[PATCH] bsps/powerpc: Update to RTEMS printer changes
Sebastian Huber
Wed Jun 8 14:03:57 UTC 2016
c/src/lib/libbsp/powerpc/shared/console/polled_io.c | 16 ++++++++--------
1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/console/polled_io.c b/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
index 76367a1..2ec68d0 100644
--- a/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
+++ b/c/src/lib/libbsp/powerpc/shared/console/polled_io.c
@@ -410,16 +410,16 @@ struct _console_global_data {
} console_global_data = {NULL, 0, 25, 80, 0, 24, 0, 0, 0, 0};
typedef struct console_io {
- void (*putc) (const u_char);
- int (*getc) (void);
- int (*tstc) (void);
+ void (*console_io_putc) (const u_char);
+ int (*console_io_getc) (void);
+ int (*console_io_tstc) (void);
}console_io;
extern console_io* curIo;
void debug_putc(const u_char c)
- curIo->putc(c);
+ curIo->console_io_putc(c);
/* const char arg to be compatible with BSP_output_char decl. */
@@ -433,12 +433,12 @@ debug_putc_onlcr(const char c)
int debug_getc(void)
- return curIo->getc();
+ return curIo->console_io_getc();
int debug_tstc(void)
- return curIo->tstc();
+ return curIo->console_io_tstc();
#define vidmem ((__io_ptr)(ptr_mem_map->isa_mem_base+0xb8000))
@@ -887,7 +887,7 @@ static int skip_atoi(const char **s)
int k_vsprintf(char *buf, const char *fmt, va_list args);
-void printk(const char *fmt, ...) {
+int printk(const char *fmt, ...) {
va_list args;
int i;
/* Should not be a problem with 8kB of stack */
@@ -895,9 +895,9 @@ void printk(const char *fmt, ...) {
va_start(args, fmt);
i = k_vsprintf(buf, fmt, args);
- (void) i; /* avoid set but not used warning */
va_end(args);
my_puts((u_char*)buf);
+ return i;
#endif
1.8.4.5
