RTEMS BSD Net on Atmel SAM Board
Isaac Gutekunst isaac.gutekunst at vecna.com
Wed Jun 1 15:46:22 UTC 2016
Hi All,
I'm trying to bring up tHE Atmel SAMV71 Explained Ultra board with networking, and can't figure out how to. Does anyone have any quick pointers?
Isaac
To limit potential email traffic, this is my setup as of now:
I've compiled the BSP with --enable-networking, verified by sprinkling #error messages in the generated header files that it really was compiled with --enable-networkinG.
I've copied the following from the networking supplement:
static struct rtems_bsdnet_ifconfig netdriver_config = {
   RTEMS_BSP_NETWORK_DRIVER_NAME,
   RTEMS_BSP_NETWORK_DRIVER_ATTACH
struct rtems_bsdnet_config rtems_bsdnet_config = {
   &netdriver_config,
   NULL,
In Init, I call
rtems_bsdnet_initialize_network ();
My overall configuration #defines are as follows:
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS   64
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK    512
#define CONFIGURE_MAXIMUM_DRIVERS                  20
#define CONFIGURE_SWAPOUT_TASK_PRIORITY            2
#define CONFIGURE_INIT_TASK_STACK_SIZE           RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_EXTRA_TASK_STACKS              RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS                  rtems_resource_unlimited (20)
#define CONFIGURE_MAXIMUM_BARRIERS               rtems_resource_unlimited (10)
#define CONFIGURE_MAXIMUM_SEMAPHORES             rtems_resource_unlimited (20)
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES         rtems_resource_unlimited (4)
#define CONFIGURE_MAXIMUM_PARTITIONS             rtems_resource_unlimited (2)
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS            8
#define CONFIGURE_MAXIMUM_TIMERS                     8
#define CONFIGURE_UNIFIED_WORK_AREAS
#if 1
#define CONFIGURE_MAXIMUM_POSIX_KEYS                 16
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS      16
#define CONFIGURE_MAXIMUM_POSIX_THREADS              10
#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES  20
#define CONFIGURE_MAXIMUM_POSIX_MUTEXES              40
#endif
#define CONFIGURE_MICROSECONDS_PER_TICK              1000
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK 1
#include <rtems/confdefs.h>
#include <rtems/shell.h>
#define CONFIGURE_SHELL_COMMANDS_INIT
#define CONFIGURE_SHELL_COMMANDS_ALL
#include <rtems/shellconfig.h>
