[PATCH 5/6] arm/raspberrypi: reorder and update MMU config table to nor force RW section later to RO.
pisa at cmp.felk.cvut.cz pisa at cmp.felk.cvut.cz
Sun Jul 17 22:48:41 UTC 2016
Enable even the first megabyte of SDRAM to be cache-able after
problems with stale cache content has been resolved by previous commit.
Because major part of application usually fits to the first
megabyte this speedups test dhrystone application by factor 40.
 .../arm/raspberrypi/startup/mm_config_table.c      | 31 +++++++++++++++-------
 1 file changed, 22 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
index 8a6d37a..50e19d8 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
@@ -23,32 +23,45 @@
 #include <bsp.h>
 #include <bsp/arm-cp15-start.h>
+ * Pagetable initialization data
+ * Keep all read-only sections before read-write ones.
+ * This ensures that write is allowed if one page/region
+ * is partially filled by read-only section contentent
+ * and rest is used for writeable section
 const arm_cp15_start_section_config arm_cp15_start_mmu_config_table[] = {
     .begin = (uint32_t) bsp_section_fast_text_begin,
     .end = (uint32_t) bsp_section_fast_text_end,
     .flags = ARMV7_MMU_CODE_CACHED
-    .begin = (uint32_t) bsp_section_fast_data_begin,
-    .end = (uint32_t) bsp_section_fast_data_end,
-    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
     .begin = (uint32_t) bsp_section_start_begin,
     .end = (uint32_t) bsp_section_start_end,
-    .begin = (uint32_t) bsp_section_vector_begin,
-    .end = (uint32_t) bsp_section_vector_end,
     .begin = (uint32_t) bsp_section_text_begin,
     .end = (uint32_t) bsp_section_text_end,
-    .flags = ARMV7_MMU_READ_WRITE
+    .flags = ARMV7_MMU_CODE_CACHED
     .begin = (uint32_t) bsp_section_rodata_begin,
     .end = (uint32_t) bsp_section_rodata_end,
     .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
+    .begin = (uint32_t) bsp_translation_table_base,
+    .end = (uint32_t) bsp_translation_table_base + 0x4000,
+    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
+    .begin = (uint32_t) bsp_section_fast_data_begin,
+    .end = (uint32_t) bsp_section_fast_data_end,
+    .begin = (uint32_t) bsp_section_vector_begin,
+    .end = (uint32_t) bsp_section_vector_end,
     .begin = (uint32_t) bsp_section_data_begin,
     .end = (uint32_t) bsp_section_data_end,
1.9.1
