BSP Console Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Tue Jun 7 18:47:45 UTC 2016
Hi,
I have been able to build my new BSP and currently trying run HelloWorld
with OpenOCD and gdb.
Following is the error message I'm getting when I run hello.exe and not
sure how to debug this error.
Any idea about this issue and how to debug it?
#0 0x000047ee in _Terminate (
the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
is_internal=is_internal at entry=false, the_error=536874968)
at
../../../../../../../rtems.git/c/src/../../cpukit/score/src/interr.c:52
#1 0x00003d16 in rtems_fatal (
source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
error=<optimized out>)
at
../../../../../../../rtems.git/c/src/../../cpukit/sapi/src/fatal2.c:34
#2 0x0000786e in _ARM_Exception_default (frame=<optimized out>)
at
../../../../../../../../../rtems.git/c/src/../../cpukit/score/cpu/arm/arm-exception-default.c:24
#3 <signal handler called>
#4 0x00000000 in bsp_start_vector_table_begin ()
#5 0x0000f2d0 in _Linker_set__Sysinit_rtems_libio_post_driver ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Regards,
Habeeb
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160607/dc3cbdaf/attachment.html>
