[PATCH] score/i386: Add context switch restore external symbol as a marker.
Fri Jul 22 06:43:27 UTC 2016
On 22/07/16 08:34, Chris Johns wrote:
> On 22/07/2016 16:10, Sebastian Huber wrote:
>> On i386 the PC is stored on the stack frame:
>> #define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
>>                                     _isr, _entry_point, _is_fp,
>> _tls_area ) \
>>    do { \
>>      uint32_t   _stack; \
>>      (void) _is_fp; /* avoid warning for being unused */ \
>>      if ( (_isr) ) (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_OFF; \
>>      else          (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_ON; \
>>      _stack  = ((uint32_t)(_stack_base)) + (_size); \
>>      _stack &= ~ (CPU_STACK_ALIGNMENT - 1); \
>>      _stack -= 2*sizeof(proc_ptr*); /* see above for why we need to do
>> this */ \
>>      *((proc_ptr *)(_stack)) = (_entry_point); \
>>      (_the_context)->ebp     = (void *) 0; \
>>      (_the_context)->esp     = (void *) _stack; \
>>    } while (0)
>> The stack pointer is part of the context. If you retrieve the PC from
>> here it should work for all threads.
> All threads on the i386 arch or all threads on all archs?
> I would like to make this simpler for all archs. I do not mind if we
> require something being added to each arch to do this but I would like
> an interface somewhere and somehow.
I don't think that the thread context reconstruction can be done in an
architecture independent way. You have different register sets and
different ways to store the PC. For example on x86 the PC is on the
stack, on ARM you have Context_Control::register_lr, on PowerPC
ppc_context::lr which is embedded in Context_Control due to cache line
alignment, on SPARC you have Context_Control::o7, and so on.
I would rather provide a global function that provides the data for your
consumer (libunwind?) with a common interface for all architectures and
an architecture dependent implementation. The debugger could call this
function.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
