support ftp Multiple user root directory and access control
yao0718
29171383 at qq.com
Thu Jul 21 08:18:35 UTC 2016
hi, I add Multiple user root directory and access control for rtems,I have test it on my board, can somebody interesting about it and test more?
--- ./base/ftpd.c 2016-03-11 11:39:41.752551200 +0800
+++ ./ftpd.c 2016-07-21 16:10:59.308281000 +0800
@@ -189,7 +189,7 @@
#if HAVE_CONFIG_H
#include "config.h"
#endif
@@ -266,6 +266,8 @@
rtems_id tid; /* Task id */
char *user; /* user name (0 if not supplied) */
char *pass; /* password (0 if not supplied) */
+ int access; /* access for session */
+ struct rtems_ftpd_user_list *p_user;
bool auth; /* true if user/pass was valid, false if not or not supplied */
} FTPD_SessionInfo_t;
@@ -325,15 +327,15 @@
static int
-can_read(void)
+can_read(int access)
- return (ftpd_access & FTPD_NO_READ) == 0;
+ return (access & FTPD_NO_READ) == 0;
static int
-can_write(void)
+can_write(int access)
- return (ftpd_access & FTPD_NO_WRITE) == 0;
+ return (access & FTPD_NO_WRITE) == 0;
@@ -783,7 +785,7 @@
struct stat stat_buf;
int res = 0;
- if(!can_read() || !info->auth)
+ if(!can_read(info->access) || !info->auth)
send_reply(info, 550, "Access denied.");
return;
@@ -927,7 +929,7 @@
typedef ssize_t (*WriteProc)(int, void const*, size_t);
WriteProc wrt = &write;
- if(!can_write() || !info->auth)
+ if(!can_write(info->access) || !info->auth)
return;
@@ -1667,6 +1669,33 @@
*p++ = '\0';
+/*find user list and chroot and set access mode for session*/
+static void check_user_access_ctrl(FTPD_SessionInfo_t *info)
+ struct rtems_ftpd_user_list *p_head = info->p_user;
+ if((!info->user)||(!p_head))
+ return;
+ while(p_head->user)
+ if(!strcmp(info->user,p_head->user))
+ if((!p_head->pass)||(!info->pass)||
+ (!strcmp(info->pass,p_head->pass)))
+ info->access = p_head->access;
+ if((p_head->root)&& (p_head->root[0] == '/'))
+ chroot(p_head->root);
+ break;
+ p_head++;
* exec_command
@@ -1688,6 +1717,7 @@
char fname[FTPD_BUFSIZE];
int wrong_command = 0;
fname[0] = '\0';
@@ -1755,7 +1785,10 @@
sscanf(args, "%254s", fname);
if (info->user)
free(info->user);
+ info->user = NULL;
if (info->pass)
free(info->pass);
info->pass = NULL;
@@ -1766,6 +1799,7 @@
send_reply(info, 331, "User name okay, need password.");
} else {
info->auth = true;
+ check_user_access_ctrl(info);
send_reply(info, 230, "User logged in.");
@@ -1784,13 +1818,14 @@
send_reply(info, 530, "Not logged in.");
} else {
info->auth = true;
else if (!strcmp("DELE", cmd))
@@ -1813,7 +1848,7 @@
int mask;
@@ -1832,7 +1867,7 @@
else if (!strcmp("RMD", cmd))
@@ -1849,7 +1884,7 @@
else if (!strcmp("MKD", cmd))
@@ -1907,7 +1942,11 @@
int chroot_made = 0;
rtems_libio_set_private_env();
+ /*add list for individual user access control*/
+ info->p_user = rtems_ftpd_configuration.user_ctrl_list;
+ info->access = rtems_ftpd_configuration.access;
/* chroot() can fail here because the directory may not exist yet. */
chroot_made = chroot(ftpd_root) == 0;
--- ./base/ftpd.h 2016-03-11 11:39:41.760052200 +0800
+++ ./ftpd.h 2016-07-21 16:11:02.474638800 +0800
@@ -6,7 +6,7 @@
#define _RTEMS_FTPD_H
#ifdef __cplusplus
extern "C" {
#endif
@@ -38,6 +38,18 @@
rtems_ftpd_hookfunction hook_function;
+/*add more lever control access for different user and password*/
+struct rtems_ftpd_user_list
+ char const *root;
+ char const *user;
+ char const *pass;
+ int access;
struct rtems_ftpd_configuration
rtems_task_priority priority; /* FTPD task priority */
@@ -54,6 +66,7 @@
3 - browse-only */
rtems_shell_login_check_t login; /* Login check or 0 to ignore
user/passwd. */
+ struct rtems_ftpd_user_list *user_ctrl_list;
usage example:
#define INCLUDE_FTPD_MULT_USER_ACCESS_CTRL
#define DEFAULT_FTPD_USER "admin"
#define DEFAULT_FTPD_PASS "123"
#ifdef INCLUDE_FTPD_MULT_USER_ACCESS_CTRL
static struct rtems_ftpd_user_list rtems_ftpd_user_ctrl_list[] =
{ "/", "admin", "admin", 0}, /*admin user for access all*/
{ "/mnt/data", "read", "read", 1}, /*read user for read /mnt/data only*/
{ "/mnt/etc", "look", "look", 3}, /* look user for brower etc only*/
{ "/mnt", "mine", "mine", 0}, /*mine user for access /mnt only*/
{ 0, 0, 0, 0},};
#endif
static bool rtems_ftpd_login_check(const char *user, const char *passphrase)
struct rtems_ftpd_user_list *p_head = rtems_ftpd_user_ctrl_list;
#endif
if ((user == NULL) || (passphrase == NULL))
return false;
if ((!strcmp(user, DEFAULT_FTPD_USER))
&& (!strcmp(passphrase, DEFAULT_FTPD_PASS)))
return true;
while (p_head->user)
if ((!strcmp(user, p_head->user))
&& (!strcmp(passphrase, p_head->pass)))
return true;
p_head++;
#endif
return false;
* ftpd support
struct rtems_ftpd_configuration rtems_ftpd_configuration =
{ .priority = 199, .max_hook_filesize = 32768, .port = 21, .hooks = 0, .root =
"/mnt", .tasks_count = 4, .idle = 60, .access = 0, .login =0,
// rtems_ftpd_login_check,
.user_ctrl_list = rtems_ftpd_user_ctrl_list
#endif
void net_ftpd_init(void)
rtems_initialize_ftpd();
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160721/ea5694e6/attachment-0001.html>
