RTEMS BSD Net on Atmel SAM Board
Isaac Gutekunst isaac.gutekunst at vecna.com
Wed Jun 1 21:09:39 UTC 2016
I believe I solved all my problems. Not enough memory. After updating the linker script to use SDRAM, everything appears to be working well! (Knock on wood).
I've also been reminded that the ping shell command has a memory leak. It expects the kernel to free up memory after the command exits. It also appears as if doing
a ping -i .001 quickly swamps the system. I feel that it's also running out of memory. I'll look into it more tomorrow.
Consider my Ethernet woes solved for now. I'm still curious about these memory leaks in ping though.
Isaac
On 06/01/2016 02:06 PM, Isaac Gutekunst wrote:
> A brief update: I've updated my configuration from a different example to be a bit more complete. It looks like it can't communicate with the PHY.
> #if (defined (RTEMS_SET_ETHERNET_ADDRESS))
>   static char ethernet_address[6] = { 0x00, 0x04, 0x9F, 0x00, 0x5B, 0x21 };
> #endif
> static struct rtems_bsdnet_ifconfig netdriver_config = {
>         RTEMS_BSP_NETWORK_DRIVER_NAME,          /* name */
>         RTEMS_BSP_NETWORK_DRIVER_ATTACH,        /* attach function */
>         NULL,                           /* No more interfaces */
> #if (defined (RTEMS_USE_BOOTP))
>         NULL,                           /* BOOTP supplies IP address */
>         NULL,                           /* BOOTP supplies IP net mask */
> #else
>         "192.168.0.140",                /* IP address */
>         "255.255.255.0",                /* IP net mask */
> #endif /* !RTEMS_USE_BOOTP */
>         ethernet_address,               /* Ethernet hardware address */
> #else
>         NULL,                           /* Driver supplies hardware address */
> #endif
>         0,                              /* Use default driver parameters */
>         0,                              /* mtu */
>         0,                              /* rbuf_count */
>         0,                              /* xbuf_count */
>         0,                              /* port */
>         39                               /* irq */
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>         &netdriver_config,
>         NULL,
>         0,                              /* Default network task priority */
>         16 * 1024,                     /* Default mbuf capacity */
>         16 * 1024,                     /* Default mbuf cluster capacity */
>         "rtems",                /* Host name */
>         "nodomain.com",         /* Domain name */
>         "192.168.0.14",         /* Gateway */
>         "192.168.0.1",          /* Log host */
>         {"192.168.0.1"  },      /* Name server(s) */
>         {"192.168.0.1"  },      /* NTP server(s) */
>         0,                      /* efficiency */
>         0,                      /* udp TX buffer */
>         0,                      /* udp RX buffer */
>         0,                      /* tcp TX buffer */
>         0,                      /* tcp RX buffer */
> I also added the network shell commands and can ping myself on 192.168.0.140. ifconfig atsamv0 shows:
> ***** atsam0 *****
> Ethernet Address: 48:11:40:20:45:01
> Address:192.168.0.140   Broadcast Address:192.168.0.255   Net mask:255.255.255.0
> Flags: Up Broadcast Running Simplex Multicast
> Send queue limit:50   length:0    Dropped:0
> -E- TimeOut ReadPhy
> This matches the slow blinking of both LEDs at about 0.5Hz.
> Isaac
> On 06/01/2016 11:46 AM, Isaac Gutekunst wrote:
>> Hi All,
>> I'm trying to bring up tHE Atmel SAMV71 Explained Ultra board with networking, and can't figure out how to. Does anyone have any quick pointers?
>> Isaac
>> To limit potential email traffic, this is my setup as of now:
>> I've compiled the BSP with --enable-networking, verified by sprinkling #error messages in the generated header files that it really was compiled with --enable-networkinG.
>> I've copied the following from the networking supplement:
>>   &netdriver_config,
>>   NULL,
>> In Init, I call
>> rtems_bsdnet_initialize_network ();
>> My overall configuration #defines are as follows:
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS   64
>> #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK    512
>> #define CONFIGURE_MAXIMUM_DRIVERS                  20
>> #define CONFIGURE_SWAPOUT_TASK_PRIORITY            2
>> #define CONFIGURE_INIT_TASK_STACK_SIZE           RTEMS_MINIMUM_STACK_SIZE
>> #define CONFIGURE_EXTRA_TASK_STACKS              RTEMS_MINIMUM_STACK_SIZE
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_MAXIMUM_TASKS                  rtems_resource_unlimited (20)
>> #define CONFIGURE_MAXIMUM_BARRIERS               rtems_resource_unlimited (10)
>> #define CONFIGURE_MAXIMUM_SEMAPHORES             rtems_resource_unlimited (20)
>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES         rtems_resource_unlimited (4)
>> #define CONFIGURE_MAXIMUM_PARTITIONS             rtems_resource_unlimited (2)
>> #define CONFIGURE_MAXIMUM_USER_EXTENSIONS            8
>> #define CONFIGURE_MAXIMUM_TIMERS                     8
>> #define CONFIGURE_UNIFIED_WORK_AREAS
>> #if 1
>> #define CONFIGURE_MAXIMUM_POSIX_KEYS                 16
>> #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS      16
>> #define CONFIGURE_MAXIMUM_POSIX_THREADS              10
>> #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES  20
>> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES              40
>> #endif
>> #define CONFIGURE_MICROSECONDS_PER_TICK              1000
>> #define CONFIGURE_UNLIMITED_OBJECTS
>> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK 1
>> #include <rtems/confdefs.h>
>> #include <rtems/shell.h>
>> #define CONFIGURE_SHELL_COMMANDS_INIT
>> #define CONFIGURE_SHELL_COMMANDS_ALL
>> #include <rtems/shellconfig.h>
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
