[PATCH 3/6] arm/bsps: CP15 and basic cache support entire cache clean for more architecture variants now.
Pavel Pisa pisa at cmp.felk.cvut.cz
Wed Jul 20 09:05:22 UTC 2016
Hello Gedare,
thanks for review.
On Tuesday 19 of July 2016 17:21:16 Gedare Bloom wrote:
> > +      line_power = arm_ccsidr_get_line_power(ccsidr);
> > +      associativity = arm_ccsidr_get_associativity(ccsidr);
> > +      way_shift = __builtin_clz(associativity - 1);
> Can we use a non-GCCism here, or wrap it in to a support function?
The code is copy of arm_cp15_data_cache_invalidate_all_levels()
with replaced cache operation line.
There has been already __builtin_clz in the source and it is used
in more places in the code. I have not found reasonable portable
replacement which would compile well (this result in single
assembler instruction on ARMv5+, x86 etc.).
The ffs ffsl etc has been adopted by standard. But I cannot
find something like clz, fls in the standards. There is only
floating point log2 in math.h.
So I see as option to define CLZ somehow centrally in CPUkit
header to __builtin_clz for GCC. ARM and even Microsoft compilers
have equivalent operation (under other name) directly available
by compiler as well.
But such update of __builtin_clz  should go to other patch which
takes care of all RTEMS use locations.
Best wishes,
              Pavel
