[PATCH 3/3] libchip/network: Fix printk warnings.
Wed Jun 1 05:22:18 UTC 2016
On 31/05/16 23:34, Chris Johns wrote:
> On 31/05/2016 18:14, Sebastian Huber wrote:
>> Oh, I forgot to remove this driver. It is now located in the libbsd. I
>> will remove it.
> Is this driver in the legacy stack not working? What about leaving it
> if it works and remove it when the stack is removed from rtems.git
> which will be after 4.12 is released?
It worked only on the Altera Cyclone V BSPs, but with much worse
stability and performance compared to the FreeBSD driver.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
