + if (sc->mii_ticks <= sc->mii_anegticks)
> + return (0);
> + break;
> + /* Update the media status. */
> + PHY_STATUS(sc);
> + /* Callback if something changed. */
> + mii_phy_update(sc, cmd);
> + return (0);
> +static void
> +atphy_status(struct mii_softc *sc)
> + struct mii_data *mii = sc->mii_pdata;
> + uint32_t bmsr, bmcr, ssr;
> + mii->mii_media_status = IFM_AVALID;
> + mii->mii_media_active = IFM_ETHER;
> + if ((bmsr & BMSR_LINK) != 0)
> + mii->mii_media_status |= IFM_ACTIVE;
> + if ((bmcr & BMCR_ISO) != 0) {
> + mii->mii_media_active |= IFM_NONE;
> + mii->mii_media_status = 0;
> + return;
> + if ((bmcr & BMCR_LOOP) != 0)
> + mii->mii_media_active |= IFM_LOOP;
> + ssr = PHY_READ(sc, ATPHY_SSR);
> + if ((ssr & ATPHY_SSR_SPD_DPLX_RESOLVED) == 0) {
> + /* Erg, still trying, I guess... */
> + return;
> + switch (ssr & ATPHY_SSR_SPEED_MASK) {
> + case ATPHY_SSR_1000MBS:
> + mii->mii_media_active |= IFM_1000_T;
> + * atphy(4) has a valid link so reset mii_ticks.
> + * Resetting mii_ticks is needed in order to
> + * detect link loss after auto-negotiation.
> + break;
> + case ATPHY_SSR_100MBS:
> + mii->mii_media_active |= IFM_100_TX;
> + break;
> + case ATPHY_SSR_10MBS:
> + mii->mii_media_active |= IFM_10_T;
> + break;
> + default:
> + return;
> + if ((ssr & ATPHY_SSR_DUPLEX) != 0)
> + mii->mii_media_active |= IFM_FDX | mii_phy_flowstatus(sc);
> + else
> + mii->mii_media_active |= IFM_HDX;
> + if ((IFM_SUBTYPE(mii->mii_media_active) == IFM_1000_T) &&
> +    (PHY_READ(sc, MII_100T2SR) & GTSR_MS_RES) != 0)
> + mii->mii_media_active |= IFM_ETH_MASTER;
> +static void
> +atphy_reset(struct mii_softc *sc)
> + struct ifmedia_entry *ife = sc->mii_pdata->mii_media.ifm_cur;
> + uint32_t reg;
> + int i;
> + //enable rgmii internal delay
> + PHY_WRITE(sc, 0xd, 0x3);
> + PHY_WRITE(sc, 0xe, 0x805d);
> + PHY_WRITE(sc, 0xd, 0x4003);
> + reg = PHY_READ(sc, 0xe);
> + PHY_WRITE(sc, 0xe, reg & ~(1 << 8));
> + PHY_WRITE(sc, 0x1d,5);
> + PHY_WRITE(sc, 0x1e, (1<<8));
> +#if 1
> + reg = PHY_READ(sc, ATPHY_SCR);
> + /* Enable automatic crossover. */
> + reg |= ATPHY_SCR_AUTO_X_MODE;
> + /* Disable power down. */
> + reg &= ~ATPHY_SCR_MAC_PDOWN;
> + /* Enable CRS on Tx. */
> + reg |= ATPHY_SCR_ASSERT_CRS_ON_TX;
> + /* Auto correction for reversed cable polarity. */
> + reg |= ATPHY_SCR_POLARITY_REVERSAL;
> + PHY_WRITE(sc, ATPHY_SCR, reg);
> + /* Workaround F1 bug to reset phy. */
> + atphy_setmedia(sc, ife == NULL ? IFM_AUTO : ife->ifm_media);
> + for (i = 0; i < 1000; i++) {
> + DELAY(1);
> + if ((PHY_READ(sc, MII_BMCR) & BMCR_RESET) == 0)
> + break;
> +#endif
> +static uint16_t
> +atphy_anar(struct ifmedia_entry *ife)
> + uint16_t anar;
> + anar = 0;
> + case IFM_AUTO:
> + anar |= ANAR_TX_FD | ANAR_TX | ANAR_10_FD | ANAR_10;
> + return (anar);
> + case IFM_1000_T:
> + return (anar);
> + case IFM_100_TX:
> + anar |= ANAR_TX;
> + break;
> + case IFM_10_T:
> + anar |= ANAR_10;
> + break;
> + default:
> + return (0);
> + if (IFM_SUBTYPE(ife->ifm_media) == IFM_100_TX)
> + anar |= ANAR_TX_FD;
> + else
> + anar |= ANAR_10_FD;
> + return (anar);
> +static int
> +atphy_setmedia(struct mii_softc *sc, int media)
> + uint16_t anar;
> + anar = BMSR_MEDIA_TO_ANAR(sc->mii_capabilities) | ANAR_CSMA;
> + if ((IFM_SUBTYPE(media) == IFM_AUTO || (media & IFM_FDX) != 0) &&
> +    ((media & IFM_FLOW) != 0 ||
> +    (sc->mii_flags & MIIF_FORCEPAUSE) != 0))
> + PHY_WRITE(sc, MII_ANAR, anar);
> +     (EXTSR_1000TFDX | EXTSR_1000THDX)) != 0)
> + PHY_WRITE(sc, MII_100T2CR, GTCR_ADV_1000TFDX |
> +    GTCR_ADV_1000THDX);
> + else if (sc->mii_mpd_model == MII_MODEL_xxATHEROS_F1) {
> + * AR8132 has 10/100 PHY and the PHY uses the same
> + * model number of F1 gigabit PHY.  The PHY has no
> + * ability to establish gigabit link so explicitly
> + * disable 1000baseT configuration for the PHY.
> + * Otherwise, there is a case that atphy(4) could
> + * not establish a link against gigabit link partner
> + * unless the link partner supports down-shifting.
> + PHY_WRITE(sc, MII_BMCR, BMCR_RESET | BMCR_AUTOEN | BMCR_STARTNEG);
> + return (EJUSTRETURN);
> diff -ruN ./rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h
> ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h
> --- ./rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h 1970-01-01
> 08:00:00.000000000 +0800
> +++ ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h 2016-03-08
> 14:27:47.000000000 +0800
> @@ -0,0 +1,63 @@
> + * are met:
> + *    disclaimer.
> PURPOSE
> CONSEQUENTIAL
> STRICT
> WAY
> + * SUCH DAMAGE.
> + * $FreeBSD$
> +#ifndef _DEV_MII_ATPHYREG_H_
> +#define _DEV_MII_ATPHYREG_H_
> + * Registers for the Attansic/Atheros Gigabit PHY.
> +/* Special Control Register */
> +#define ATPHY_SCR 0x10
> +#define ATPHY_SCR_JABBER_DISABLE 0x0001
> +#define ATPHY_SCR_POLARITY_REVERSAL 0x0002
> +#define ATPHY_SCR_SQE_TEST 0x0004
> +#define ATPHY_SCR_MAC_PDOWN 0x0008
> +#define ATPHY_SCR_CLK125_DISABLE 0x0010
> +#define ATPHY_SCR_MDI_MANUAL_MODE 0x0000
> +#define ATPHY_SCR_MDIX_MANUAL_MODE 0x0020
> +#define ATPHY_SCR_AUTO_X_1000T 0x0040
> +#define ATPHY_SCR_AUTO_X_MODE 0x0060
> +#define ATPHY_SCR_10BT_EXT_ENABLE 0x0080
> +#define ATPHY_SCR_MII_5BIT_ENABLE 0x0100
> +#define ATPHY_SCR_SCRAMBLER_DISABLE 0x0200
> +#define ATPHY_SCR_FORCE_LINK_GOOD 0x0400
> +#define ATPHY_SCR_ASSERT_CRS_ON_TX 0x0800
> +/* Special Status Register. */
> +#define ATPHY_SSR 0x11
> +#define ATPHY_SSR_SPD_DPLX_RESOLVED 0x0800
> +#define ATPHY_SSR_DUPLEX 0x2000
> +#define ATPHY_SSR_SPEED_MASK 0xC000
> +#define ATPHY_SSR_10MBS 0x0000
> +#define ATPHY_SSR_100MBS 0x4000
> +#define ATPHY_SSR_1000MBS 0x8000
> +#endif /* _DEV_MII_ATPHYREG_H_ */
> ------------------ Original ------------------
> From:  "yao0718";<29171383 at qq.com>;
> Date:  Tue, Jul 5, 2016 03:11 PM
> To:  "devel"<devel at rtems.org>;
> Subject:  [0/6] ti cpsw driver port from freebsd for am335x
> I add cpsw driver from freebsd and modify some code for my board, my board
> is not beagleblack, so i am not sure it can work fine in BB board,to reduce
> phy find process, I  set phy address 4 and 6 for which phy address on my
> board,my board has two eth port ,I set dualmac when attach;
> can somebody test it on beaglebone and merge to beaglebone  bsp?
> devel mailing list
> devel at rtems.org
