[PATCH 03/10] arm/raspberrypi: Enable HYP to SVC switch for this BSP.
pisa at cmp.felk.cvut.cz
Mon Jul 4 00:07:07 UTC 2016
This support is required when newer firmware is used on
Raspberry Pi 2 boards.
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 3 +++
c/src/lib/libbsp/arm/raspberrypi/configure.ac | 4 ++++
2 files changed, 7 insertions(+)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index abb6865..c9208d4 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -94,6 +94,9 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
libbsp_a_SOURCES += ../../shared/src/stackalloc.c
libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
+if BSP_START_IN_HYP_SUPPORT
+libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S
+endif
# Startup
libbsp_a_SOURCES += ../../shared/bspreset_loop.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
index 2676bef..ecaee3d 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
+++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
@@ -24,6 +24,10 @@ AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
+RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode])
+AM_CONDITIONAL(BSP_START_IN_HYP_SUPPORT,test "$BSP_START_IN_HYP_SUPPORT" = "1")
RTEMS_BSPOPTS_SET([I2C_IO_MODE],[*],[1])
RTEMS_BSPOPTS_HELP([I2C_IO_MODE],[Define to 1 to use interrupt-driven I/O with the Raspberry Pi I2C bus. If defined to other value the access will be polled-driven.])
1.9.1
