Errors while building USB DWC OTG driver
Jan Sommer soja-lists at aries.uberspace.de
Fri Jun 3 10:01:03 UTC 2016
Am 2016-06-03 11:37, schrieb Deval Shah:
> Now for the debugging what are the methods with qemu? As in how to get
> step
> by step analysis of the running program ?
If you run qemu with the options -s -S it will break at the beginning of
the program and allow a gdb connection.
You can then connect to qemu from within gdb with "target remote :1234"
and debug the programm as usual.
Best regards,
    Jan
> Thank you,
> Deval Shah
> On Fri, Jun 3, 2016 at 1:50 PM, Deval Shah <deval.maker at gmail.com>
> wrote:
>> Hello,
>> I was going through last years mailing list for debugging the issue. I
>> found this
>> https://lists.rtems.org/pipermail/devel/2015-June/011741.html.
>> Can someone explain how to get the linker map file ?
>> On Wed, Jun 1, 2016 at 11:01 AM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello Deval,
>>> I would use a hardware debugger or Qemu to tackle this problem.
>>> On 31/05/16 19:32, Deval Shah wrote:
>>>> Hello,
>>>> I have managed to resolve previous errors and the driver is finally
>>>> building. I want to test this on hardware now. I tried running
>>>> "USB01"
>>>> testsuit for this. But I could not see any output on minicom.
>>>> Is there any debug flag/macro which I can turn on in order to get
>>>> all
>>>> the error log? Or any other debug method for raspberry pi hardware ?
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
