[PATCH] rtems: Fix no protocol mutex release
Fri Jun 3 06:18:54 UTC 2016
The Classic binary semaphores without a locking protocol could be
released by everyone, e.g. in contrast to the POSIX mutexes (all
variants) or the Classic binary semphores with priority inheritance or
ceiling there was no owner check in the release path.
This behaviour was a bit unexpected and not documented.   Add an owner
check to the release path.  Update sptests/sp42 accordingly.
Close #2725
 cpukit/rtems/src/semrelease.c                    |   3 +-
 cpukit/score/include/rtems/score/coremuteximpl.h |  54 +++--------
 testsuites/sptests/sp42/init.c                   | 109 ++++++++++++++---------
 testsuites/sptests/sp42/sp42.scn                 |   4 +-
 4 files changed, 84 insertions(+), 86 deletions(-)
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index ccd4e63..39c467d 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -64,9 +64,10 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
       break;
     case SEMAPHORE_VARIANT_MUTEX_NO_PROTOCOL:
-      _CORE_recursive_mutex_Surrender_no_protocol_classic(
+      _CORE_recursive_mutex_Surrender_no_protocol(
         &the_semaphore->Core_control.Mutex.Recursive,
         _Semaphore_Get_operations( the_semaphore ),
+        executing,
         &queue_context
       status = STATUS_SUCCESSFUL;
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index decf770..956dfa8 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -311,22 +311,29 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_no_protocol(
-RTEMS_INLINE_ROUTINE void
-_CORE_recursive_mutex_Surrender_no_protocol_finalize(
+RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender_no_protocol(
   CORE_recursive_mutex_Control  *the_mutex,
   const Thread_queue_Operations *operations,
+  Thread_Control                *executing,
   Thread_queue_Context          *queue_context
   unsigned int    nest_level;
   Thread_Control *new_owner;
+  _CORE_mutex_Acquire_critical( &the_mutex->Mutex, queue_context );
+  if ( !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing ) ) {
+    _CORE_mutex_Release( &the_mutex->Mutex, queue_context );
+    return STATUS_NOT_OWNER;
   nest_level = the_mutex->nest_level;
   if ( nest_level > 0 ) {
     the_mutex->nest_level = nest_level - 1;
-    return;
+    return STATUS_SUCCESSFUL;
   new_owner = _Thread_queue_First_locked(
@@ -337,7 +344,7 @@ _CORE_recursive_mutex_Surrender_no_protocol_finalize(
   if ( new_owner == NULL ) {
-    return;
   _Thread_queue_Extract_critical(
@@ -346,48 +353,9 @@ _CORE_recursive_mutex_Surrender_no_protocol_finalize(
     new_owner,
     queue_context
-RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender_no_protocol(
-  CORE_recursive_mutex_Control  *the_mutex,
-  const Thread_queue_Operations *operations,
-  Thread_Control                *executing,
-  Thread_queue_Context          *queue_context
-  _CORE_mutex_Acquire_critical( &the_mutex->Mutex, queue_context );
-  if ( !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing ) ) {
-    _CORE_mutex_Release( &the_mutex->Mutex, queue_context );
-    return STATUS_NOT_OWNER;
-  _CORE_recursive_mutex_Surrender_no_protocol_finalize(
-    the_mutex,
-    operations,
-    queue_context
- * The Classic no protocol recursive mutex has the nice property that everyone
- * can release it.
-RTEMS_INLINE_ROUTINE void _CORE_recursive_mutex_Surrender_no_protocol_classic(
-    the_mutex,
-    operations,
-    queue_context
 RTEMS_INLINE_ROUTINE void _CORE_ceiling_mutex_Initialize(
   CORE_ceiling_mutex_Control *the_mutex,
   Priority_Control            priority_ceiling
diff --git a/testsuites/sptests/sp42/init.c b/testsuites/sptests/sp42/init.c
index 55faa9b..6d96ede 100644
--- a/testsuites/sptests/sp42/init.c
+++ b/testsuites/sptests/sp42/init.c
@@ -24,19 +24,12 @@ const char rtems_test_name[] = "SP 42";
 #define MAX_TASKS 20
-rtems_task Init(rtems_task_argument argument);
-rtems_task Locker_task(rtems_task_argument unused);
-void do_test(
-  rtems_attribute attr,
-  bool            extract  /* TRUE if extract, not release */
  * Carefully chosen to exercise threadq enqueue/dequeue priority logic.
  * Somewhat randomly sorted to ensure than if discipline is FIFO, run-time
  * behavior won't be the same when released.
-rtems_task_priority Priorities_High[MAX_TASKS] = {
+static const rtems_task_priority Priorities_High[MAX_TASKS] = {
   37, 37, 37, 37,       /* backward - more 2-n */
   2, 2, 2, 2,           /* forward - multiple are on 2-n chain */
   4, 3,                 /* forward - search forward arbitrary */
@@ -45,7 +38,7 @@ rtems_task_priority Priorities_High[MAX_TASKS] = {
   34, 34, 34, 34,       /* backward - multple on 2-n chain */
-rtems_task_priority Priorities_Low[MAX_TASKS] = {
+static const rtems_task_priority Priorities_Low[MAX_TASKS] = {
   13, 13, 13, 13,       /* backward - more 2-n */
@@ -54,24 +47,37 @@ rtems_task_priority Priorities_Low[MAX_TASKS] = {
   12, 12, 12, 12,       /* backward - multple on 2-n chain */
-rtems_task_priority *Priorities;
+static const int Obtain_order[2][MAX_TASKS] = {
+  { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19 },
+  { 4, 5, 6, 7, 9, 10, 11, 12, 13, 8, 16, 17, 18, 19, 0, 1, 2, 3, 15, 14 }
+static const rtems_task_priority *Priorities;
+static rtems_id   Semaphore;
+static rtems_id   Master;
+static rtems_id   Task_id[ MAX_TASKS ];
+static rtems_name Task_name[ MAX_TASKS ];
+static rtems_task_argument Obtain_counter;
-rtems_id   Semaphore;
-rtems_id   Task_id[ MAX_TASKS ];
-rtems_name Task_name[ MAX_TASKS ];
+static enum {
+ FIFO,
+ PRIORITY
+} Variant;
-  rtems_task_argument unused
+static rtems_task Locker_task(
+  rtems_task_argument task_index
-  rtems_id          tid;
-  uint32_t          task_index;
-  rtems_status_code status;
+  rtems_id            tid;
+  rtems_status_code   status;
+  rtems_task_argument my_obtain_counter;
   status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
   directive_failed( status, "rtems_task_ident" );
-  task_index = task_number( tid ) - 1;
+  rtems_test_assert( task_index == task_number( tid ) - 1 );
   status = rtems_semaphore_obtain( Semaphore, RTEMS_DEFAULT_OPTIONS, 0 );
   directive_failed( status, "rtems_semaphore_obtain" );
@@ -79,28 +85,45 @@ rtems_task Locker_task(
   put_name( Task_name[ task_index ], FALSE );
   puts( " - unblocked - OK" );
+  status = rtems_task_wake_after( 10 );
+  directive_failed( status, "rtems_task_wake_after" );
+  my_obtain_counter = Obtain_counter;
+  rtems_test_assert( task_index == Obtain_order[ Variant ][ Obtain_counter ] );
+  ++Obtain_counter;
+  status = rtems_semaphore_release( Semaphore );
+  directive_failed( status, "rtems_semaphore_release" );
+  if ( my_obtain_counter == MAX_TASKS - 1 ) {
+    status = rtems_event_transient_send( Master );
+    directive_failed( status, "rtems_event_transient_send" );
   (void) rtems_task_delete( RTEMS_SELF );
-void do_test(
+static void do_test(
-  int               i;
+  rtems_task_argument i;
+  Variant = ( ( attr & RTEMS_PRIORITY ) != 0 ? PRIORITY : FIFO );
+  Obtain_counter = 0;
   status = rtems_semaphore_create(
     rtems_build_name( 'S', 'E', 'M', '0' ),  /* name = SEM0 */
-    0,                                       /* unlocked */
+    0,                                       /* locked */
     RTEMS_BINARY_SEMAPHORE | attr,           /* mutex w/desired discipline */
     0,                                       /* IGNORED */
     &Semaphore
   directive_failed( status, "rtems_semaphore_create" );
-  for (i=0 ; i< MAX_TASKS ; i++ ) {
+  for (i = 0 ; i < MAX_TASKS ; i++ ) {
     Task_name[ i ] = rtems_build_name(
        'T',
        'A',
@@ -118,42 +141,42 @@ void do_test(
     directive_failed( status, "rtems_task_create" );
-    status = rtems_task_start(
-      Task_id[ i ], Locker_task, (rtems_task_argument)i );
+    status = rtems_task_start( Task_id[ i ], Locker_task, i );
     directive_failed( status, "rtems_task_start" );
-    status = rtems_task_wake_after( 10 );
-    directive_failed( status, "rtems_task_wake_after" );
-    if ( extract == FALSE ) {
-      status = rtems_semaphore_release( Semaphore );
-      directive_failed( status, "rtems_semaphore_release" );
-      status = rtems_task_wake_after( 100 );
-    } else {
+  if ( extract ) {
+    for (i = 0 ; i< MAX_TASKS ; i++ ) {
       status = rtems_task_delete( Task_id[ i ]  );
       directive_failed( status, "rtems_task_delete" );
-  /* one extra release for the initial state */
+  /* do the initial release */
+  if ( !extract ) {
+    status = rtems_event_transient_receive( RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+    directive_failed( status, "rtems_event_transient_receive" );
   /* now delete the semaphore since no one is waiting and it is unlocked */
   status = rtems_semaphore_delete( Semaphore );
   directive_failed( status, "rtems_semaphore_delete" );
-rtems_task Init(
+static rtems_task Init(
+  rtems_task_priority prio;
   TEST_BEGIN();
+  Master = rtems_task_self();
   if (RTEMS_MAXIMUM_PRIORITY == 255)
     Priorities = Priorities_High;
   else if (RTEMS_MAXIMUM_PRIORITY == 15)
@@ -163,6 +186,10 @@ rtems_task Init(
     rtems_test_exit( 0 );
+  prio = RTEMS_MAXIMUM_PRIORITY - 1;
+  status = rtems_task_set_priority(RTEMS_SELF, prio, &prio);
+  directive_failed( status, "rtems_task_set_priority" );
   if ( sizeof(Priorities_Low) / sizeof(rtems_task_priority) != MAX_TASKS ) {
     puts( "Priorities_Low table does not have right number of entries" );
@@ -201,6 +228,8 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS             MAX_TASKS+1
 #define CONFIGURE_MAXIMUM_SEMAPHORES        1
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/sp42/sp42.scn b/testsuites/sptests/sp42/sp42.scn
index 01adcf7..206d05c 100644
--- a/testsuites/sptests/sp42/sp42.scn
+++ b/testsuites/sptests/sp42/sp42.scn
@@ -1,4 +1,4 @@
-*** START OF TEST 42 ***
+*** BEGIN OF TEST SP 42 ***
 Exercising blocking discipline w/extract in FIFO order
 Exercising blocking discipline w/unblock in FIFO order
 TA00 - unblocked - OK
@@ -44,4 +44,4 @@ TA02 - unblocked - OK
 TA03 - unblocked - OK
 TA15 - unblocked - OK
 TA14 - unblocked - OK
-*** END OF TEST 42 ***
+*** END OF TEST SP 42 ***
1.8.4.5
