I2C testcase linking error
Ben Gras beng at shrike-systems.com
Sun Jul 24 18:22:36 UTC 2016
All,
Aha, I see the problem indeed.
From the output I conclude default-configuration.o is providing symbols
that conflict with your configuration symbols. This suggests
default-configuration.o is pulled in to satisfy some configuration
requirement. This suggests we should put more info in init.c.
I found a small change from your init.c that seems to "fix" this problem:
-#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_FILESYSTEM_IMFS
I guess DEVFS is too limited to support the I2C subsystem but I didn't
go so deep as to find out what the ins and outs are once I saw this does
link :-)
On 24-07-16 09:06, punit vara wrote:
> https://github.com/punitvara/rtems/tree/new
> You can reproduce linking error from this  new branch.
> On Sat, Jul 23, 2016 at 11:57 PM, Ben Gras <beng at shrike-systems.com
> <mailto:beng at shrike-systems.com>> wrote:
>     All,
>     I tried to reproduce this. The I2C branch of your repo doesn't build
>     because of struct i2c not being defined. So I #if 0'd out all the
>     function bodies in i2c.c, and then everything builds, without
>     linker errors.
>     What is your state now? Are you blocked on this (or anything else)
>     still? If so, can you help me reproduce, e.g. by creating a branch
>     that
>     definitely exhibits the problem?
>     I did build from scratch, if you have linking problems it may be
>     an idea
>     to rm -rf the beagle build dir and reconfigure and rebuild, in case
>     there is a library hanging around with an extra object file it isn't
>     supposed to have that the buildsystem isn't updating.
>     Cheers,
>     Ben
>     On 22-07-16 14:26, punit vara wrote:
>     /root/development/rtems/b-NEW/arm-rtems4.12/c/beagleboneblack/cpukit/libmisc/../../../../../../../../NEW/c/src/../../cpukit/libmisc/dummy/default-configuration.c:23:
>     > multiple definition of
>     > `_Linker_set__Sysinit__RTEMS_tasks_Initialize_user_tasks_body'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160724/db7b56cf/attachment-0002.html>
