[PATCH v2 5/5] score: Add deadlock detection
Tue Jul 26 09:20:52 UTC 2016
The mutex objects use the owner field of the thread queues for the mutex
owner.  Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
 cpukit/sapi/src/interrtext.c                       |   5 +-
 cpukit/score/include/rtems/score/interr.h          |   3 +-
 cpukit/score/include/rtems/score/thread.h          |   6 +
 cpukit/score/include/rtems/score/threadq.h         |  45 ++-
 cpukit/score/include/rtems/score/threadqimpl.h     |  38 ++
 cpukit/score/src/coremutexseize.c                  |   9 +
 cpukit/score/src/mutex.c                           |   4 +
 cpukit/score/src/threadqenqueue.c                  | 256 ++++++++++++-
 testsuites/sptests/spinternalerror02/init.c        |   4 +-
 .../spinternalerror02/spinternalerror02.scn        |   3 +-
 testsuites/sptests/spmutex01/init.c                | 413 +++++++++++++++++++--
 testsuites/sptests/spmutex01/spmutex01.doc         |   5 +
 testsuites/sptests/spsyslock01/init.c              |  79 ++--
 13 files changed, 768 insertions(+), 102 deletions(-)
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 3ae7315..8408061 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -7,7 +7,7 @@
- * Copyright (c) 2012-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2012, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -54,7 +54,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR",
   "INTERNAL_ERROR_RESOURCE_IN_USE",
   "INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL",
-  "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL"
+  "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL",
+  "INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 8d4c104..845dc6f 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -163,7 +163,8 @@ typedef enum {
   INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
   INTERNAL_ERROR_RESOURCE_IN_USE,
   INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL,
-  INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
+  INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL,
+  INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 85d759c..d10143b 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -327,6 +327,12 @@ typedef struct {
     Chain_Control Pending_requests;
   } Lock;
+   * @brief Thread queue link provided for use by the thread wait lock owner to
+   * build a thread queue path.
+  Thread_queue_Link Link;
 #endif
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 9a17804..a39a031 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -49,6 +49,17 @@ typedef struct Thread_queue_Operations Thread_queue_Operations;
 typedef struct Thread_queue_Path Thread_queue_Path;
+ * @brief Thread queue deadlock callout.
+ * @param the_thread The thread that detected the deadlock.
+ * @see _Thread_queue_Context_set_deadlock_callout().
+typedef void ( *Thread_queue_Deadlock_callout )(
+  Thread_Control *the_thread
 #if defined(RTEMS_MULTIPROCESSING)
  * @brief Multiprocessing (MP) support callout for thread queue operations.
@@ -117,6 +128,17 @@ typedef struct {
   uint64_t timeout;
+   * @brief Invoked in case of a detected deadlock.
+   * Must be initialized for _Thread_queue_Enqueue_critical() in case the
+   * thread queue may have an owner, e.g. for mutex objects.
+  Thread_queue_Deadlock_callout deadlock_callout;
+#if defined(RTEMS_MULTIPROCESSING)
    * @brief Callout to unblock the thread in case it is actually a thread
    * proxy.
@@ -126,7 +148,6 @@ typedef struct {
    * @see _Thread_queue_Context_set_MP_callout().
-#if defined(RTEMS_MULTIPROCESSING)
   Thread_queue_MP_callout mp_callout;
 #endif
@@ -175,6 +196,28 @@ typedef struct {
 typedef struct {
+   * @brief Node to register this link in the global thread queue links lookup
+   * tree.
+  RBTree_Node Registry_node;
+   * @brief The source thread queue determined by the thread queue owner.
+  Thread_queue_Queue *source;
+   * @brief The target thread queue determined by the thread wait queue of the
+   * source owner.
+  Thread_queue_Queue *target;
+   * @brief Node to add this link to a thread queue path.
+  Chain_Node Path_node;
    * @brief The owner of this thread queue link.
   Thread_Control *owner;
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 11dc6c5..fba6856 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -52,6 +52,11 @@ extern "C" {
 struct Thread_queue_Path {
 #if defined(RTEMS_SMP)
+   * @brief The chain of thread queue links defining the thread queue path.
+  Chain_Control Links;
    * @brief The start of a thread queue path.
   Thread_queue_Link Start;
@@ -86,6 +91,16 @@ typedef struct {
 } Thread_queue_Syslock_queue;
+ * @brief Sets the thread wait return code to STATUS_DEADLOCK.
+void _Thread_queue_Deadlock_status( Thread_Control *the_thread );
+ * @brief Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
+void _Thread_queue_Deadlock_fatal( Thread_Control *the_thread );
  * @brief Initializes a thread queue context.
  * @param queue_context The thread queue context to initialize.
@@ -97,6 +112,7 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(
 #if defined(RTEMS_DEBUG)
   memset( queue_context, 0, sizeof( *queue_context ) );
   queue_context->expected_thread_dispatch_disable_level = 0xdeadbeef;
+  queue_context->deadlock_callout = _Thread_queue_Deadlock_fatal;
 #else
   (void) queue_context;
 #endif
@@ -173,6 +189,28 @@ _Thread_queue_Context_set_absolute_timeout(
+ * @brief Sets the deadlock callout in the thread queue
+ * context.
+ * A deadlock callout must be provided for _Thread_queue_Enqueue_critical()
+ * operations that operate on thread queues which may have an owner, e.g. mutex
+ * objects.  Available deadlock callouts are _Thread_queue_Deadlock_status()
+ * and _Thread_queue_Deadlock_fatal().
+ * @param queue_context The thread queue context.
+ * @param deadlock_callout The deadlock callout.
+ * @see _Thread_queue_Enqueue_critical().
+RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_deadlock_callout(
+  Thread_queue_Context          *queue_context,
+  queue_context->deadlock_callout = deadlock_callout;
  * @brief Sets the MP callout in the thread queue context.
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index dacb274..cfefc50 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -62,6 +62,11 @@ Status_Control _CORE_mutex_Seize_slow(
   _Thread_queue_Context_set_expected_level( queue_context, 2 );
 #endif
+  _Thread_queue_Context_set_deadlock_callout(
+    queue_context,
+    _Thread_queue_Deadlock_status
     &the_mutex->Wait_queue.Queue,
     CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
@@ -87,6 +92,10 @@ Status_Control _CORE_mutex_Seize_no_protocol_slow(
   if ( wait ) {
     _Thread_queue_Context_set_expected_level( queue_context, 1 );
+      queue_context,
       operations,
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index 12a4f29..085d5c2 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -108,6 +108,10 @@ static void _Mutex_Acquire_slow(
+    queue_context,
+    _Thread_queue_Deadlock_fatal
     &mutex->Queue.Queue,
     MUTEX_TQ_OPERATIONS,
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 19c345b..8ccbf68 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -9,6 +9,8 @@
  *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
+ *  Copyright (c) 2015, 2016 embedded brains GmbH.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
@@ -34,49 +36,266 @@
 #define THREAD_QUEUE_READY_AGAIN \
   (THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_READY_AGAIN)
+#if defined(RTEMS_SMP)
+ * A global registry of active thread queue links is used to provide deadlock
+ * detection on SMP configurations.  This is simple to implement and no
+ * additional storage is required for the thread queues.  The disadvantage is
+ * that this global registry is not scalable and may lead to lock contention.
+ * However, the registry is only used in case of nested resource conflicts.  In
+ * this case, the application is already in trouble.
+typedef struct {
+  ISR_lock_Control Lock;
+  RBTree_Control Links;
+} Thread_queue_Links;
+static Thread_queue_Links _Thread_queue_Links = {
+  ISR_LOCK_INITIALIZER( "Thread Queue Links" ),
+  RBTREE_INITIALIZER_EMPTY( _Thread_queue_Links.Links )
+static bool _Thread_queue_Link_equal(
+  const void        *left,
+  const RBTree_Node *right
+  const Thread_queue_Queue *the_left;
+  const Thread_queue_Link  *the_right;
+  the_left = left;
+  the_right = (Thread_queue_Link *) right;
+  return the_left == the_right->source;
+static bool _Thread_queue_Link_less(
+  const void        *left,
+  the_left = left;
+  return (uintptr_t) the_left < (uintptr_t) the_right->source;
+static void *_Thread_queue_Link_map( RBTree_Node *node )
+  return node;
+static Thread_queue_Link *_Thread_queue_Link_find(
+  Thread_queue_Links *links,
+  return _RBTree_Find_inline(
+    &links->Links,
+    source,
+    _Thread_queue_Link_equal,
+    _Thread_queue_Link_less,
+    _Thread_queue_Link_map
+static bool _Thread_queue_Link_add(
+  Thread_queue_Link  *link,
+  Thread_queue_Queue *source,
+  Thread_queue_Links *links;
+  Thread_queue_Queue *recursive_target;
+  ISR_lock_Context    lock_context;
+  links = &_Thread_queue_Links;
+  recursive_target = target;
+  _ISR_lock_Acquire( &links->Lock, &lock_context );
+  while ( true ) {
+    Thread_queue_Link *recursive_link;
+    recursive_link = _Thread_queue_Link_find( links, recursive_target );
+    if ( recursive_link == NULL ) {
+      break;
+    recursive_target = recursive_link->target;
+    if ( recursive_target == source ) {
+      _ISR_lock_Release( &links->Lock, &lock_context );
+      return false;
+  link->source = source;
+  link->target = target;
+  _RBTree_Insert_inline(
+    &links->Links,
+    &link->Registry_node,
+    source,
+  return true;
+static void _Thread_queue_Link_remove( Thread_queue_Link *link )
+  _RBTree_Extract( &links->Links, &link->Registry_node );
+#endif
 static void _Thread_queue_Path_release( Thread_queue_Path *path )
-  Thread_queue_Link *link;
+  Chain_Node *head;
+  Chain_Node *node;
-  link = &path->Start;
+  head = _Chain_Head( &path->Links );
+  node = _Chain_Last( &path->Links );
+  while ( head != node ) {
+    Thread_queue_Link *link;
+    link = RTEMS_CONTAINER_OF( node, Thread_queue_Link, Path_node );
+    if ( link->Queue_context.Wait.queue_lock != NULL ) {
+      _Thread_queue_Link_remove( link );
-  if ( link->owner != NULL ) {
     _Thread_Wait_release_critical( link->owner, &link->Queue_context );
+    node = _Chain_Previous( node );
+#if defined(RTEMS_DEBUG)
+    _Chain_Set_off_chain( &link->Path_node );
+#endif
 #else
   (void) path;
 #endif
-static void _Thread_queue_Path_acquire(
+static bool _Thread_queue_Path_acquire(
   Thread_Control     *the_thread,
   Thread_queue_Queue *queue,
-#if defined(RTEMS_SMP)
+  _Chain_Initialize_empty( &path->Links );
+  _Chain_Initialize_node( &path->Start.Path_node );
+  _Thread_queue_Context_initialize( &path->Start.Queue_context );
   owner = queue->owner;
   if ( owner == NULL ) {
-    return;
+    return true;
+  if ( owner == the_thread ) {
+    return false;
-  link->owner = owner;
-  _Thread_Wait_acquire_default_critical(
-    owner,
-    &link->Queue_context.Lock_context
+  do {
+    _Chain_Append_unprotected( &path->Links, &link->Path_node );
+    link->owner = owner;
+    _Thread_Wait_acquire_default_critical(
+      owner,
+      &link->Queue_context.Lock_context
+    target = owner->Wait.queue;
+    link->Queue_context.Wait.queue = target;
+    link->Queue_context.Wait.operations = owner->Wait.operations;
+    if ( target != NULL ) {
+      if ( _Thread_queue_Link_add( link, queue, target ) ) {
+        link->Queue_context.Wait.queue_lock = &target->Lock;
+          &owner->Wait.Lock.Pending_requests,
+          &link->Queue_context.Wait.Gate.Node
+        _Thread_Wait_release_default_critical(
+          owner,
+        _Thread_Wait_acquire_queue_critical(
+          &target->Lock,
+        if ( link->Queue_context.Wait.queue == NULL ) {
+          return true;
+      } else {
+        link->Queue_context.Wait.queue_lock = NULL;
+        _Thread_queue_Path_release( path );
+        return false;
+    } else {
+      return true;
+    link = &owner->Wait.Link;
+    queue = target;
+    owner = queue->owner;
+  } while ( owner != NULL );
 #else
-  (void) the_thread;
-  (void) queue;
-  (void) path;
+  do {
+    if ( owner == NULL ) {
+      return true;
+      return false;
+    queue = owner->Wait.queue;
+  } while ( queue != NULL );
 #endif
+  return true;
+  the_thread->Wait.return_code = STATUS_DEADLOCK;
+  _Terminate(
+    INTERNAL_ERROR_CORE,
+    false,
 void _Thread_queue_Enqueue_critical(
@@ -99,8 +318,15 @@ void _Thread_queue_Enqueue_critical(
   _Thread_Wait_claim( the_thread, queue, operations );
-  _Thread_queue_Path_acquire( the_thread, queue, &path );
+  if ( !_Thread_queue_Path_acquire( the_thread, queue, &path ) ) {
+    _Thread_Wait_restore_default( the_thread );
+    _Thread_queue_Queue_release( queue, &queue_context->Lock_context );
+    ( *queue_context->deadlock_callout )( the_thread );
+    return;
   ( *operations->enqueue )( queue, the_thread, &path );
   _Thread_queue_Path_release( &path );
   the_thread->Wait.return_code = STATUS_SUCCESSFUL;
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index cbc81a5..eac90a0 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -1,5 +1,5 @@
  *  Donierstr. 4
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
+    error - 3 == INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index c6e85b1..ff04560 100644
--- a/testsuites/sptests/spinternalerror02/spinternalerror02.scn
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -17,7 +17,7 @@ INTERNAL_ERROR_BAD_STACK_HOOK
 INTERNAL_ERROR_BAD_ATTRIBUTES
 INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
 OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL
-INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
+INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE
 INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
 OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
 INTERNAL_ERROR_GXX_KEY_ADD_FAILED
@@ -27,6 +27,7 @@ INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
+INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
 INTERNAL_ERROR_CORE
diff --git a/testsuites/sptests/spmutex01/init.c b/testsuites/sptests/spmutex01/init.c
index 76d62c0..c363370 100644
--- a/testsuites/sptests/spmutex01/init.c
+++ b/testsuites/sptests/spmutex01/init.c
@@ -16,33 +16,65 @@
   #include "config.h"
 #endif
+#include <threads.h>
+#include <setjmp.h>
+#include <rtems.h>
+#include <rtems/libcsupport.h>
+#ifdef RTEMS_POSIX_API
+#include <errno.h>
+#include <pthread.h>
+#endif
 #include "tmacros.h"
 const char rtems_test_name[] = "SPMUTEX 1";
 #define TASK_COUNT 5
+#define MTX_COUNT 3
 typedef enum {
   REQ_WAKE_UP_MASTER = RTEMS_EVENT_0,
   REQ_WAKE_UP_HELPER = RTEMS_EVENT_1,
-  REQ_MTX_OBTAIN = RTEMS_EVENT_2,
-  REQ_MTX_RELEASE = RTEMS_EVENT_3
+  REQ_MTX_0_OBTAIN = RTEMS_EVENT_2,
+  REQ_MTX_0_RELEASE = RTEMS_EVENT_3,
+  REQ_MTX_1_OBTAIN = RTEMS_EVENT_4,
+  REQ_MTX_1_RELEASE = RTEMS_EVENT_5,
+  REQ_MTX_2_OBTAIN = RTEMS_EVENT_6,
+  REQ_MTX_2_RELEASE = RTEMS_EVENT_7,
+  REQ_MTX_C11_OBTAIN = RTEMS_EVENT_8,
+  REQ_MTX_C11_RELEASE = RTEMS_EVENT_9,
+  REQ_MTX_POSIX_OBTAIN = RTEMS_EVENT_10,
+  REQ_MTX_POSIX_RELEASE = RTEMS_EVENT_11
 } request_id;
 typedef enum {
+  M,
   A_1,
   A_2_0,
   A_2_1,
-  M,
   H,
   NONE
 } task_id;
+typedef enum {
+  MTX_0,
+  MTX_1,
+  MTX_2
+} mutex_id;
 typedef struct {
-  rtems_id mtx;
+  rtems_id mtx[MTX_COUNT];
+  mtx_t mtx_c11;
+  pthread_mutex_t mtx_posix;
+#endif
   rtems_id tasks[TASK_COUNT];
   int generation[TASK_COUNT];
   int expected_generation[TASK_COUNT];
+  jmp_buf deadlock_return_context;
 } test_context;
 static test_context test_instance;
@@ -109,22 +141,79 @@ static void request(test_context *ctx, task_id id, request_id req)
   sync_with_helper(ctx);
-static void obtain(test_context *ctx)
+static void obtain(test_context *ctx, mutex_id id)
   rtems_status_code sc;
-  sc = rtems_semaphore_obtain(ctx->mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_semaphore_obtain(ctx->mtx[id], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void release(test_context *ctx)
+static void deadlock_obtain(test_context *ctx, mutex_id id)
-  sc = rtems_semaphore_release(ctx->mtx);
+  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+static void release(test_context *ctx, mutex_id id)
+  rtems_status_code sc;
+  sc = rtems_semaphore_release(ctx->mtx[id]);
+static void obtain_c11(test_context *ctx)
+  int status;
+  status = mtx_lock(&ctx->mtx_c11);
+  rtems_test_assert(status == thrd_success);
+static void deadlock_obtain_c11(test_context *ctx)
+  if (setjmp(ctx->deadlock_return_context) == 0) {
+    (void) mtx_lock(&ctx->mtx_c11);
+static void release_c11(test_context *ctx)
+  int status;
+  status = mtx_unlock(&ctx->mtx_c11);
+static void obtain_posix(test_context *ctx)
+  int error;
+  error = pthread_mutex_lock(&ctx->mtx_posix);
+  rtems_test_assert(error == 0);
+static void deadlock_obtain_posix(test_context *ctx)
+  int error;
+  rtems_test_assert(error == EDEADLK);
+static void release_posix(test_context *ctx)
+  int error;
+  error = pthread_mutex_unlock(&ctx->mtx_posix);
+#endif
 static void check_generations(test_context *ctx, task_id a, task_id b)
   size_t i;
@@ -179,22 +268,65 @@ static void worker(rtems_task_argument arg)
   while (true) {
     rtems_event_set events = wait_for_events();
-    if ((events & REQ_MTX_OBTAIN) != 0) {
-      obtain(ctx);
+    if ((events & REQ_MTX_0_OBTAIN) != 0) {
+      obtain(ctx, MTX_0);
       ++ctx->generation[id];
-    if ((events & REQ_MTX_RELEASE) != 0) {
-      release(ctx);
+    if ((events & REQ_MTX_0_RELEASE) != 0) {
+      release(ctx, MTX_0);
+    if ((events & REQ_MTX_1_OBTAIN) != 0) {
+      obtain(ctx, MTX_1);
+      ++ctx->generation[id];
+    if ((events & REQ_MTX_1_RELEASE) != 0) {
+      release(ctx, MTX_1);
+    if ((events & REQ_MTX_2_OBTAIN) != 0) {
+      obtain(ctx, MTX_2);
+    if ((events & REQ_MTX_2_RELEASE) != 0) {
+      release(ctx, MTX_2);
+    if ((events & REQ_MTX_C11_OBTAIN) != 0) {
+      obtain_c11(ctx);
+    if ((events & REQ_MTX_C11_RELEASE) != 0) {
+      release_c11(ctx);
+    if ((events & REQ_MTX_POSIX_OBTAIN) != 0) {
+      obtain_posix(ctx);
+    if ((events & REQ_MTX_POSIX_RELEASE) != 0) {
+      release_posix(ctx);
+#endif
-static void test(void)
+static void set_up(test_context *ctx)
-  test_context *ctx = &test_instance;
+  int status;
+  size_t i;
   ctx->tasks[M] = rtems_task_self();
   start_task(ctx, A_1, worker, 1);
@@ -202,61 +334,264 @@ static void test(void)
   start_task(ctx, A_2_1, worker, 2);
   start_task(ctx, H, helper, 3);
-  sc = rtems_semaphore_create(
-    rtems_build_name(' ', 'M', 'T', 'X'),
-    1,
-    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
-    0,
-    &ctx->mtx
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  for (i = 0; i < MTX_COUNT; ++i) {
+    sc = rtems_semaphore_create(
+      rtems_build_name(' ', 'M', 'T', 'X'),
+      1,
+      RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+      0,
+      &ctx->mtx[i]
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  obtain(ctx);
-  request(ctx, A_1, REQ_MTX_OBTAIN);
+  status = mtx_init(&ctx->mtx_c11, mtx_plain);
+    int error;
+    pthread_mutexattr_t attr;
+    error = pthread_mutexattr_init(&attr);
+    error = pthread_mutexattr_setprotocol(&attr, PTHREAD_PRIO_INHERIT);
+    error = pthread_mutex_init(&ctx->mtx_posix, &attr);
+    error = pthread_mutexattr_destroy(&attr);
+#endif
+static void test_inherit(test_context *ctx)
+  request(ctx, A_1, REQ_MTX_0_OBTAIN);
   check_generations(ctx, NONE, NONE);
   assert_prio(ctx, M, 1);
-  release(ctx);
   check_generations(ctx, A_1, NONE);
   assert_prio(ctx, M, 3);
-  request(ctx, A_1, REQ_MTX_RELEASE);
+  request(ctx, A_1, REQ_MTX_0_RELEASE);
-  obtain(ctx);
-  request(ctx, A_2_0, REQ_MTX_OBTAIN);
-  request(ctx, A_2_1, REQ_MTX_OBTAIN);
+static void test_inherit_fifo_for_equal_priority(test_context *ctx)
+  request(ctx, A_2_0, REQ_MTX_0_OBTAIN);
+  request(ctx, A_2_1, REQ_MTX_0_OBTAIN);
-  release(ctx);
   assert_prio(ctx, A_1, 1);
   check_generations(ctx, A_1, A_2_0);
-  request(ctx, A_2_0, REQ_MTX_RELEASE);
+  request(ctx, A_2_0, REQ_MTX_0_RELEASE);
   check_generations(ctx, A_2_0, A_2_1);
-  request(ctx, A_2_1, REQ_MTX_RELEASE);
+  request(ctx, A_2_1, REQ_MTX_0_RELEASE);
   check_generations(ctx, A_2_1, NONE);
-static void Init(rtems_task_argument arg)
+static void test_deadlock_two_classic(test_context *ctx)
-  TEST_BEGIN();
+  request(ctx, A_1, REQ_MTX_1_OBTAIN);
+  check_generations(ctx, A_1, NONE);
+  check_generations(ctx, NONE, NONE);
+  deadlock_obtain(ctx, MTX_1);
+  request(ctx, A_1, REQ_MTX_1_RELEASE);
+static void test_deadlock_three_classic(test_context *ctx)
+  request(ctx, A_2_0, REQ_MTX_2_OBTAIN);
+  check_generations(ctx, A_2_0, NONE);
+  request(ctx, A_2_0, REQ_MTX_1_OBTAIN);
+  deadlock_obtain(ctx, MTX_2);
+  check_generations(ctx, A_1, A_2_0);
+  request(ctx, A_2_0, REQ_MTX_2_RELEASE);
+  request(ctx, A_2_0, REQ_MTX_1_RELEASE);
+static void test_deadlock_c11_and_classic(test_context *ctx)
+  obtain_c11(ctx);
+  request(ctx, A_1, REQ_MTX_C11_OBTAIN);
+  deadlock_obtain(ctx, MTX_0);
+  release_c11(ctx);
+  request(ctx, A_1, REQ_MTX_C11_RELEASE);
+static void test_deadlock_classic_and_c11(test_context *ctx)
+  deadlock_obtain_c11(ctx);
+static void test_deadlock_posix_and_classic(test_context *ctx)
+  request(ctx, A_1, REQ_MTX_POSIX_OBTAIN);
+  request(ctx, A_1, REQ_MTX_POSIX_RELEASE);
+#endif
+static void test_deadlock_classic_and_posix(test_context *ctx)
+  deadlock_obtain_posix(ctx);
+#endif
+static void tear_down(test_context *ctx)
+  size_t i;
+  for (i = 1; i < TASK_COUNT; ++i) {
+    sc = rtems_task_delete(ctx->tasks[i]);
+    sc = rtems_semaphore_delete(ctx->mtx[i]);
+  mtx_destroy(&ctx->mtx_c11);
+    int error;
+    error = pthread_mutex_destroy(&ctx->mtx_posix);
+#endif
-  test();
+static void Init(rtems_task_argument arg)
+  test_context *ctx = &test_instance;
+  rtems_resource_snapshot snapshot;
+  TEST_BEGIN();
+  rtems_resource_snapshot_take(&snapshot);
+  set_up(ctx);
+  test_inherit(ctx);
+  test_inherit_fifo_for_equal_priority(ctx);
+  test_deadlock_two_classic(ctx);
+  test_deadlock_three_classic(ctx);
+  test_deadlock_c11_and_classic(ctx);
+  test_deadlock_classic_and_c11(ctx);
+  test_deadlock_posix_and_classic(ctx);
+  test_deadlock_classic_and_posix(ctx);
+  tear_down(ctx);
+  rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
   TEST_END();
   rtems_test_exit(0);
+static void fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code error
+  if (
+    source == INTERNAL_ERROR_CORE
+      && !is_internal
+      && error == INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
+    longjmp(ctx->deadlock_return_context, 1);
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
 #define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
-#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 3
+#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
+#endif
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INITIAL_EXTENSIONS \
+  { .fatal = fatal_extension }, \
+  RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_INIT_TASK_PRIORITY 3
diff --git a/testsuites/sptests/spmutex01/spmutex01.doc b/testsuites/sptests/spmutex01/spmutex01.doc
index 7951024..7bcb850 100644
--- a/testsuites/sptests/spmutex01/spmutex01.doc
+++ b/testsuites/sptests/spmutex01/spmutex01.doc
@@ -4,6 +4,10 @@ test set name: spmutex01
 directives:
+  - mtx_lock()
+  - mtx_unlock()
+  - pthread_mutex_lock()
+  - pthread_mutex_unlock()
   - rtems_semaphore_create()
   - rtems_semaphore_obtain()
   - rtems_semaphore_release()
@@ -12,3 +16,4 @@ concepts:
   - Ensure that priority inheritance mechanism works.
   - Ensure that thread priority queueing discipline works.
+  - Ensure that deadlock detection works in various combinations.
diff --git a/testsuites/sptests/spsyslock01/init.c b/testsuites/sptests/spsyslock01/init.c
index 5bf5d6a..1e0d4818 100644
--- a/testsuites/sptests/spsyslock01/init.c
+++ b/testsuites/sptests/spsyslock01/init.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2015, 2016 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -21,7 +21,7 @@
 #include <sys/lock.h>
 #include <limits.h>
-#include <pthread.h>
 #include <time.h>
@@ -35,8 +35,6 @@ const char rtems_test_name[] = "SPSYSLOCK 1";
 #define EVENT_MTX_PRIO_INV RTEMS_EVENT_2
-#define EVENT_MTX_DEADLOCK RTEMS_EVENT_3
 #define EVENT_REC_MTX_ACQUIRE RTEMS_EVENT_4
 #define EVENT_REC_MTX_RELEASE RTEMS_EVENT_5
@@ -56,7 +54,6 @@ typedef struct {
   rtems_id mid;
   rtems_id low;
   struct _Mutex_Control mtx;
-  struct _Mutex_Control deadlock_mtx;
   struct _Mutex_recursive_Control rec_mtx;
   struct _Condition_Control cond;
   struct _Semaphore_Control sem;
@@ -65,6 +62,7 @@ typedef struct {
   int eno[2];
   int generation[2];
   int current_generation[2];
 } test_context;
@@ -298,6 +296,19 @@ static void test_mtx_timeout_recursive(test_context *ctx)
   send_event(ctx, idx, EVENT_REC_MTX_RELEASE);
+static void test_mtx_deadlock(test_context *ctx)
+  struct _Mutex_Control *mtx = &ctx->mtx;
+  _Mutex_Acquire(mtx);
+  _Mutex_Release(mtx);
 static void test_condition(test_context *ctx)
   struct _Condition_Control *cond = &ctx->cond;
@@ -493,21 +504,6 @@ static void mid_task(rtems_task_argument arg)
   rtems_test_assert(0);
-#ifdef RTEMS_POSIX_API
-static void deadlock_cleanup(void *arg)
-  struct _Mutex_Control *deadlock_mtx = arg;
-   * The thread terminate procedure will dequeue us from the wait queue.  So,
-   * one release is sufficient.
-  _Mutex_Release(deadlock_mtx);
-  _Mutex_Destroy(deadlock_mtx);
-#endif
 static void high_task(rtems_task_argument idx)
@@ -553,22 +549,6 @@ static void high_task(rtems_task_argument idx)
-    if ((events & EVENT_MTX_DEADLOCK) != 0) {
-      struct _Mutex_Control *deadlock_mtx = &ctx->deadlock_mtx;
-      pthread_cleanup_push(deadlock_cleanup, deadlock_mtx);
-#endif
-      _Mutex_Initialize(deadlock_mtx);
-      _Mutex_Acquire(deadlock_mtx);
-      pthread_cleanup_pop(0);
-#endif
     if ((events & EVENT_REC_MTX_ACQUIRE) != 0) {
       _Mutex_recursive_Acquire(&ctx->rec_mtx);
@@ -670,6 +650,7 @@ static void test(void)
   test_prio_inv_recursive(ctx);
   test_mtx_timeout_normal(ctx);
   test_mtx_timeout_recursive(ctx);
+  test_mtx_deadlock(ctx);
   test_condition(ctx);
   test_condition_timeout(ctx);
   test_sem(ctx);
@@ -677,15 +658,11 @@ static void test(void)
   test_futex(ctx);
   test_sched();
-  send_event(ctx, 0, EVENT_MTX_DEADLOCK);
   sc = rtems_task_delete(ctx->mid);
   sc = rtems_task_delete(ctx->high[0]);
-#endif
   sc = rtems_task_delete(ctx->high[1]);
@@ -707,6 +684,24 @@ static void Init(rtems_task_argument arg)
   rtems_test_exit(0);
+  bool is_internal,
+  if (
+      && !is_internal
 #define CONFIGURE_MICROSECONDS_PER_TICK US_PER_TICK
@@ -714,7 +709,9 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 4
 #define CONFIGURE_INIT_TASK_PRIORITY 4
 #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
1.8.4.5
