[PATCH 5/7] samples/base_mp/apptask.c: Fix warning and clean up
Tue Jun 14 15:05:57 UTC 2016
 testsuites/samples/base_mp/apptask.c | 23 +++++++++++------------
 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/testsuites/samples/base_mp/apptask.c b/testsuites/samples/base_mp/apptask.c
index 1414549..e54e08a 100644
--- a/testsuites/samples/base_mp/apptask.c
+++ b/testsuites/samples/base_mp/apptask.c
@@ -1,15 +1,13 @@
-/*  Application_task
+ * @file
- *  This routine is as an example of an application task which
- *  prints a message including its RTEMS task id.  This task
- *  then invokes exit to return to the monitor.
- *  Input parameters:
- *    node - processor's node number
- *  Output parameters:  NONE
- *  COPYRIGHT (c) 1989-1999.
+ * This routine is as an example of an application task which
+ * prints a message including its RTEMS task id.  This task
+ * then invokes exit to return to the monitor.
+ *  COPYRIGHT (c) 1989-1999, 2016.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -34,7 +32,8 @@ rtems_task Application_task(
   rtems_id          tid;
   rtems_status_code status;
-  status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
+  rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
+  (void) status;
   printf( "This task was invoked with the node argument (%" PRIdrtems_task_argument ")\n", node );
   printf( "This task has the id of 0x%" PRIxrtems_id "\n",  tid );
   TEST_END();
1.8.3.1
