[PATCH 1/8] score: Delete dead copy and paste code
Wed Jun 8 13:57:57 UTC 2016
 cpukit/score/cpu/bfin/rtems/score/cpu.h     | 136 --------------------------
 cpukit/score/cpu/epiphany/rtems/score/cpu.h |  99 +------------------
 cpukit/score/cpu/lm32/rtems/score/cpu.h     | 135 --------------------------
 cpukit/score/cpu/m32c/rtems/score/cpu.h     | 134 --------------------------
 cpukit/score/cpu/mips/rtems/score/cpu.h     |  98 +------------------
 cpukit/score/cpu/moxie/rtems/score/cpu.h    | 107 +--------------------
 cpukit/score/cpu/or1k/rtems/score/cpu.h     | 105 +-------------------
 cpukit/score/cpu/sh/cpu.c                   |   8 --
 cpukit/score/cpu/sh/rtems/score/cpu.h       | 104 +-------------------
 cpukit/score/cpu/v850/rtems/score/cpu.h     | 143 ----------------------------
 10 files changed, 5 insertions(+), 1064 deletions(-)
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index e4ad87f..1bff479 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -849,146 +849,10 @@ void _CPU_Context_Initialize(
 /* end of Fatal Error manager macros */
-/* Bitfield handler macros */
- * @defgroup CPUBitfield Processor Dependent Bitfield Manipulation
- * This set of routines are used to implement fast searches for
- * the most important ready task.
- * This definition is set to TRUE if the port uses the generic bitfield
- * manipulation implementation.
 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
- * This definition is set to TRUE if the port uses the data tables provided
- * by the generic bitfield manipulation implementation.
- * This can occur when actually using the generic bitfield manipulation
- * implementation or when implementing the same algorithm in assembly
- * language for improved performance.  It is unlikely that a port will use
- * the data if it has a bitfield scan instruction.
 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
- * This routine sets @a _output to the bit number of the first bit
- * set in @a _value.  @a _value is of CPU dependent type
- * @a Priority_bit_map_Word.  This type may be either 16 or 32 bits
- * wide although only the 16 least significant bits will be used.
- * There are a number of variables in using a "find first bit" type
- * instruction.
- *   -# What happens when run on a value of zero?
- *   -# Bits may be numbered from MSB to LSB or vice-versa.
- *   -# The numbering may be zero or one based.
- *   -# The "find first bit" instruction may search from MSB or LSB.
- * RTEMS guarantees that (1) will never happen so it is not a concern.
- * (2),(3), (4) are handled by the macros @ref _CPU_Priority_Mask and
- * @ref _CPU_Priority_bits_index.  These three form a set of routines
- * which must logically operate together.  Bits in the _value are
- * set and cleared based on masks built by @ref _CPU_Priority_Mask.
- * The basic major and minor values calculated by @ref _Priority_Major
- * and @ref _Priority_Minor are "massaged" by @ref _CPU_Priority_bits_index
- * to properly range between the values returned by the "find first bit"
- * instruction.  This makes it possible for @ref _Priority_Get_highest to
- * calculate the major and directly index into the minor table.
- * This mapping is necessary to ensure that 0 (a high priority major/minor)
- * is the first bit found.
- * This entire "find first bit" and mapping process depends heavily
- * on the manner in which a priority is broken into a major and minor
- * components with the major being the 4 MSB of a priority and minor
- * the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
- * priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
- * to the lowest priority.
- * If your CPU does not have a "find first bit" instruction, then
- * there are ways to make do without it.  Here are a handful of ways
- * to implement this in software:
- at verbatim
-      - a series of 16 bit test instructions
-      - a "binary search using if's"
-      - _number = 0
-        if _value > 0x00ff
-          _value >>=8
-          _number = 8;
-        if _value > 0x0000f
-          _value >=8
-          _number += 4
-        _number += bit_set_table[ _value ]
- at endverbatim
- *   where bit_set_table[ 16 ] has values which indicate the first
- *     bit set
- * @param[in] _value is the value to be scanned
- * @param[in] _output is the first bit set
- * Port Specific Information:
- * XXX document implementation including references if appropriate
-#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
-#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
-    __asm__ ("bit(1);"):
-    (_output) = 0;   /* do something to prevent warnings */ \
-#endif
-/* end of Bitfield handler macros */
- * This routine builds the mask which corresponds to the bit fields
- * as searched by @ref _CPU_Bitfield_Find_first_bit.  See the discussion
- * for that routine.
-#define _CPU_Priority_Mask( _bit_number ) \
-  ( 1 << (_bit_number) )
-#endif
- * @ingroup CPUBitfield
- * This routine translates the bit numbers returned by
- * @ref _CPU_Bitfield_Find_first_bit into something suitable for use as
- * a major or minor component of a priority.  See the discussion
- * @param[in] _priority is the major or minor number to translate
-#define _CPU_Priority_bits_index( _priority ) \
-  (_priority)
-#endif
-/* end of Priority handler macros */
 /* functions */
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index e433e19..c59e54f 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -678,106 +678,9 @@ void _CPU_Context_Initialize(
- *  This routine sets _output to the bit number of the first bit
- *  set in _value.  _value is of CPU dependent type Priority_Bit_map_control.
- *  This type may be either 16 or 32 bits wide although only the 16
- *  least significant bits will be used.
- *  instruction.
- *    (1) What happens when run on a value of zero?
- *    (2) Bits may be numbered from MSB to LSB or vice-versa.
- *    (3) The numbering may be zero or one based.
- *    (4) The "find first bit" instruction may search from MSB or LSB.
- *  (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
- *  _CPU_Priority_bits_index().  These three form a set of routines
- *  set and cleared based on masks built by _CPU_Priority_mask().
- *  The basic major and minor values calculated by _Priority_Major()
- *  and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
- *  instruction.  This makes it possible for _Priority_Get_highest() to
- *    - a series of 16 bit test instructions
- *    - a "binary search using if's"
- *    - _number = 0
- *      if _value > 0x00ff
- *        _value >>=8
- *        _number = 8;
- *      if _value > 0x0000f
- *        _value >=8
- *        _number += 4
- *      _number += bit_set_table[ _value ]
- *      bit set
-  /* #define CPU_USE_GENERIC_BITFIELD_CODE FALSE */
-#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
-#endif
- *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
-    (1 << _bit_number)
-#endif
- *  _CPU_Bitfield_Find_first_bit() into something suitable for use as
-  (_priority)
-#endif
+#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
 typedef struct {
 /* There is no CPU specific per-CPU state */
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 1a22da8..325a8a4 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -881,145 +881,10 @@ extern char _gp[];
- * instruction.
- at verbatim
-      - _number = 0
-          _value >>=8
-          _number = 8;
-          _value >=8
-          _number += 4
- at endverbatim
- *     bit set
-#endif
-#endif
-  (_priority)
-#endif
 /* functions */
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index de0ead5..f980abc 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -869,144 +869,10 @@ void _CPU_Context_Restart_self(
- * instruction.
- at verbatim
-      - _number = 0
-          _value >>=8
-          _number = 8;
-          _value >=8
-          _number += 4
- at endverbatim
- *     bit set
-#endif
-#endif
-  (_priority)
-#endif
 /* functions */
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 67a9ea6..6a0c36e 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -882,105 +882,9 @@ void _CPU_Context_Initialize(
 extern void mips_break( int error );
- *  set in _value.  _value is of CPU dependent type Priority_bit_map_Word.
- *  instruction.
- *    - _number = 0
- *        _value >>=8
- *        _number = 8;
- *        _value >=8
- *        _number += 4
- *      bit set
-#endif
-#endif
-  (_priority)
-#endif
 /* functions */
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index ad40ff4..5ba8673 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -678,114 +678,9 @@ uint32_t   _CPU_ISR_Get_level( void );
- *  instruction.
- *    - _number = 0
- *        _value >>=8
- *        _number = 8;
- *        _value >=8
- *        _number += 4
- *      bit set
- *  MOXIE Specific Information:
- *  XXX
-#endif
- *  XXX
-#endif
- *  XXX
-  (_priority)
-#endif
 /* functions */
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 5d7a72f..919017b 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -673,112 +673,9 @@ void _CPU_Context_Initialize(
- *  instruction.
- *    - _number = 0
- *        _value >>=8
- *        _number = 8;
- *        _value >=8
- *        _number += 4
- *      bit set
-  /* Get a value between 0 and N where N is the bit size */
-  /* This routine makes use of the fact that CPUCFGR defines
-     OB32S to have value 32, and OB64S to have value 64. If
-     this ever changes then this routine will fail. */
-     asm volatile ("l.mfspr %0,r0,0x2   \n\t"\
-                   "l.andi  %0,%0,0x60  \n\t"\
-                   "l.ff1   %1,%1,r0    \n\t"\
-                   "l.sub   %0,%0,%1    \n\t" : "=&r" (_output), "+r" (_value));
-#endif
-#endif
-  (_priority)
-#endif
 typedef struct {
diff --git a/cpukit/score/cpu/sh/cpu.c b/cpukit/score/cpu/sh/cpu.c
index d6e2d17..8988da9 100644
--- a/cpukit/score/cpu/sh/cpu.c
+++ b/cpukit/score/cpu/sh/cpu.c
@@ -203,14 +203,6 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
 #endif
-uint8_t   _bit_set_table[16] =
-  { 4, 4, 4, 4, 4, 4, 4, 4, 3, 3, 3, 3, 2, 2, 1,0};
-#endif
   Context_Control	*_the_context,
   void			*_stack_base,
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index fd657dd..8a1cc7f 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -650,111 +650,9 @@ void _CPU_Context_Initialize(
- *  instruction.
- *    - _number = 0
- *        _value >>=8
- *        _number = 8;
- *        _value >=8
- *        _number += 4
- *      bit set
-extern uint8_t   _bit_set_table[];
-      _output = 0;\
-      if(_value > 0x00ff) \
-      { _value >>= 8; _output = 8; } \
-      if(_value > 0x000f) \
-	{ _output += 4; _value >>= 4; } \
-      _output += _bit_set_table[ _value]; }
-#endif
-#endif
-  (_priority)
-#endif
 /* functions */
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 36e271c..ffbb510 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -833,153 +833,10 @@ void _CPU_Context_Initialize(
- * There is no single v850 instruction to do a bit scan so there is
- * no CPU specific implementation of bit field scanning. The empty
- * stub routines are left as a place holder in case someone figures
- * out how to do a v850 implementation better than the generic algorithm.
- * instruction.
- at verbatim
-      - _number = 0
-          _value >>=8
-          _number = 8;
-          _value >=8
-          _number += 4
- at endverbatim
- *     bit set
-#endif
-#endif
-  (_priority)
-#endif
 /* functions */
1.8.4.5
