Help required with setting up TFTP communication between QEMU instance and host machine
Sun Jul 24 07:58:31 UTC 2016
On 23/07/2016 7:41 PM, vivek kukreja wrote:
> Thank you for your prompt advice regarding tap interface.
> I followed this mail chain and successfully run the ping01 example in rtems-libbsd:
> https://lists.rtems.org/pipermail/users/2015-June/029063.html
> Now I can ping and FTP into the QEMU instance from host machine!
Great. If you enable NFS and connect to an NFS server you can write
capture files this way.
