[PATCH v2 5/5] score: Add deadlock detection
Wed Jul 27 05:45:35 UTC 2016
On 27/07/16 06:51, Chris Johns wrote:
>> +#if defined(RTEMS_SMP)
>> + * A global registry of active thread queue links is used to provide
>> deadlock
>> + * detection on SMP configurations.  This is simple to implement and no
>> + * additional storage is required for the thread queues.  The
>> disadvantage is
>> + * that this global registry is not scalable and may lead to lock
>> contention.
>  The disadvantage is the global registry is not scalable ...
>> + * However, the registry is only used in case of nested resource
>> conflicts.  In
>> + * this case, the application is already in trouble.
> How does a user know this or detect there maybe an issue? Is there a
> flag, count or something else kept that says there is a problem and so
> an application problem?
> Writing apps for real-time SMP is something new and difficult and it
> would good to provide users with relevant indications when things are
> not going well.
The deadlock detection is just the first step in implementing the OMIP
protocol. It will get more complex and I guess there will be a
considerable worst-case overhead for applications with complex resource
dependencies. Avoiding complex resource dependencies must be done in the
design phase of the application.
The worst-case run-time is determined by the resource dependency graph.
Once the implementation is done I will add some documentation with the
implementation details. I think this should go into the user manual in a
dedicated section. Its important for the user to know the run-time
complexity of mutex obtain and release operations for example from my
point of view.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
