[PATCH] SDHC driver for PowerPC QoriQ
Tue Jul 26 05:36:42 UTC 2016
On 26/07/16 03:17, Nickolay Kolchin wrote:
> 1. We were not aware about existing SDHC driver. We always considered
> rtems-libbsd an experiment. Is it ready for production use?
Yes, its definitely ready for production use. Its documentation and
configuration is currently the weak point.
I would prefer to get the SD/MMC card support improved in libbsd instead
of adding more and more BSP-specific drivers each with its own basic
support code.
> 2. Driver was developed for Kontron P2020 board. Existing errata for
> this chip (P1020), mentions only "inability to detect sdcard at startup".
For the SDHC you have to be careful with erratas, a good reference is
the Linux driver "drivers/mmc/host/sdhci-of-esdhc.c". I had trouble to
get a stable DMA support on the P1020.
> On Mon, Jul 25, 2016 at 8:48 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Nickolay,
>     the sources must have a proper license header. Is there a
>     particular reason why you didn't use the standard SDHC driver:
>     https://git.rtems.org/rtems-libbsd/tree/freebsd/sys/dev/sdhci/sdhci.c
>     It depends a bit on your QorIQ variant, some have nasty silicon
>     bugs in the SDHC area.
>     Please don't use rtems_disk_create_phys() for new code, use
>     rtems_blkdev_create() instead.
>     On 25/07/16 03:47, Nickolay Semyonov wrote:
>         From: Nickolay Semyonov <snob at wolpike.com
>         <mailto:snob at wolpike.com>>
>         Heavily tested with iozone.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
