[1/6]add ar8031 or ar 8035 phy support
Thu Jul 14 05:46:24 UTC 2016
If we import more and more files from various FreeBSD versions, then we
make it harder and harder to update everything to a newer FreeBSD
release. This may end up in a situation where we are practically stuck
at FreeBSD 9.
Imports which are not from the freebsd-org submodule must at least
clearly state the import version in the commit message.
On 14/07/16 07:38, yao0718 wrote:
> I am not use the freebsd-orgsubmodule commit, I clone the master
> freebsd form github and manual port form the master of freebsd
> ------------------ Original ------------------
> *From: * "Sebastian Huber";<sebastian.huber at embedded-brains.de>;
> *Date: * Thu, Jul 14, 2016 01:35 PM
> *To: * "Gedare Bloom"<gedare at rtems.org>; "yao0718"<29171383 at qq.com>;
> *Cc: * "devel"<devel at rtems.org>;
> *Subject: * Re: [1/6]add ar8031 or ar 8035 phy support
> On 13/07/16 16:41, Gedare Bloom wrote:
> > I think this should be the checked-out version of specific freebsd,
> > with the populated $FreeBSD$ tag? See what other files are using.
> In the libbsd the FreeBSD version is determined by the Git freebsd-org
> submodule commit.
> Is the Git freebsd-org submodule the origin of this file?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
