[PATCH 02/10] bsps/arm: Support recent bootloaders starting kernel in HYP mode
Sebastian Huber
Mon Jul 4 05:40:30 UTC 2016
On 04/07/16 01:52, ppisa at cmp.felk.cvut.cz wrote:
> From: Pavel Pisa <pisa at cmp.felk.cvut.cz>
> When HYP mode is detected at startup then setup HYP mode
> vectors table (for future extensions) clean exceptions
> switching to HYP mode and switch CPU to ARM SVC mode.
> BSPs which want to use this support need to include next option
> in their configure.ac
> RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1])
> RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode])
> AM_CONDITIONAL(BSP_START_IN_HYP_SUPPORT,test "$BSP_START_IN_HYP_SUPPORT" = "1")
> and need to include next lines in corresponding Makefile.am
> if BSP_START_IN_HYP_SUPPORT
> libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S
> endif
> .../lib/libbsp/arm/shared/include/linker-symbols.h | 4 ++
> c/src/lib/libbsp/arm/shared/include/start.h | 13 +++-
> c/src/lib/libbsp/arm/shared/start/start.S | 73 +++++++++++++++++++-
> .../arm/shared/startup/bsp-start-in-hyp-support.S | 77 ++++++++++++++++++++++
> c/src/lib/libbsp/arm/shared/startup/linkcmds.base | 9 ++-
> 5 files changed, 170 insertions(+), 6 deletions(-)
> create mode 100644 c/src/lib/libbsp/arm/shared/startup/bsp-start-in-hyp-support.S
> diff --git a/c/src/lib/libbsp/arm/shared/include/linker-symbols.h b/c/src/lib/libbsp/arm/shared/include/linker-symbols.h
> index 7446259..1a996f5 100644
> --- a/c/src/lib/libbsp/arm/shared/include/linker-symbols.h
> +++ b/c/src/lib/libbsp/arm/shared/include/linker-symbols.h
> @@ -59,6 +59,10 @@ LINKER_SYMBOL(bsp_stack_und_begin)
> LINKER_SYMBOL(bsp_stack_und_end)
> LINKER_SYMBOL(bsp_stack_und_size)
> +LINKER_SYMBOL(bsp_stack_hyp_begin)
> +LINKER_SYMBOL(bsp_stack_hyp_end)
> +LINKER_SYMBOL(bsp_stack_hyp_size)
> LINKER_SYMBOL(bsp_stack_svc_begin)
> LINKER_SYMBOL(bsp_stack_svc_end)
> LINKER_SYMBOL(bsp_stack_svc_size)
> diff --git a/c/src/lib/libbsp/arm/shared/include/start.h b/c/src/lib/libbsp/arm/shared/include/start.h
> index f61eed3..bf8eed4 100644
> --- a/c/src/lib/libbsp/arm/shared/include/start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/start.h
> @@ -45,6 +45,15 @@ extern "C" {
> #define BSP_START_DATA_SECTION __attribute__((section(".bsp_start_data")))
> +* Many ARM boot loaders pass arguments to loaded OS kernel
> +#ifdef BSP_START_HOOKS_WITH_LOADER_ARGS
> +#define BSP_START_HOOKS_LOADER_ARGS int saved_psr, int saved_machid, int saved_dtb_adr
> +#else
> +#define BSP_START_HOOKS_LOADER_ARGS void
> +#endif
> * @brief System start entry.
> @@ -57,7 +66,7 @@ void _start(void);
> * stack pointers are initialized but before the copying of the exception
> * vectors.
> -void bsp_start_hook_0(void);
> +void bsp_start_hook_0(BSP_START_HOOKS_LOADER_ARGS);
Do we really need the saved_psr and saved_machid? I think it is
sufficient to pass the DTB address or NULL to bsp_start_hook_0() for all
BSPs. We should avoid this conditional parameter list.
> * @brief Start entry hook 1.
> @@ -65,7 +74,7 @@ void bsp_start_hook_0(void);
> * This hook will be called from the start entry code after copying of the
> * exception vectors but before the call to boot_card().
> -void bsp_start_hook_1(void);
> +void bsp_start_hook_1(BSP_START_HOOKS_LOADER_ARGS);
These parameters are not set up in start.S in this patch.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
