I2C testcase linking error
punit vara
punitvara at gmail.com
Sun Jul 24 18:28:50 UTC 2016
Thanks a lot. :) I2C framework uses IMFS that why I think this solution
worked.
On Sun, Jul 24, 2016 at 11:52 PM, Ben Gras <beng at shrike-systems.com> wrote:
> All,
> Aha, I see the problem indeed.
> From the output I conclude default-configuration.o is providing symbols
> that conflict with your configuration symbols. This suggests
> default-configuration.o is pulled in to satisfy some configuration
> requirement. This suggests we should put more info in init.c.
> I found a small change from your init.c that seems to "fix" this problem:
> -#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_FILESYSTEM_IMFS
> I guess DEVFS is too limited to support the I2C subsystem but I didn't go
> so deep as to find out what the ins and outs are once I saw this does link
> On 24-07-16 09:06, punit vara wrote:
> https://github.com/punitvara/rtems/tree/new
> You can reproduce linking error from this new branch.
> On Sat, Jul 23, 2016 at 11:57 PM, Ben Gras <beng at shrike-systems.com>
> wrote:
>> All,
>> I tried to reproduce this. The I2C branch of your repo doesn't build
>> because of struct i2c not being defined. So I #if 0'd out all the
>> function bodies in i2c.c, and then everything builds, without linker
>> errors.
>> What is your state now? Are you blocked on this (or anything else)
>> still? If so, can you help me reproduce, e.g. by creating a branch that
>> definitely exhibits the problem?
>> I did build from scratch, if you have linking problems it may be an idea
>> to rm -rf the beagle build dir and reconfigure and rebuild, in case
>> there is a library hanging around with an extra object file it isn't
>> supposed to have that the buildsystem isn't updating.
>> Cheers,
>> Ben
>> On 22-07-16 14:26, punit vara wrote:
>> /root/development/rtems/b-NEW/arm-rtems4.12/c/beagleboneblack/cpukit/libmisc/../../../../../../../../NEW/c/src/../../cpukit/libmisc/dummy/default-configuration.c:23:
>> > multiple definition of
>> > `_Linker_set__Sysinit__RTEMS_tasks_Initialize_user_tasks_body'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160724/a8cd5668/attachment.html>
