[PATCH v2] rtems: Fix no protocol mutex release
Mon Jun 6 22:07:20 UTC 2016
On 06/06/2016 19:57, Sebastian Huber wrote:
> On 04/06/16 08:16, Chris Johns wrote:
>> On 03/06/2016 23:44, Sebastian Huber wrote:
>>> On 03/06/16 15:40, Joel Sherrill wrote:
>>>> My concern is that this will break existing programs that used them for
>>>> condition synchronization.
>>> These applications are broken since you can obtain the
>>> RTEMS_BINARY_SEMAPHORE recursively.
>> Did you check if there are any cases in the rtems source?
> A pure RTEMS_BINARY_SEMAPHORE is almost always a bug if you use a
> priority based scheduler. Interestingly, several parts in RTEMS used
> such a thing.
> https://devel.rtems.org/ticket/1452
> https://devel.rtems.org/ticket/2726
> https://devel.rtems.org/ticket/2727
> https://devel.rtems.org/ticket/2728
> https://devel.rtems.org/ticket/2729
Thanks for checking and fixing these.
