Hint Wanted on Debugging Unexpected Section
Mon Jul 4 18:48:00 UTC 2016
On Mon, Jul 4, 2016 at 1:42 PM, Sebastian Huber <
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > On Mon, Jul 4, 2016 at 1:07 PM, Sebastian Huber <
> > > Hello Joel,
> > > please use the linker command files of the qoriq BSPs as a template on
> > > PowerPC.
> > psim is using the shared linkcmds. Is something wrong with it?
> > What would be the advantage of the qoriq linker script if both are using
> > the shared pattern?
> > Just curious. I was avoiding the cut and pasted ones like the plague. But
> > if there is a second factor, we all should know it.
> Sorry for the noise, the PSIM linkcmds is fine.
No problem. Just wanted to make sure I wasn't missing something.
> > > You can use the linker map file to figure out which sections a the
> trouble
> > > maker (-Wl,-Map,map.txt).
> > Hmm... there were these... any ideas?
> > Thanks.
> > .unexpected_sections
> >                 0x00000000       0xa8
> >  .rela.rtemsroset._Sysinit.content.0.0x00030080
> >                 0x00000000        0xc
> You use probably some GCC flags that no other BSP used up to now.  What
> are your LDFLAGS or CFLAGS?  Do you use PIC or some dynamic relocations?
> Who generates these .rela.rtemsroset.* sections?
This BSP is paravirtualized. All of the provided system libraries are
dynamic (except for the video one). We already have this running on
x86 and I was moving it to ppc. So the environment is a bit different.
I didn't see this on x86.
CFLAGS are normal. The LDFLAGS have these added which are
the same as on x86.
LDFLAGS += -Wl,-Ttext-segment=0x04200000
LDFLAGS += -Wl,-call_shared
LDFLAGS += -Wl,-Bshareable
LDFLAGS += -Wl,-shared
LDFLAGS += -Wl,-export-dynamic
LDFLAGS += -Wl,-no-undefined
LDFLAGS += ${DESKHOME}/ppc/lib/libkernel.so
LDFLAGS += -Wl,--whole-archive
LDFLAGS += ${DESKHOME}/ppc/lib/gcc-4.6.1/libvideo.a
LDFLAGS += -Wl,--no-whole-archive
LDFLAGS += -Wl,-Map,map.txt
Since the unexpected sections appear to be rtems specific, any suggestions
on how to track them down? All I can think of is a brutal hack to check
every object.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160704/1a305dd3/attachment-0002.html>
