I2C testcase linking error
punit vara
punitvara at gmail.com
Sun Jul 24 07:06:30 UTC 2016
https://github.com/punitvara/rtems/tree/new
You can reproduce linking error from this new branch.
On Sat, Jul 23, 2016 at 11:57 PM, Ben Gras <beng at shrike-systems.com> wrote:
> All,
> I tried to reproduce this. The I2C branch of your repo doesn't build
> because of struct i2c not being defined. So I #if 0'd out all the
> function bodies in i2c.c, and then everything builds, without linker
> errors.
> What is your state now? Are you blocked on this (or anything else)
> still? If so, can you help me reproduce, e.g. by creating a branch that
> definitely exhibits the problem?
> I did build from scratch, if you have linking problems it may be an idea
> to rm -rf the beagle build dir and reconfigure and rebuild, in case
> there is a library hanging around with an extra object file it isn't
> supposed to have that the buildsystem isn't updating.
> Cheers,
> Ben
> On 22-07-16 14:26, punit vara wrote:
> /root/development/rtems/b-NEW/arm-rtems4.12/c/beagleboneblack/cpukit/libmisc/../../../../../../../../NEW/c/src/../../cpukit/libmisc/dummy/default-configuration.c:23:
> > multiple definition of
> > `_Linker_set__Sysinit__RTEMS_tasks_Initialize_user_tasks_body'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160724/3c2a5cb5/attachment.html>
