[PATCH] Add Untar_FromGzChunk_Print() + Test
Mon Jul 25 21:59:38 UTC 2016
OK to push.
On 25/07/2016 11:46 PM, Alexander Krutwig wrote:
>  cpukit/libmisc/Makefile.am            |  2 +-
>  cpukit/libmisc/untar/untar.h          | 33 +++++++++++++
>  cpukit/libmisc/untar/untar_tgz.c      | 89 +++++++++++++++++++++++++++++++++++
>  testsuites/libtests/configure.ac      |  3 +-
>  testsuites/libtests/tar01/Makefile.am | 32 +++++++++++--
>  testsuites/libtests/tar01/init.c      | 45 ++++++++++++++++++
>  testsuites/libtests/tar01/tar01.doc   |  1 +
>  testsuites/libtests/tar01/tar01.scn   | 11 +++++
>  8 files changed, 210 insertions(+), 6 deletions(-)
>  create mode 100644 cpukit/libmisc/untar/untar_tgz.c
> diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
> index a50de94..4f5c01d 100644
> --- a/cpukit/libmisc/Makefile.am
> +++ b/cpukit/libmisc/Makefile.am
> @@ -155,7 +155,7 @@ EXTRA_DIST += stackchk/README
>  ## libuntar
>  noinst_LIBRARIES += libuntar.a
> -libuntar_a_SOURCES = untar/untar.c untar/untar.h
> +libuntar_a_SOURCES = untar/untar.c untar/untar_tgz.c untar/untar.h
>  EXTRA_DIST += untar/README
> diff --git a/cpukit/libmisc/untar/untar.h b/cpukit/libmisc/untar/untar.h
> index 006f06d..4d00d36 100644
> --- a/cpukit/libmisc/untar/untar.h
> +++ b/cpukit/libmisc/untar/untar.h
> @@ -20,6 +20,7 @@
>  #include <stdbool.h>
>  #include <stddef.h>
>  #include <tar.h>
> +#include <zlib.h>
>  #include <rtems/print.h>
> @@ -38,6 +39,8 @@ extern "C" {
>  #define UNTAR_INVALID_CHECKSUM   2
>  #define UNTAR_INVALID_HEADER     3
> +#define UNTAR_GZ_INFLATE_FAILED 4
> +#define UNTAR_GZ_INFLATE_END_FAILED 5
>  int Untar_FromMemory(void *tar_buf, size_t size);
>  int Untar_FromMemory_Print(void *tar_buf, size_t size, const rtems_printer* printer);
> @@ -137,6 +140,36 @@ int Untar_FromChunk_Print(
> + * @brief Initializes the Untar_ChunkGzContext.
> + * @param Untar_ChunkGzContext *context [in] Pointer to a context structure.
> + * @param void *inflateBuffer [in] Pointer to a context structure.
> + * @param size_t inflateBufferSize [in] Size of inflateBuffer.
> +int Untar_GzChunkContext_Init(
> +  Untar_GzChunkContext *ctx,
> +  void *inflateBuffer,
> +  size_t inflateBufferSize
> + * @brief Untars a GZ compressed POSIX TAR file.
> + * This is a subroutine used to rip links, directories, and
> + * files out of a tar.gz/tgz file.
> + * @param Untar_ChunkContext *context [in] Pointer to a context structure.
> + * @param ssize buflen [in] Size of valid bytes in input buffer.
> + * @param z_stream *strm [in] Pointer to the current zlib context.
> +int Untar_FromGzChunk_Print(
> +  void *chunk,
> +  size_t chunk_size,
> +  const rtems_printer* printer
>   * This converts octal ASCII number representations into an
>   * unsigned long.  Only support 32-bit numbers for now.
> diff --git a/cpukit/libmisc/untar/untar_tgz.c b/cpukit/libmisc/untar/untar_tgz.c
> new file mode 100644
> index 0000000..1ab7ec9
> --- /dev/null
> +++ b/cpukit/libmisc/untar/untar_tgz.c
> @@ -0,0 +1,89 @@
> + * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/untar.h>
> +  int ret;
> +  int status = UNTAR_SUCCESSFUL;
> +  Untar_ChunkContext_Init(&ctx->base);
> +  ctx->inflateBuffer = inflateBuffer;
> +  ctx->inflateBufferSize = inflateBufferSize;
> +  memset(&ctx->strm, 0, sizeof(ctx->strm));
> +  ret = inflateInit2(&ctx->strm, 32 + MAX_WBITS);
> +  if (ret != Z_OK){
> +    status = UNTAR_FAIL;
> +  return status;
> +  void *chunk,
> +  const rtems_printer *printer
> +  int untar_succesful;
> +  int status;
> +  ctx->strm.next_in = (Bytef *)chunk;
> +  ctx->strm.avail_in = (size_t)chunk_size;
> +    /* Inflate until output buffer is not full */
> +  do {
> +    ctx->strm.next_out = (Bytef *) ctx->inflateBuffer;
> +    ctx->strm.avail_out = ctx->inflateBufferSize;
> +    status = inflate(&ctx->strm, Z_NO_FLUSH);
> +    if (status == Z_OK || status == Z_STREAM_END) {
> +      size_t inflated_size =
> +        ctx->inflateBufferSize - ctx->strm.avail_out;
> +      untar_succesful = Untar_FromChunk_Print(&ctx->base,
> +        ctx->inflateBuffer, inflated_size, NULL);
> +      if (untar_succesful != UNTAR_SUCCESSFUL){
> +        return untar_succesful;
> +  } while (ctx->strm.avail_out == 0 && ctx->strm.avail_in > 0
> +      && status == Z_OK);
> +  if (status != Z_OK) {
> +      rtems_printf(printer, "Untar not successful\n");
> +    if (status != Z_STREAM_END) {
> +      rtems_printf(printer, "Zlib inflate failed\n");
> +    status = inflateEnd(&ctx->strm);
> +      rtems_printf(printer, "Zlib inflate end failed\n");
> diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
> index a136749..82f2d80 100644
> --- a/testsuites/libtests/configure.ac
> +++ b/testsuites/libtests/configure.ac
> @@ -31,6 +31,7 @@ RTEMS_CHECK_CPUOPTS([RTEMS_POSIX_API])
>  AC_PROG_LN_S
>  AC_PATH_PROG([PAX],[pax],no)
> +AC_PATH_PROG([GZIP],[gzip],no)
>  AS_IF([test "x$PAX" = "xno"],[
>  	AC_MSG_ERROR([pax is missing.])
> @@ -38,7 +39,7 @@ AS_IF([test "x$PAX" = "xno"],[
>  AC_CHECK_HEADERS([complex.h])
> -AM_CONDITIONAL(TARTESTS,test "$as_ln_s" = "ln -s" && test -n "$PAX")
> +AM_CONDITIONAL(TARTESTS,test "$as_ln_s" = "ln -s" && test -n "$PAX" && test -n "$GZIP")
>  AM_CONDITIONAL(HAS_CXX,test "$rtems_cv_HAS_CPLUSPLUS" = "yes")
>  AM_CONDITIONAL([HAS_COMPLEX],[test "$ac_cv_header_complex_h" = yes])
> diff --git a/testsuites/libtests/tar01/Makefile.am b/testsuites/libtests/tar01/Makefile.am
> index 6bcb4f2..d7257bc 100644
> --- a/testsuites/libtests/tar01/Makefile.am
> +++ b/testsuites/libtests/tar01/Makefile.am
> @@ -1,9 +1,20 @@
>  if TARTESTS
>  rtems_tests_PROGRAMS = tar01
> -tar01_SOURCES = init.c ../../psxtests/psxfile01/test_cat.c \
> -  initial_filesystem_tar.c initial_filesystem_tar.h
> +tar01_SOURCES =
> +tar01_SOURCES += init.c
> +tar01_SOURCES += ../../psxtests/psxfile01/test_cat.c
> +tar01_SOURCES += initial_filesystem_tar.c
> +tar01_SOURCES += initial_filesystem_tar.h
> +tar01_SOURCES += initial_filesystem_tar_gz.c
> +tar01_SOURCES += initial_filesystem_tar_gz.h
> +tar01_LDADD = -lrtemscpu -lz
> -BUILT_SOURCES = initial_filesystem_tar.c initial_filesystem_tar.h
> +BUILT_SOURCES =
> +BUILT_SOURCES += initial_filesystem_tar.c
> +BUILT_SOURCES += initial_filesystem_tar.h
> +BUILT_SOURCES += initial_filesystem_tar_gz.c
> +BUILT_SOURCES += initial_filesystem_tar_gz.h
>  dist_rtems_tests_DATA = tar01.scn
>  dist_rtems_tests_DATA += tar01.doc
> @@ -18,7 +29,7 @@ AM_CPPFLAGS += -I$(top_srcdir)/include
>  AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>  AM_CPPFLAGS += -I$(top_srcdir)/../psxtests/include
> -LINK_OBJS = $(tar01_OBJECTS)
> +LINK_OBJS = $(tar01_OBJECTS) $(tar01_LDADD)
>  LINK_LIBS = $(tar01_LDLIBS)
>  tar01$(EXEEXT): $(tar01_OBJECTS) $(tar01_DEPENDENCIES)
> @@ -33,6 +44,14 @@ initial_filesystem_tar.h: initial_filesystem.tar
>  	$(BIN2C) -H initial_filesystem.tar initial_filesystem_tar
>  CLEANFILES += initial_filesystem_tar.h
> +initial_filesystem_tar_gz.c: initial_filesystem.tar.gz
> +	$(BIN2C) -C initial_filesystem.tar.gz initial_filesystem_tar_gz
> +CLEANFILES += initial_filesystem_tar_gz.h
> +initial_filesystem_tar_gz.h: initial_filesystem.tar.gz
> +	$(BIN2C) -H initial_filesystem.tar.gz initial_filesystem_tar_gz
>  initial_filesystem.tar:
>  	rm -rf initial_fs
>  	$(MKDIR_P) initial_fs/home
> @@ -42,6 +61,11 @@ initial_filesystem.tar:
>  	$(LN_S) home/test_file symlink; \
>  	$(PAX) -w -f ../initial_filesystem.tar home symlink)
>  CLEANFILES += initial_filesystem.tar
> +initial_filesystem.tar.gz: initial_filesystem.tar
> +	$(GZIP) < initial_filesystem.tar > initial_filesystem.tar.gz
> +CLEANFILES += initial_filesystem.tar.gz
>  endif TARTESTS
>  clean-local:
> diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
> index 285c767..4bfa29c 100644
> --- a/testsuites/libtests/tar01/init.c
> +++ b/testsuites/libtests/tar01/init.c
> @@ -24,6 +24,7 @@
>  #include <unistd.h>
>  #include "initial_filesystem_tar.h"
> +#include "initial_filesystem_tar_gz.h"
>  const char rtems_test_name[] = "TAR 1";
> @@ -32,9 +33,12 @@ rtems_task Init(rtems_task_argument argument);
>  void test_untar_from_memory(void);
>  void test_untar_from_file(void);
>  void test_untar_chunks_from_memory(void);
> +void test_untar_unzip_tgz(void);
>  #define TARFILE_START initial_filesystem_tar
>  #define TARFILE_SIZE  initial_filesystem_tar_size
> +#define TARFILE_GZ_START initial_filesystem_tar_gz
> +#define TARFILE_GZ_SIZE  initial_filesystem_tar_gz_size
>  void test_cat(
>    char *file,
> @@ -145,6 +149,45 @@ void test_untar_chunks_from_memory(void)
> +  int status;
> +  rtems_printer     printer;
> +  int rv;
> +  Untar_GzChunkContext ctx;
> +  size_t i = 0;
> +  char *buffer = (char *)TARFILE_GZ_START;
> +  size_t buflen = TARFILE_GZ_SIZE;
> +  char inflate_buffer;
> +  rtems_print_printer_printf(&printer);
> +  /* make a directory to untar it into */
> +  rv = mkdir( "/dest3", 0777 );
> +  rtems_test_assert( rv == 0 );
> +  rv = chdir( "/dest3" );
> +  printf( "Untaring chunks from tgz - " );
> +  status = Untar_GzChunkContext_Init(&ctx, &inflate_buffer, 1);
> +  rtems_test_assert(status == UNTAR_SUCCESSFUL);
> +  for(i = 0; i < buflen; i++) {
> +    status = Untar_FromGzChunk_Print(&ctx, &buffer[i], 1, &printer);
> +  printf( "successful\n" );
> +  printf( "========= /dest3/home/test_file =========\n" );
> +  test_cat( "/dest3/home/test_file", 0, 0 );
> +  printf( "========= /dest3/symlink =========\n" );
> +  test_cat( "/dest3/symlink", 0, 0 );
>  rtems_task Init(
>    rtems_task_argument ignored
> @@ -156,6 +199,8 @@ rtems_task Init(
>    test_untar_from_file();
>    puts( "" );
>    test_untar_chunks_from_memory();
> +  puts( "" );
> +  test_untar_unzip_tgz();
>    TEST_END();
>    exit( 0 );
> diff --git a/testsuites/libtests/tar01/tar01.doc b/testsuites/libtests/tar01/tar01.doc
> index 1a8151c..060f98a 100644
> --- a/testsuites/libtests/tar01/tar01.doc
> +++ b/testsuites/libtests/tar01/tar01.doc
> @@ -15,6 +15,7 @@ directives:
>    + Untar_FromMemory
>    + Untar_FromFile
>    + Untar_ChunksFromMemory
> +  + Untar_UnzipTgz
>  concepts:
> diff --git a/testsuites/libtests/tar01/tar01.scn b/testsuites/libtests/tar01/tar01.scn
> index 078cedf..68fa951 100644
> --- a/testsuites/libtests/tar01/tar01.scn
> +++ b/testsuites/libtests/tar01/tar01.scn
> @@ -31,4 +31,15 @@ initial tar image.
>  (0)This is a test of loading an RTEMS filesystem from an
>  initial tar image.
> +Untaring chunks from tgz- untar: dir: home
> +untar: file: home/test_file (73)
> +successful
> +========= /dest3/home/test_file =========
> +(0)This is a test of loading an RTEMS filesystem from an
> +initial tar image.
> +========= /dest3/symlink =========
> +initial tar image.
>  *** END OF TAR01 TEST ***
