[PATCH] beagle: pwm polishing
Ben Gras
beng at shrike-systems.com
Sun Jul 17 13:59:36 UTC 2016
. added a README to pwm
. added select_pwmss() to select pwmss-generic registers, as opposed
to PWM-specific registers
. added pwmss_clock_en_status() and pwmss_tb_clock_check()
. other API improvements
. style improvements
c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h | 113 ++++--
c/src/lib/libbsp/arm/beagle/preinstall.am | 4 +
c/src/lib/libbsp/arm/beagle/pwm/README | 197 +++++++++
c/src/lib/libbsp/arm/beagle/pwm/pwm.c | 563 ++++++++++++++------------
4 files changed, 568 insertions(+), 309 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/beagle/pwm/README
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
index ef016f0..cf5d6fe 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h
@@ -3,11 +3,11 @@
* @ingroup arm_beagle
- * @brief BeagleBone Black BSP definitions.
+ * @brief BeagleBone Black PWM support definitions.
- * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
+ * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -31,43 +31,53 @@ extern "C" {
#define BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4))
#define BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4))
-#define BBB_PWMSS_COUNT 3
-#define BBB_PWMSS0 0
-#define BBB_PWMSS1 1
-#define BBB_PWMSS2 2
-#define BBB_P8_13_2B 3
-#define BBB_P8_19_2A 4
-#define BBB_P8_45_2A 5
-#define BBB_P8_46_2B 6
-#define BBB_P8_34_1B 7
-#define BBB_P8_36_1A 8
-#define BBB_P9_14_1A 9
-#define BBB_P9_16_1B 10
-#define BBB_P9_21_0B 11
-#define BBB_P9_22_0A 12
-#define BBB_P9_29_0B 13
-#define BBB_P9_31_0A 14
-#define BBB_MUX0 0
-#define BBB_MUX1 1
-#define BBB_MUX2 2
-#define BBB_MUX3 3
-#define BBB_MUX4 4
-#define BBB_MUX5 5
-#define BBB_MUX6 6
-#define BBB_MUX7 7
-#define BBB_EPWM1 1
-#define BBB_EPWM2 2
-#define BBB_EPWM0 0
+ * @brief The set of possible PWM subsystem module
+ * Enumerated type to define various instance of pwm module.
+typedef enum{
+ BBB_PWMSS0 = 0,
+ BBB_PWMSS1,
+ BBB_PWMSS2,
+ BBB_PWMSS_COUNT
+}BBB_PWMSS;
+typedef enum{
+ BBB_P8_13_2B = 3,
+ BBB_P8_19_2A,
+ BBB_P8_45_2A,
+ BBB_P8_46_2B,
+ BBB_P8_34_1B,
+ BBB_P8_36_1A,
+ BBB_P9_14_1A,
+ BBB_P9_16_1B,
+ BBB_P9_21_0B,
+ BBB_P9_22_0A,
+ BBB_P9_29_0B,
+ BBB_P9_31_0A
+}bbb_pwm_pin_t;
+#define BBB_P8_13_MUX_PWM 4
+#define BBB_P8_19_MUX_PWM 4
+#define BBB_P8_45_MUX_PWM 3
+#define BBB_P8_46_MUX_PWM 3
+#define BBB_P8_34_MUX_PWM 2
+#define BBB_P8_36_MUX_PWM 2
+#define BBB_P9_14_MUX_PWM 6
+#define BBB_P9_16_MUX_PWM 6
+#define BBB_P9_21_MUX_PWM 3
+#define BBB_P9_22_MUX_PWM 3
+#define BBB_P9_29_MUX_PWM 1
+#define BBB_P9_31_MUX_PWM 1
+#define BBB_PWM_FREQ_THRESHOLD 0.5f
* @brief BeagleBone Black PWM API.
- * @brief This function intilize clock and pinmuxing for pwm sub system.
+ * @brief This function intilizes clock for pwm sub system.
* @param PWMSS_ID It is the instance number of EPWM of pwm sub system.
@@ -75,20 +85,20 @@ extern "C" {
* @return false if not successful
-bool beagle_pwm_init(uint32_t pwmss_id);
+bool beagle_pwm_init(BBB_PWMSS pwmss_id);
/* PWMSS setting
* set pulse argument of epwm module
* @param pwm_id : EPWMSS number , 0~2
* @param pwm_freq : frequency to be generated
- * @param dutyA : Duty Cycle in ePWM A
- * @param dutyB : Duty Cycle in ePWM B
+ * @param dutyA : Duty Cycle(in percentage) in PWM channel A
+ * @param dutyB : Duty Cycle(in percentage) in PWM channel B
* @return : 1 for success
* @return : 0 for failed
- * @example : PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f); // Generate 50HZ pwm in PWM0 ,
+ * @example : beagle_pwm_configure(0 , 50.0f , 50.0f , 25.0f); // Generate 50HZ pwm in PWM0 ,
* // duty cycle is 50% for ePWM0A , 25% for ePWM0B
* @Note :
@@ -105,12 +115,12 @@ bool beagle_pwm_init(uint32_t pwmss_id);
* Divisor = CLKDIV * HSPCLKDIV
* 1 TBPRD : 10 ns (default)
* 65535 TBPRD : 655350 ns
- * 65535 TBPRD : 655350 * Divisor ns = X TBPRD : Cyclens
+ * 65535 TBPRD : 655350 * Divisor ns = X TBPRD : Cycle
* accrooding to that , we must find a Divisor value , let X nearest 65535 .
- * so , Divisor must Nearest Cyclens/655350
+ * so , Divisor must Nearest Cycle/655350
-int beagle_pwmss_setting(uint32_t pwm_id, float pwm_freq, float dutyA, float dutyB);
+int beagle_pwm_configure(BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b);
* @brief This API enables the particular PWM module.
@@ -121,10 +131,10 @@ int beagle_pwmss_setting(uint32_t pwm_id, float pwm_freq, float dutyA, float dut
* @return false if fail
-bool beagle_ehrpwm_enable(uint32_t pwmid);
+bool beagle_pwm_enable(BBB_PWMSS pwmid);
- * @brief This API disables the HR sub-module.
+ * @brief This API disables the particular PWM module.
* @param pwmid It is the instance number of EPWM of pwm sub system.
@@ -132,10 +142,10 @@ bool beagle_ehrpwm_enable(uint32_t pwmid);
-bool beagle_ehrpwm_disable(uint32_t pwmid);
+bool beagle_pwm_disable(BBB_PWMSS pwmid);
- * @brief This function Enables pinmuxing for PWM module.
+ * @brief This function enables pinmuxing for PWM module.
* @param pin_no It is individual pin at which freuqency need to be generated.
* It should be according to pwm sub system.
@@ -146,7 +156,20 @@ bool beagle_ehrpwm_disable(uint32_t pwmid);
-bool beagle_epwm_pinmux_setup(uint32_t pin_no, uint32_t pwm_id);
+bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id);
+ * @brief This function determines whether PWMSS-wide clocks enabled or not.
+ * @param pwmss_id It is the instance number of PWMSS which clocks need to be
+ * checked.
+ * @return true if successful
+ * @return false if fail
+bool beagle_pwmss_is_running(unsigned int pwmss_id);
#ifdef __cplusplus
diff --git a/c/src/lib/libbsp/arm/beagle/preinstall.am b/c/src/lib/libbsp/arm/beagle/preinstall.am
index 3701a2b..8a7ff8b 100644
--- a/c/src/lib/libbsp/arm/beagle/preinstall.am
+++ b/c/src/lib/libbsp/arm/beagle/preinstall.am
@@ -118,6 +118,10 @@ $(PROJECT_INCLUDE)/bsp/bbb-gpio.h: include/bbb-gpio.h $(PROJECT_INCLUDE)/bsp/$(d
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bbb-gpio.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bbb-gpio.h
+$(PROJECT_INCLUDE)/bsp/bbb-pwm.h: include/bbb-pwm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bbb-pwm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bbb-pwm.h
$(PROJECT_INCLUDE)/libcpu/arm-cp15.h: ../../../libcpu/arm/shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
diff --git a/c/src/lib/libbsp/arm/beagle/pwm/README b/c/src/lib/libbsp/arm/beagle/pwm/README
new file mode 100644
index 0000000..d41f5ca
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/pwm/README
@@ -0,0 +1,197 @@
+Pulse Width Modulation subsystem includes EPWM, ECAP , EQEP. There are
+different instances available for each one. For PWM there are three
+different individual EPWM module 0 , 1 and 2. So wherever pwmss word is
+used that affects whole PWM sub system such as EPWM, ECAP and EQEP. This code
+has only implementation Non high resolution PWM module. APIs for high
+resolution PWM has been yet to develop.
+For Each EPWM instance, has two PWM channels, e.g. EPWM0 has two channel
+EPWM0A and EPWM0B. If you configure two PWM outputs(e.g. EPWM0A , EPWM0B)
+in the same device, then they *must* be configured with the same frequency.
+Changing frequency on one channel (e.g EPWMxA) will automatically change
+frequency on another channel(e.g. EPWMxB). However, it is possible to set
+different pulse-width/duty cycle to different channel at a time. So always
+set the frequency first and then pulse-width/duty cycle.
+For more you can refer :
+http://www.ofitselfso.com/BBBCSIO/Source/PWMPortEnum.cs.html
+Pulse Width Modulation uses the system frequency of Beagle Bone Black.
+System frequency = SYSCLKOUT, that is, CPU clock. TBCLK = SYSCLKOUT(By Default)
+SYCLKOUT = 100 MHz
+Please visit following link to check why SYSCLKDIV = 100MHz:
+https://groups.google.com/forum/#!topic/beagleboard/Ed2J9Txe_E4
+(Refer Technical Reference Manual (TRM) Table 15-41 as well)
+To generate different frequencies with the help of PWM module , SYSCLKOUT
+need to be scaled down, which will act as TBCLK and TBCLK will be base clock
+for the pwm subsystem.
+TBCLK = SYSCLKOUT/(HSPCLKDIV * CLKDIV)
+ | clock |
+ SYSCLKOUT---> | |---> TBCLK
+ | prescale |
+ TBCTL[CLKDIV]----- ------TBCTL[HSPCLKDIV]
+CLKDIV and HSPCLKDIV bits are part of the TBCTL register (Refer TRM).
+CLKDIV - These bits determine part of the time-base clock prescale value.
+Please use the following values of CLKDIV to scale down sysclk respectively.
+0h (R/W) = /1
+1h (R/W) = /2
+2h (R/W) = /4
+3h (R/W) = /8
+4h (R/W) = /16
+5h (R/W) = /32
+6h (R/W) = /64
+7h (R/W) = /128
+These bits determine part of the time-base clock prescale value.
+Please use following value of HSPCLKDIV to scale down sysclk respectively
+0h (R/W) = /1
+1h (R/W) = /2
+2h (R/W) = /4
+3h (R/W) = /6
+4h (R/W) = /8
+5h (R/W) = /10
+6h (R/W) = /12
+7h (R/W) = /14
+For example, if you set CLKDIV = 3h and HSPCLKDIV= 2h Then
+SYSCLKOUT will be divided by (1/8)(1/4). It means SYSCLKOUT/32
+How to generate frequency ?
+freq = 1/Period
+TBPRD register is responsible to generate the frequency. These bits determine
+the period of the time-base counter.
+By default TBCLK = SYSCLKOUT = 100 MHz
+Here by default period is 1/100MHz = 10 nsec
+Following example shows value to be loaded into TBPRD
+e.g. TBPRD = 1 = 1 count
+ count x Period = 1 x 1ns = 1ns
+ freq = 1/Period = 1 / 1ns = 100 MHz
+For duty cycle CMPA and CMPB are the responsible registers.
+To generate single with 50% Duty cycle & 100MHz freq.
+ CMPA = count x Duty Cycle
+ = TBPRD x Duty Cycle
+ = 1 x 50/100
+ = 0.2
+The value in the active CMPA register is continuously compared to
+the time-base counter (TBCNT). When the values are equal, the
+counter-compare module generates a "time-base counter equal to
+counter compare A" event. This event is sent to the action-qualifier
+where it is qualified and converted it into one or more actions.
+These actions can be applied to either the EPWMxA or the
+EPWMxB output depending on the configuration of the AQCTLA and
+AQCTLB registers.
+List of pins for that can be used for different PWM instance :
+ | EPWM2 | EPWM1 | EPWM0 |
+ | BBB_P8_13_2B | BBB_P8_34_1B | BBB_P9_21_0B |
+ | BBB_P8_19_2A | BBB_P8_36_1A | BBB_P9_22_0A |
+ | BBB_P8_45_2A | BBB_P9_14_1A | BBB_P9_29_0B |
+ | BBB_P8_46_2B | BBB_P9_16_1B | BBB_P9_31_0A |
+BBB_P8_13_2B represents P8 Header , pin number 13 , 2nd PWM instance and B channel.
+Following sample program can be used to generate 7 Hz frequency.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <bsp.h>
+#include <bsp/gpio.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <bsp/bbb-pwm.h>
+const char rtems_test_name[] = "Testing PWM driver";
+rtems_printer rtems_test_printer;
+static void inline delay_sec(int sec)
+ rtems_task_wake_after(sec*rtems_clock_get_ticks_per_second());
+rtems_task Init(rtems_task_argument argument);
+rtems_task Init(
+ rtems_task_argument ignored
+ rtems_test_begin();
+ printf("Starting PWM Testing");
+ /*Initialize GPIO pins in BBB*/
+ rtems_gpio_initialize();
+ /* Set P9 Header , 21 Pin number , PWM B channel and 0 PWM instance to generate frequency*/
+ beagle_epwm_pinmux_setup(BBB_P9_21_0B,BBB_PWMSS0);
+/** Initialize clock for PWM sub system
+ * Turn on time base clock for PWM o instance
+ beagle_pwm_init(BBB_PWMSS0);
+ float PWM_HZ = 7.0f ; /* 7 Hz */
+ float duty_A = 20.0f ; /* 20% Duty cycle for PWM 0_A output */
+ const float duty_B = 50.0f ; /* 50% Duty cycle for PWM 0_B output*/
+ /*Note: Always check whether pwmss clocks are enabled or not before configuring PWM*/
+ bool is_running = beagle_pwmss_is_running(BBB_PWMSS2);
+ if(is_running) {
+ /*To analyse the two different duty cycle Output should be observed at P8_45 and P8_46 pin number */
+ beagle_pwm_configure(BBB_PWMSS0, PWM_HZ ,duty_A , duty_B);
+ printf("PWM enable for 10s ....\n");
+ /*Set Up counter and enable pwm module */
+ beagle_pwm_enable(BBB_PWMSS0);
+ delay_sec(10);
+ /*freeze the counter and disable pwm module*/
+ beagle_epwm_disable(BBB_PWMSS0);
+/* NOTICE: the clock driver is enabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (2 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/c/src/lib/libbsp/arm/beagle/pwm/pwm.c b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
index 3b9716e..0bc5d12 100644
--- a/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
+++ b/c/src/lib/libbsp/arm/beagle/pwm/pwm.c
@@ -7,7 +7,7 @@
@@ -24,6 +24,7 @@
#include <bsp/bbb-gpio.h>
#include <bsp.h>
+#include <bsp/beagleboneblack.h>
/* Currently these definitions are for BeagleBone Black board only
* Later on Beagle-xM board support can be added in this code.
@@ -32,102 +33,97 @@
#if IS_AM335X
- * @brief This function select PWM module to be enabled
+ * @brief This function selects EPWM module to be enabled
* @param pwm_id It is the instance number of EPWM of pwm sub system.
* @return Base Address of respective pwm instant.
-static uint32_t select_pwmss(uint32_t pwm_id)
+static uint32_t select_pwm(BBB_PWMSS pwm_id)
-uint32_t baseAddr=0;
- if (pwm_id == BBB_PWMSS0)
- baseAddr = AM335X_EPWM_0_REGS;
- return baseAddr;
- else if (pwm_id == BBB_PWMSS1)
- baseAddr = AM335X_EPWM_1_REGS;
- return baseAddr;
- else if (pwm_id == BBB_PWMSS2)
- baseAddr = AM335X_EPWM_2_REGS;
- return baseAddr;
- else
- printf("Invalid PWM Id\n");
- return 0;
+ uint32_t baseAddr=0;
+ if (pwm_id == BBB_PWMSS0) {
+ baseAddr = AM335X_EPWM_0_REGS;
+ } else if (pwm_id == BBB_PWMSS1) {
+ baseAddr = AM335X_EPWM_1_REGS;
+ } else if (pwm_id == BBB_PWMSS2) {
+ baseAddr = AM335X_EPWM_2_REGS;
+ } else {
+ baseAddr = 0;
+ return baseAddr;
+ * @brief This function selects PWM Sub system to be enabled
+ * @param pwmss_id The instance number of ePWMSS whose system clocks
+ * have to be configured.
+ * @return Base Address of respective pwmss instant.
+static uint32_t select_pwmss(BBB_PWMSS pwmss_id)
- switch(pwm_id) {
- case BBB_PWMSS2:
- switch(pin_no) {
- case BBB_P8_13_2B:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(9)) = BBB_MUXMODE(BBB_MUX4);
- break;
- case BBB_P8_19_2A:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(8)) = BBB_MUXMODE(BBB_MUX4);
- break;
- case BBB_P8_45_2A:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(0)) = BBB_MUXMODE(BBB_MUX3);
- break;
- case BBB_P8_46_2B:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(1)) = BBB_MUXMODE(BBB_MUX3);
- break;
- default :
- printf("Invalid pin for module 2\n");
- return false;
- break;
- case BBB_PWMSS1:
- switch(pin_no) {
- case BBB_P8_34_1B:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(11)) = BBB_MUXMODE(BBB_MUX2);
- break;
- case BBB_P8_36_1A:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_MUX2);
- break;
- case BBB_P9_14_1A:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_MUX6);
- break;
- case BBB_P9_16_1B:
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_MUX6);
- break;
- default :
- printf("Invalid pin for module 1\n");
- return false;
- break;
- case BBB_PWMSS0:
- switch(pin_no) {
- case BBB_P9_21_0B:
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = BBB_MUXMODE(BBB_MUX3);
- break;
- case BBB_P9_22_0A:
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = BBB_MUXMODE(BBB_MUX3);
- break;
- case BBB_P9_29_0B:
- REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSX) = BBB_MUXMODE(BBB_MUX1);
- break;
- case BBB_P9_31_0A:
- REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKX) = BBB_MUXMODE(BBB_MUX1);
- break;
- default:
- printf("Invalid pin for module 0\n");
- return false;
- break;
- default:
- printf("Invalid PWM sub system\n");
- return false;
+ if (pwmss_id == BBB_PWMSS0) {
+ baseAddr = AM335X_PWMSS0_MMAP_ADDR;
+ } else if (pwmss_id == BBB_PWMSS1) {
+ baseAddr = AM335X_PWMSS1_MMAP_ADDR;
+ } else if (pwmss_id == BBB_PWMSS2) {
+ baseAddr = AM335X_PWMSS2_MMAP_ADDR;
+ } else {
+ baseAddr = 0;
+ return baseAddr;
+ bool is_valid = true;
+ if(pwm_id == BBB_PWMSS0) {
+ if (pin_no == BBB_P9_21_0B) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = BBB_MUXMODE(BBB_P9_21_MUX_PWM);
+ } else if (pin_no == BBB_P9_22_0A) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = BBB_MUXMODE(BBB_P9_22_MUX_PWM);
+ } else if (pin_no == BBB_P9_29_0B) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSX) = BBB_MUXMODE(BBB_P9_29_MUX_PWM);
+ } else if (pin_no == BBB_P9_31_0A) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKX) = BBB_MUXMODE(BBB_P9_31_MUX_PWM);
+ } else {
+ is_valid = false;
+ if (pin_no == BBB_P8_34_1B) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(11)) = BBB_MUXMODE(BBB_P8_34_MUX_PWM);
+ } else if (pin_no == BBB_P8_36_1A) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_P8_36_MUX_PWM);
+ } else if (pin_no == BBB_P9_14_1A) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
+ } else if (pin_no == BBB_P9_16_1B) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
+ } else {
+ is_valid = false;
+ if (pin_no == BBB_P8_13_2B) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(9)) = BBB_MUXMODE(BBB_P8_13_MUX_PWM);
+ } else if (pin_no == BBB_P8_19_2A) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(8)) = BBB_MUXMODE(BBB_P8_19_MUX_PWM);
+ } else if (pin_no == BBB_P8_45_2A) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(0)) = BBB_MUXMODE(BBB_P8_45_MUX_PWM);
+ } else if (pin_no == BBB_P8_46_2B) {
+ REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(1)) = BBB_MUXMODE(BBB_P8_46_MUX_PWM);
+ } else {
+ is_valid = false;
+ } else {
+ is_valid = false;
+ return is_valid;
@@ -137,32 +133,26 @@ bool beagle_epwm_pinmux_setup(uint32_t pin_no, uint32_t pwm_id)
* @param instance It is the instance number of EPWM of pwmsubsystem.
+ * false if unsuccessful
-static bool pwmss_tbclk_enable(unsigned int instance)
+static bool pwmss_tbclk_enable(BBB_PWMSS instance)
-uint32_t enable_bit;
-bool is_valid = true;
+ uint32_t enable_bit;
- if (instance == BBB_PWMSS0)
- enable_bit = AM335X_PWMSS_CTRL_PWMSS0_TBCLKEN;
- else if (instance == BBB_PWMSS1)
+ if (instance == BBB_PWMSS0) {
+ enable_bit = AM335X_PWMSS_CTRL_PWMSS0_TBCLKEN;
+ } else if (instance == BBB_PWMSS1) {
enable_bit = AM335X_PWMSS_CTRL_PWMSS1_TBCLKEN;
- else if (instance == BBB_PWMSS2)
+ } else if (instance == BBB_PWMSS2) {
enable_bit = AM335X_PWMSS_CTRL_PWMSS2_TBCLKEN;
- else
+ } else {
is_valid = false;
if (is_valid)
- REG(AM335X_PADCONF_BASE + AM335X_PWMSS_CTRL) |= enable_bit;
+ REG(AM335X_PADCONF_BASE + AM335X_PWMSS_CTRL) |= enable_bit;
return is_valid;
@@ -173,18 +163,22 @@ bool is_valid = true;
- * @return None.
-static void epwm_clock_enable(uint32_t pwm_id)
- if((pwm_id <3) && (pwm_id >=0)) {
- uint32_t baseAddr;
- baseAddr = select_pwmss(pwm_id);
- REG(baseAddr - AM335X_EPWM_REGS + AM335X_PWMSS_CLKCONFIG) |= AM335X_PWMSS_CLK_EN_ACK;
- } else {
- printf("Invalid pwm_id\n");
+static bool pwm_clock_enable(BBB_PWMSS pwm_id)
+ const bool id_is_valid = pwm_id < BBB_PWMSS_COUNT;
+ bool status = true;
+ if (id_is_valid) {
+ const uint32_t baseAddr = select_pwmss(pwm_id);
+ REG(baseAddr + AM335X_PWMSS_CLKCONFIG) |= AM335X_PWMSS_CLK_EN_ACK;
+ } else {
+ status = false;
+ return status;
@@ -198,184 +192,230 @@ static void epwm_clock_enable(uint32_t pwm_id)
* 'pwmss_id' can take one of the following values:
* (0 <= pwmss_id <= 2)
- * @return None.
+ * @return True if successful
+ * False if Unsuccessful
-static void module_clk_config(uint32_t pwmss_id)
+static bool pwmss_module_clk_config(BBB_PWMSS pwmss_id)
- if(pwmss_id == 0)
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL) |=
- AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
- while(AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE !=
- (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL) &
- AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE));
- while((AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT) !=
- AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST));
- else if(pwmss_id == 1)
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL) |=
- AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
- while(AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE !=
- (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL) &
- AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE));
+ if(pwmss_id == BBB_PWMSS0) {
+ const uint32_t is_functional = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC <<
+ AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT;
+ const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL;
+ const uint32_t idle_bits = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST;
+ const uint32_t is_enable = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
+ const uint32_t module_mode = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE;
+ REG(clkctrl) |= is_enable;
+ while((REG(clkctrl) & module_mode) != is_enable);
+ while((REG(clkctrl) & idle_bits) != is_functional);
+ else if(pwmss_id == BBB_PWMSS1) {
+ const uint32_t is_functional = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC <<
+ AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT;
+ const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL;
+ const uint32_t idle_bits = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST;
+ const uint32_t is_enable = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
+ const uint32_t module_mode = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE;
- while((AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT) !=
- AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST));
- else if(pwmss_id == 2)
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL) |=
- AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
- while(AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE !=
- (REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL) &
- AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE));
+ } else if(pwmss_id == BBB_PWMSS2) {
+ const uint32_t is_functional = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC <<
+ AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT;
+ const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL;
+ const uint32_t idle_bits = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST;
+ const uint32_t is_enable = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
+ const uint32_t module_mode = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE;
- while((AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT) !=
- AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST));
- else
- printf("Please enter valid pwm Id \n");
+ } else
+ is_valid = false;
+ return is_valid;
+ const bool id_is_valid = pwmss_id < BBB_PWMSS_COUNT;
bool status = true;
- if((pwmss_id <3) && (pwmss_id >=0))
- module_clk_config(pwmss_id);
- epwm_clock_enable(pwmss_id);
- pwmss_tbclk_enable(pwmss_id);
- return status;
+ if(id_is_valid) {
+ pwmss_module_clk_config(pwmss_id);
+ pwm_clock_enable(pwmss_id);
+ pwmss_tbclk_enable(pwmss_id);
+ } else {
+ status =false;
- else {
- status =false;
return status;
uint32_t baseAddr;
int status = 1;
- if(pwm_freq <= 0.5) {
- status =0;
- return status;
- if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB > 100.0f) {
- status = 0;
- return status;
- dutyA /= 100.0f;
- dutyB /= 100.0f;
- /*Compute necessary TBPRD*/
- float Cyclens = 0.0f;
- float Divisor =0;
- int i,j;
+ float cycle = 0.0f,divisor = 0;
+ unsigned int i,j;
const float CLKDIV_div[] = {1.0,2.0,4.0,8.0,16.0,32.0,64.0,128.0};
const float HSPCLKDIV_div[] = {1.0, 2.0, 4.0, 6.0, 8.0, 10.0,12.0, 14.0};
- int NearCLKDIV =7;
- int NearHSPCLKDIV =7;
- int NearTBPRD =0;
+ int NearCLKDIV =7,NearHSPCLKDIV =7,NearTBPRD =0;
+ if (pwm_freq <= BBB_PWM_FREQ_THRESHOLD) {
+ status =0;
+ if (duty_a < 0.0f || duty_a > 100.0f || duty_b < 0.0f || duty_b > 100.0f) {
+ status = 0;
+ duty_a /= 100.0f;
+ duty_b /= 100.0f;
/** 10^9 /Hz compute time per cycle (ns) */
- Cyclens = 1000000000.0f / pwm_freq;
+ cycle = 1000000000.0f / pwm_freq;
/** am335x provide (128* 14) divider and per TBPRD means 10ns when divider
* and max TBPRD is 65535 so max cycle is 128 * 8 * 14 * 65535 * 10ns */
- Divisor = (Cyclens / 655350.0f);
- if(Divisor > (128 * 14)) {
- printf("Can't generate %f HZ",pwm_freq);
- return 0;
+ divisor = (cycle / 655350.0f);
+ if (divisor > (128 * 14)) {
+ return 0;
else {
- for (i=0;i<8;i++) {
- for(j=0 ; j<8; j++) {
- if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV]
- * HSPCLKDIV_div[NearHSPCLKDIV]) && (CLKDIV_div[i] * HSPCLKDIV_div[j] > Divisor)) {
- NearCLKDIV = i;
- NearHSPCLKDIV = j;
+ for (i=0;i<8;i++) {
+ for(j=0 ; j<8; j++) {
+ if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV]
+ * HSPCLKDIV_div[NearHSPCLKDIV]) && (CLKDIV_div[i] * HSPCLKDIV_div[j] > divisor)) {
+ NearCLKDIV = i;
+ NearHSPCLKDIV = j;
+ baseAddr = select_pwm(pwm_id);
REG16(baseAddr + AM335X_EPWM_TBCTL) &= ~(AM335X_TBCTL_CLKDIV_MASK | AM335X_TBCTL_HSPCLKDIV_MASK);
- REG16(baseAddr + AM335X_EPWM_TBCTL) = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
- (~AM335X_EPWM_TBCTL_CLKDIV)) | ((NearCLKDIV
+ const uint16_t clkdiv_clear = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
+ (~AM335X_EPWM_TBCTL_CLKDIV));
+ const uint16_t clkdiv_write = ((NearCLKDIV
<< AM335X_EPWM_TBCTL_CLKDIV_SHIFT) & AM335X_EPWM_TBCTL_CLKDIV);
- (~AM335X_EPWM_TBCTL_HSPCLKDIV)) | ((NearHSPCLKDIV <<
+ REG16(baseAddr + AM335X_EPWM_TBCTL) = clkdiv_clear | clkdiv_write;
+ const uint16_t hspclkdiv_clear = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
+ (~AM335X_EPWM_TBCTL_HSPCLKDIV));
+ const uint16_t hspclkdiv_write = ((NearHSPCLKDIV <<
AM335X_EPWM_TBCTL_HSPCLKDIV_SHIFT) & AM335X_EPWM_TBCTL_HSPCLKDIV);
- NearTBPRD = (Cyclens / (10.0 * CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]));
- (~AM335X_EPWM_PRD_LOAD_SHADOW_MASK)) | (((bool)AM335X_EPWM_SHADOW_WRITE_DISABLE <<
+ REG16(baseAddr + AM335X_EPWM_TBCTL) = hspclkdiv_clear | hspclkdiv_write;
+ NearTBPRD = (cycle / (10.0 * CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]));
+ const uint16_t shadow_mask = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
+ (~AM335X_EPWM_PRD_LOAD_SHADOW_MASK));
+ const uint16_t shadow_disable = (((bool)AM335X_EPWM_SHADOW_WRITE_DISABLE <<
AM335X_EPWM_TBCTL_PRDLD_SHIFT) & AM335X_EPWM_PRD_LOAD_SHADOW_MASK);
- (~AM335X_EPWM_COUNTER_MODE_MASK)) | (((unsigned int)AM335X_EPWM_COUNT_UP <<
+ REG16(baseAddr + AM335X_EPWM_TBCTL) = shadow_mask | shadow_disable;
+ const uint16_t counter_mask = (REG16(baseAddr + AM335X_EPWM_TBCTL) &
+ (~AM335X_EPWM_COUNTER_MODE_MASK));
+ const uint16_t counter_shift = (((unsigned int)AM335X_EPWM_COUNT_UP <<
AM335X_TBCTL_CTRMODE_SHIFT) & AM335X_EPWM_COUNTER_MODE_MASK);
+ REG16(baseAddr + AM335X_EPWM_TBCTL) = counter_mask | counter_shift;
/*setting clock divider and freeze time base*/
- REG16(baseAddr + AM335X_EPWM_CMPB) = (unsigned short)((float)(NearTBPRD) * dutyB);
- REG16(baseAddr + AM335X_EPWM_CMPA) = (unsigned short)((float)(NearTBPRD) * dutyA);
+ REG16(baseAddr + AM335X_EPWM_CMPB) = (unsigned short)((float)(NearTBPRD) * duty_b);
+ REG16(baseAddr + AM335X_EPWM_CMPA) = (unsigned short)((float)(NearTBPRD) * duty_a);
REG16(baseAddr + AM335X_EPWM_TBPRD) = (unsigned short)NearTBPRD;
REG16(baseAddr + AM335X_EPWM_TBCNT) = 0;
return status;
+ const bool id_is_valid = pwmid < BBB_PWMSS_COUNT;
bool status = true;
- if((pwmid<3) && (pwmid >=0)) {
- baseAddr = select_pwmss(pwmid);
- REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XAHIGH | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
- REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLB_ZRO_XBHIGH | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
- REG16(baseAddr + AM335X_EPWM_TBCNT) = 0;
- REG16(baseAddr + AM335X_EPWM_TBCTL) |= AM335X_TBCTL_FREERUN | AM335X_TBCTL_CTRMODE_UP;
- return status;
- else {
- status =false;
- return status;
+ const uint32_t baseAddr = select_pwm(pwmid);
+ /* Initially set EPWMxA o/p high , when increasing counter = CMPA toggle o/p of EPWMxA */
+ REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XAHIGH | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
+ /* Initially set EPWMxB o/p high , when increasing counter = CMPA toggle o/p of EPWMxB */
+ REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLB_ZRO_XBHIGH | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
+ REG16(baseAddr + AM335X_EPWM_TBCNT) = 0;
+ /* Set counter mode : Up-count mode */
+ REG16(baseAddr + AM335X_EPWM_TBCTL) |= AM335X_TBCTL_FREERUN | AM335X_TBCTL_CTRMODE_UP;
+ } else {
+ status =false;
+ return status;
bool status = true;
- REG16(baseAddr + AM335X_EPWM_TBCTL) = AM335X_EPWM_TBCTL_CTRMODE_STOPFREEZE;
- REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XALOW | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
- REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLA_ZRO_XBLOW | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
- return status;
+ REG16(baseAddr + AM335X_EPWM_TBCTL) = AM335X_EPWM_TBCTL_CTRMODE_STOPFREEZE;
+ REG16(baseAddr + AM335X_EPWM_AQCTLA) = AM335X_EPWM_AQCTLA_ZRO_XALOW | (AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE << AM335X_EPWM_AQCTLA_CAU_SHIFT);
+ REG16(baseAddr + AM335X_EPWM_AQCTLB) = AM335X_EPWM_AQCTLA_ZRO_XBLOW | (AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE << AM335X_EPWM_AQCTLB_CBU_SHIFT);
+ } else {
+ status = false;
- else {
- status = false;
- return status;
+ return status;
+ * @brief This functions determines whether time base clock is enabled for EPWMSS
+ * @param pwmss_id The instance number of ePWMSS whose time base clock need to
+ * be checked
+ * @return returns 4 for PWMSS_ID = 2
+ * returns 2 for PWMSS_ID = 1
+ * returns 1 for PWMSS_ID = 0
+static int pwmss_tb_clock_check(unsigned int pwmss_id)
+ unsigned int reg_value;
+ /*control module check*/
+ reg_value = REG(AM335X_CONTROL_MODULE + AM335X_PWMSS_CTRL);
+ return (reg_value & (1 << pwmss_id));
+ * @brief This functions determines whether clock for EPWMSS is enabled or not.
+ * @param It is the Memory address of the PWMSS instance used.
+ * @return
+static unsigned int pwmss_clock_en_status(unsigned int pwmid)
+ unsigned int status;
+ const uint32_t baseAddr = select_pwmss(pwmid);
+ status = REG(baseAddr + AM335X_PWMSS_CLKSTATUS);
+ status = status >> 8 & 0x1;
+ return status;
+ bool status=true;
+ status = pwmss_clock_en_status(pwmss_id);
+ if(status){
+ status = pwmss_tb_clock_check(pwmss_id);
+ } else {
+ status = false;
+ } else {
+ status = false;
+ return status;
#endif
@@ -387,33 +427,28 @@ bool beagle_ehrpwm_disable(uint32_t pwmid)
* GPIO API and to make the build successful.
* Later on support can be added here.
-uint32_t select_pwmss(uint32_t pwm_id)
-return -1;
+ return false;
-bool pwmss_tbclk_enable(unsigned int instance)
-return false;
+ return false;
-return false;
+ return false;
-return false;
+ return -1;
-return false;
+ return false;
-return -1;
return false;
#endif
2.7.4
