[PATCH 3/3] libchip/network: Fix printk warnings.
Wed Jun 1 05:40:18 UTC 2016
On 01/06/2016 15:22, Sebastian Huber wrote:
> On 31/05/16 23:34, Chris Johns wrote:
>> On 31/05/2016 18:14, Sebastian Huber wrote:
>>> Oh, I forgot to remove this driver. It is now located in the libbsd. I
>>> will remove it.
>> Is this driver in the legacy stack not working? What about leaving it
>> if it works and remove it when the stack is removed from rtems.git
>> which will be after 4.12 is released?
> It worked only on the Altera Cyclone V BSPs, but with much worse
> stability and performance compared to the FreeBSD driver.
Ah ok, this makes sense. Thanks.
