Porting BSD Mailbox for RPi
Mudit Jain muditjain18011995 at gmail.com
Thu Jun 9 09:20:44 UTC 2016
Hi all,
I have procured a RPi Model B and was testing the ported driver on the
same.
This is where it hangs.
*** LIBBSD SDHCI 01 TEST ***
nexus0: <RTEMS Nexus device>
bcm_dma0: <BCM2835 DMA Controller> on nexus0
sdhci_bcm0: <Broadcom 2708 SDHCI controller> on nexus0
<Hangs>
It hangs because it tries to look for a mbox device,
Ideally, mbox0 should be on nexus0.
I suspect the problem is with the bus handles and the IRQs
Presently, the resource structure defined in the nexus-devices.h code is as
follows :
static const rtems_bsd_device_resource rpi_mbox_res[] = {
        .type = RTEMS_BSD_RES_MEMORY,
        .start_request = 0,
        .start_actual = 0x2000B880
        .type = RTEMS_BSD_RES_IRQ,
        .start_request = 0,
        .start_actual = BCM2835_IRQ_ID_MAILBOX_0
The value of BCM2835_IRQ_ID_MAILBOX_0 is 65 in irq.h
Is this resource structure appropriate for mbox ?
Github Link <https://github.com/spark1729/rtems-libbsd/commits/RPI_SD>
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160609/08ecf4dc/attachment.html>
