[PATCH] mghttpd: Add RTEMS printer support
Sebastian Huber
Fri Jun 3 12:58:44 UTC 2016
cpukit/include/rtems/print.h | 4 ++--
cpukit/mghttpd/mongoose.c | 12 ++++++++++++
cpukit/mghttpd/mongoose.h | 4 ++++
3 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/print.h b/cpukit/include/rtems/print.h
index 5268e8c..91c4515 100644
--- a/cpukit/include/rtems/print.h
+++ b/cpukit/include/rtems/print.h
@@ -39,10 +39,10 @@ extern "C" {
* Type definition for the printer structure used to access the kernel print
* support.
-typedef struct {
+typedef struct rtems_printer {
void *context;
rtems_print_plugin_t printer;
-}rtems_printer;
+} rtems_printer;
* @brief check if the printer is valid.
diff --git a/cpukit/mghttpd/mongoose.c b/cpukit/mghttpd/mongoose.c
index dd243d3..a89fc56 100644
--- a/cpukit/mghttpd/mongoose.c
+++ b/cpukit/mghttpd/mongoose.c
@@ -5519,3 +5519,15 @@ struct mg_context *mg_start(const struct mg_callbacks *callbacks,
return ctx;
+#ifdef __rtems__
+#include <rtems/print.h>
+static int mg_printer_plugin(void *context, const char *fmt, va_list ap) {
+ return mg_vprintf(context, fmt, ap);
+void rtems_print_printer_mg_printf(rtems_printer *printer, struct mg_connection *conn) {
+ printer->context = conn;
+ printer->printer = mg_printer_plugin;
+#endif /* __rtems__ */
diff --git a/cpukit/mghttpd/mongoose.h b/cpukit/mghttpd/mongoose.h
index ad7c40f..330ed67 100644
--- a/cpukit/mghttpd/mongoose.h
+++ b/cpukit/mghttpd/mongoose.h
@@ -256,6 +256,10 @@ enum {
// Works exactly like mg_write(), but allows to do message formatting.
int mg_printf(struct mg_connection *,
PRINTF_FORMAT_STRING(const char *fmt), ...) PRINTF_ARGS(2, 3);
+#ifdef __rtems__
+struct rtems_printer;
+void rtems_print_printer_mg_printf(struct rtems_printer *, struct mg_connection *);
// Send contents of the entire file together with HTTP headers.
1.8.4.5
