[1/6]add ar8031 or ar 8035 phy support
yao0718 29171383 at qq.com
Tue Jul 5 07:14:05 UTC 2016
diff -ruN ./rtems-libbsd/freebsd/sys/dev/mii/atphy.c ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphy.c
--- ./rtems-libbsd/freebsd/sys/dev/mii/atphy.c	1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphy.c	2016-07-05 10:57:44.540734400 +0800
@@ -0,0 +1,378 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2008, Pyun YongHyeon <yongari at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * Driver for the Attansic/Atheros F1 10/100/1000 PHY.
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/socket.h>
+#include <sys/bus.h>
+#include <net/if.h>
+#include <net/if_media.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <rtems/bsd/local/miidevs.h>
+#include <dev/mii/atphyreg.h>
+#include <rtems/bsd/local/miibus_if.h>
+static int atphy_probe(device_t);
+static int atphy_attach(device_t);
+static device_method_t atphy_methods[] = {
+	/* Device interface. */
+	DEVMETHOD(device_probe,		atphy_probe),
+	DEVMETHOD(device_attach,	atphy_attach),
+	DEVMETHOD(device_detach,	mii_phy_detach),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	DEVMETHOD_END
+static devclass_t atphy_devclass;
+static driver_t atphy_driver = {
+	"atphy",
+	atphy_methods,
+	sizeof(struct mii_softc)
+DRIVER_MODULE(atphy, miibus, atphy_driver, atphy_devclass, 0, 0);
+static int	atphy_service(struct mii_softc *, struct mii_data *, int);
+static void	atphy_status(struct mii_softc *);
+static void	atphy_reset(struct mii_softc *);
+static uint16_t	atphy_anar(struct ifmedia_entry *);
+static int	atphy_setmedia(struct mii_softc *, int);
+static const struct mii_phydesc atphys[] = {
+	MII_PHY_DESC(xxATHEROS, F1),
+	MII_PHY_DESC(xxATHEROS, F1_7),
+	MII_PHY_DESC(xxATHEROS, AR8021),
+/*	MII_PHY_DESC(xxATHEROS, AR8035),*/
+	MII_PHY_DESC(xxATHEROS, F2),
+	MII_PHY_END
+static const struct mii_phy_funcs atphy_funcs = {
+	atphy_service,
+	atphy_status,
+	atphy_reset
+static int
+atphy_probe(device_t dev)
+	return (mii_phy_dev_probe(dev, atphys, BUS_PROBE_DEFAULT));
+static int
+atphy_attach(device_t dev)
+	mii_phy_dev_attach(dev, MIIF_NOMANPAUSE, &atphy_funcs, 1);
+	return (0);
+static int
+atphy_service(struct mii_softc *sc, struct mii_data *mii, int cmd)
+	struct ifmedia_entry *ife = mii->mii_media.ifm_cur;
+	uint16_t anar, bmcr, bmsr;
+	switch (cmd) {
+	case MII_POLLSTAT:
+		break;
+	case MII_MEDIACHG:
+		if (IFM_SUBTYPE(ife->ifm_media) == IFM_AUTO ||
+		    IFM_SUBTYPE(ife->ifm_media) == IFM_1000_T) {
+			atphy_setmedia(sc, ife->ifm_media);
+			break;
+		bmcr = 0;
+		switch (IFM_SUBTYPE(ife->ifm_media)) {
+		case IFM_100_TX:
+			bmcr = BMCR_S100;
+			break;
+		case IFM_10_T:
+			bmcr = BMCR_S10;
+			break;
+		case IFM_NONE:
+			bmcr = PHY_READ(sc, MII_BMCR);
+			 * XXX
+			 * Due to an unknown reason powering down PHY resulted
+			 * in unexpected results such as inaccessibility of
+			 * hardware of freshly rebooted system. Disable
+			 * powering down PHY until I got more information for
+			 * Attansic/Atheros PHY hardwares.
+			PHY_WRITE(sc, MII_BMCR, bmcr | BMCR_ISO);
+			goto done;
+		default:
+			return (EINVAL);
+		anar = atphy_anar(ife);
+		if ((ife->ifm_media & IFM_FDX) != 0) {
+			bmcr |= BMCR_FDX;
+			if ((ife->ifm_media & IFM_FLOW) != 0 ||
+			    (sc->mii_flags & MIIF_FORCEPAUSE) != 0)
+				anar |= ANAR_PAUSE_TOWARDS;
+		if ((sc->mii_extcapabilities & (EXTSR_1000TFDX |
+		    EXTSR_1000THDX)) != 0)
+			PHY_WRITE(sc, MII_100T2CR, 0);
+		PHY_WRITE(sc, MII_ANAR, anar | ANAR_CSMA);
+		 * Reset the PHY so all changes take effect.
+		PHY_WRITE(sc, MII_BMCR, bmcr | BMCR_RESET | BMCR_AUTOEN |
+		    BMCR_STARTNEG);
+done:
+		break;
+	case MII_TICK:
+		 * Only used for autonegotiation.
+		if (IFM_SUBTYPE(ife->ifm_media) != IFM_AUTO) {
+			sc->mii_ticks = 0;
+			break;
+		 * Check for link.
+		 * Read the status register twice; BMSR_LINK is latch-low.
+		bmsr = PHY_READ(sc, MII_BMSR) | PHY_READ(sc, MII_BMSR);
+		if (bmsr & BMSR_LINK) {
+			break;
+		/* Announce link loss right after it happens. */
+		if (sc->mii_ticks++ == 0)
+			break;
+		if (sc->mii_ticks <= sc->mii_anegticks)
+			return (0);
+		break;
+	/* Update the media status. */
+	PHY_STATUS(sc);
+	/* Callback if something changed. */
+	mii_phy_update(sc, cmd);
+	return (0);
+static void
+atphy_status(struct mii_softc *sc)
+	struct mii_data *mii = sc->mii_pdata;
+	uint32_t bmsr, bmcr, ssr;
+	mii->mii_media_status = IFM_AVALID;
+	mii->mii_media_active = IFM_ETHER;
+	if ((bmsr & BMSR_LINK) != 0)
+		mii->mii_media_status |= IFM_ACTIVE;
+	if ((bmcr & BMCR_ISO) != 0) {
+		mii->mii_media_active |= IFM_NONE;
+		mii->mii_media_status = 0;
+		return;
+	if ((bmcr & BMCR_LOOP) != 0)
+		mii->mii_media_active |= IFM_LOOP;
+	ssr = PHY_READ(sc, ATPHY_SSR);
+	if ((ssr & ATPHY_SSR_SPD_DPLX_RESOLVED) == 0) {
+		/* Erg, still trying, I guess... */
+		return;
+	switch (ssr & ATPHY_SSR_SPEED_MASK) {
+	case ATPHY_SSR_1000MBS:
+		mii->mii_media_active |= IFM_1000_T;
+		 * atphy(4) has a valid link so reset mii_ticks.
+		 * Resetting mii_ticks is needed in order to
+		 * detect link loss after auto-negotiation.
+		break;
+	case ATPHY_SSR_100MBS:
+		mii->mii_media_active |= IFM_100_TX;
+		break;
+	case ATPHY_SSR_10MBS:
+		mii->mii_media_active |= IFM_10_T;
+		break;
+	default:
+		return;
+	if ((ssr & ATPHY_SSR_DUPLEX) != 0)
+		mii->mii_media_active |= IFM_FDX | mii_phy_flowstatus(sc);
+	else
+		mii->mii_media_active |= IFM_HDX;
+	if ((IFM_SUBTYPE(mii->mii_media_active) == IFM_1000_T) &&
+	    (PHY_READ(sc, MII_100T2SR) & GTSR_MS_RES) != 0)
+		mii->mii_media_active |= IFM_ETH_MASTER;
+static void
+atphy_reset(struct mii_softc *sc)
+	struct ifmedia_entry *ife = sc->mii_pdata->mii_media.ifm_cur;
+	uint32_t reg;
+	int i;
+	//enable rgmii internal delay
+	PHY_WRITE(sc, 0xd, 0x3);
+	PHY_WRITE(sc, 0xe, 0x805d);
+	PHY_WRITE(sc, 0xd, 0x4003);
+	reg = PHY_READ(sc, 0xe);
+	PHY_WRITE(sc, 0xe, reg & ~(1 << 8));
+	PHY_WRITE(sc, 0x1d,5);
+	PHY_WRITE(sc, 0x1e, (1<<8));
+#if 1
+	reg = PHY_READ(sc, ATPHY_SCR);
+	/* Enable automatic crossover. */
+	reg |= ATPHY_SCR_AUTO_X_MODE;
+	/* Disable power down. */
+	reg &= ~ATPHY_SCR_MAC_PDOWN;
+	/* Enable CRS on Tx. */
+	reg |= ATPHY_SCR_ASSERT_CRS_ON_TX;
+	/* Auto correction for reversed cable polarity. */
+	reg |= ATPHY_SCR_POLARITY_REVERSAL;
+	PHY_WRITE(sc, ATPHY_SCR, reg);
+	/* Workaround F1 bug to reset phy. */
+	atphy_setmedia(sc, ife == NULL ? IFM_AUTO : ife->ifm_media);
+	for (i = 0; i < 1000; i++) {
+		DELAY(1);
+		if ((PHY_READ(sc, MII_BMCR) & BMCR_RESET) == 0)
+			break;
+#endif
+static uint16_t
+atphy_anar(struct ifmedia_entry *ife)
+	uint16_t anar;
+	anar = 0;
+	case IFM_AUTO:
+		anar |= ANAR_TX_FD | ANAR_TX | ANAR_10_FD | ANAR_10;
+		return (anar);
+	case IFM_1000_T:
+		return (anar);
+	case IFM_100_TX:
+		anar |= ANAR_TX;
+		break;
+	case IFM_10_T:
+		anar |= ANAR_10;
+		break;
+	default:
+		return (0);
+		if (IFM_SUBTYPE(ife->ifm_media) == IFM_100_TX)
+			anar |= ANAR_TX_FD;
+		else
+			anar |= ANAR_10_FD;
+	return (anar);
+static int
+atphy_setmedia(struct mii_softc *sc, int media)
+	uint16_t anar;
+	anar = BMSR_MEDIA_TO_ANAR(sc->mii_capabilities) | ANAR_CSMA;
+	if ((IFM_SUBTYPE(media) == IFM_AUTO || (media & IFM_FDX) != 0) &&
+	    ((media & IFM_FLOW) != 0 ||
+	    (sc->mii_flags & MIIF_FORCEPAUSE) != 0))
+	PHY_WRITE(sc, MII_ANAR, anar);
+	     (EXTSR_1000TFDX | EXTSR_1000THDX)) != 0)
+		PHY_WRITE(sc, MII_100T2CR, GTCR_ADV_1000TFDX |
+		    GTCR_ADV_1000THDX);
+	else if (sc->mii_mpd_model == MII_MODEL_xxATHEROS_F1) {
+		 * AR8132 has 10/100 PHY and the PHY uses the same
+		 * model number of F1 gigabit PHY.  The PHY has no
+		 * ability to establish gigabit link so explicitly
+		 * disable 1000baseT configuration for the PHY.
+		 * Otherwise, there is a case that atphy(4) could
+		 * not establish a link against gigabit link partner
+		 * unless the link partner supports down-shifting.
+	PHY_WRITE(sc, MII_BMCR, BMCR_RESET | BMCR_AUTOEN | BMCR_STARTNEG);
+	return (EJUSTRETURN);
diff -ruN ./rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h
--- ./rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h	1970-01-01 08:00:00.000000000 +0800
+++ ./am335x_bsp/rtems-libbsd/freebsd/sys/dev/mii/atphyreg.h	2016-03-08 14:27:47.000000000 +0800
@@ -0,0 +1,63 @@
+ * are met:
+ *    disclaimer.
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_DEV_MII_ATPHYREG_H_
+#define	_DEV_MII_ATPHYREG_H_
+ * Registers for the Attansic/Atheros Gigabit PHY.
+/* Special Control Register */
+#define ATPHY_SCR			0x10
+#define ATPHY_SCR_JABBER_DISABLE	0x0001
+#define ATPHY_SCR_POLARITY_REVERSAL	0x0002
+#define ATPHY_SCR_SQE_TEST		0x0004
+#define ATPHY_SCR_MAC_PDOWN		0x0008
+#define ATPHY_SCR_CLK125_DISABLE	0x0010
+#define ATPHY_SCR_MDI_MANUAL_MODE	0x0000
+#define ATPHY_SCR_MDIX_MANUAL_MODE	0x0020
+#define ATPHY_SCR_AUTO_X_1000T		0x0040
+#define ATPHY_SCR_AUTO_X_MODE		0x0060
+#define ATPHY_SCR_10BT_EXT_ENABLE	0x0080
+#define ATPHY_SCR_MII_5BIT_ENABLE	0x0100
+#define ATPHY_SCR_SCRAMBLER_DISABLE	0x0200
+#define ATPHY_SCR_FORCE_LINK_GOOD	0x0400
+#define ATPHY_SCR_ASSERT_CRS_ON_TX	0x0800
+/* Special Status Register. */
+#define ATPHY_SSR			0x11
+#define ATPHY_SSR_SPD_DPLX_RESOLVED	0x0800
+#define ATPHY_SSR_DUPLEX		0x2000
+#define ATPHY_SSR_SPEED_MASK		0xC000
+#define ATPHY_SSR_10MBS			0x0000
+#define ATPHY_SSR_100MBS		0x4000
+#define ATPHY_SSR_1000MBS		0x8000
+#endif	/* _DEV_MII_ATPHYREG_H_ */
------------------ Original ------------------
Date:  Tue, Jul 5, 2016 03:11 PM
To:  "devel"<devel at rtems.org>;
Subject:  [0/6] ti cpsw driver port from freebsd for am335x
I add cpsw driver from freebsd and modify some code for my board, my board is not beagleblack, so i am not sure it can work fine in BB board,to reduce phy find process, I  set phy address 4 and 6 for which phy address on my board,my board has two eth port ,I set dualmac when attach;
can somebody test it on beaglebone and merge to beaglebone  bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160705/283446f1/attachment-0002.html>
