[PATCH 7/7] Add pthread_condattr_getclock() and pthread_condattr_setclock()
Tue Jun 14 15:05:59 UTC 2016
 cpukit/posix/Makefile.am                    |   4 +-
 cpukit/posix/src/condattrgetclock.c         |  39 +++++++++++
 cpukit/posix/src/condattrsetclock.c         |  45 ++++++++++++
 testsuites/psxtests/Makefile.am             |   2 +-
 testsuites/psxtests/configure.ac            |   1 +
 testsuites/psxtests/psxcond02/Makefile.am   |  24 +++++++
 testsuites/psxtests/psxcond02/init.c        | 105 ++++++++++++++++++++++++++++
 testsuites/psxtests/psxcond02/psxcond02.doc |  27 +++++++
 testsuites/psxtests/psxcond02/psxcond02.scn |  12 ++++
 9 files changed, 257 insertions(+), 2 deletions(-)
 create mode 100644 cpukit/posix/src/condattrgetclock.c
 create mode 100644 cpukit/posix/src/condattrsetclock.c
 create mode 100644 testsuites/psxtests/psxcond02/Makefile.am
 create mode 100644 testsuites/psxtests/psxcond02/init.c
 create mode 100644 testsuites/psxtests/psxcond02/psxcond02.doc
 create mode 100644 testsuites/psxtests/psxcond02/psxcond02.scn
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 461e6eb..6495cca 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -83,7 +83,9 @@ libposix_a_SOURCES += src/cancel.c \
 ## CONDITION_VARIABLE_C_FILES
 libposix_a_SOURCES += src/cond.c src/condattrdestroy.c \
-    src/condattrgetpshared.c src/condattrinit.c src/condattrsetpshared.c \
+    src/condattrinit.c  \
+    src/condattrgetpshared.c src/condattrsetpshared.c \
+    src/condattrgetclock.c src/condattrsetclock.c \
     src/condbroadcast.c src/conddefaultattributes.c src/conddestroy.c \
     src/condinit.c src/condsignal.c src/condsignalsupp.c \
     src/condtimedwait.c src/condwait.c src/condwaitsupp.c src/condget.c
diff --git a/cpukit/posix/src/condattrgetclock.c b/cpukit/posix/src/condattrgetclock.c
new file mode 100644
index 0000000..d738575
--- /dev/null
+++ b/cpukit/posix/src/condattrgetclock.c
@@ -0,0 +1,39 @@
+ * @file
+ * @brief Get the Clock Condition Variable Attributes
+ * @ingroup POSIXAPI
+ *  COPYRIGHT (c) 2016
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <pthread.h>
+#include <errno.h>
+int pthread_condattr_getclock(
+  const pthread_condattr_t *__restrict attr,
+  clockid_t                *__restrict clock
+  if ( !attr ) {
+    return EINVAL;
+  if ( !clock ) {
+    return EINVAL;
+  *clock = attr->clock;
+  return 0;
diff --git a/cpukit/posix/src/condattrsetclock.c b/cpukit/posix/src/condattrsetclock.c
index 0000000..8a4c0a7
--- /dev/null
+++ b/cpukit/posix/src/condattrsetclock.c
@@ -0,0 +1,45 @@
+ * @file
+ * @brief Set the Clock Condition Variable Attributes
+ *  COPYRIGHT (c) 2016.
+#if HAVE_CONFIG_H
+#endif
+#include <errno.h>
+int pthread_condattr_setclock(
+  pthread_condattr_t *attr,
+  clockid_t           clock
+  if ( !attr ) {
+    return EINVAL;
+  switch ( clock ) {
+    case CLOCK_REALTIME:
+    case CLOCK_MONOTONIC:
+      attr->clock = clock;
+      return 0;
+    case CLOCK_PROCESS_CPUTIME_ID:
+    case CLOCK_THREAD_CPUTIME_ID:
+    default:
+      break;
+  return EINVAL;
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 6dd5649..a3bffb9 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -7,7 +7,7 @@ _SUBDIRS += psxhdrs psx01 psx02 psx03 psx04 psx05 psx06 psx07 psx08 psx09 \
     psxaio01 psxaio02 psxaio03 \
     psxalarm01 psxautoinit01 psxautoinit02 psxbarrier01 \
     psxcancel psxcancel01 psxclassic01 psxcleanup psxcleanup01 \
-    psxconcurrency01 psxcond01 psxconfig01 psxenosys \
+    psxconcurrency01 psxcond01 psxcond02 psxconfig01 psxenosys \
     psxitimer psxmsgq01 psxmsgq02 psxmsgq03 psxmsgq04 \
     psxmutexattr01 psxobj01 psxrwlock01 psxsem01 psxsignal01 psxsignal02 \
     psxsignal03 psxsignal04 psxsignal05 psxsignal06 \
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 779e0b5..be4a21f 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -145,6 +145,7 @@ psxclock/Makefile
 psxclock01/Makefile
 psxconcurrency01/Makefile
 psxcond01/Makefile
+psxcond02/Makefile
 psxconfig01/Makefile
 psxeintr_join/Makefile
 psxenosys/Makefile
diff --git a/testsuites/psxtests/psxcond02/Makefile.am b/testsuites/psxtests/psxcond02/Makefile.am
index 0000000..82aa29c
--- /dev/null
+++ b/testsuites/psxtests/psxcond02/Makefile.am
@@ -0,0 +1,24 @@
+rtems_tests_PROGRAMS = psxcond02
+psxcond02_SOURCES = init.c ../include/pmacros.h
+dist_rtems_tests_DATA = psxcond02.scn
+dist_rtems_tests_DATA += psxcond02.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxcond02_OBJECTS)
+LINK_LIBS = $(psxcond02_LDLIBS)
+psxcond02$(EXEEXT): $(psxcond02_OBJECTS) \
+    $(psxcond02_DEPENDENCIES)
+	@rm -f psxcond02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxcond02/init.c b/testsuites/psxtests/psxcond02/init.c
index 0000000..6314762
--- /dev/null
+++ b/testsuites/psxtests/psxcond02/init.c
@@ -0,0 +1,105 @@
+#ifdef HAVE_CONFIG_H
+#endif
+#include "tmacros.h"
+#include <time.h>
+#include <errno.h>
+const char rtems_test_name[] = "PSXCOND 2";
+/* forward declarations to avoid warnings */
+void *POSIX_Init(void *argument);
+static void test_exercise_clock_attribute_errors(void)
+  int                 sc;
+  pthread_condattr_t  attr;
+  clockid_t           clock;
+  /* NULL attribute pointer errors */
+  puts( "pthread_condattr_getclock (NULL attribute) - EINVAL" );
+  sc = pthread_condattr_getclock( NULL, &clock );
+  fatal_posix_service_status( sc, EINVAL, "condattr getclock" );
+  puts( "pthread_condattr_getclock (NULL clock) - EINVAL" );
+  sc = pthread_condattr_getclock( &attr, NULL );
+  puts( "pthread_condattr_setclock (NULL attribute) - EINVAL" );
+  sc = pthread_condattr_setclock( NULL, CLOCK_REALTIME );
+  fatal_posix_service_status( sc, EINVAL, "condattr setclock" );
+  /* invalid clock errors */
+  puts( "pthread_condattr_init - OK" );
+  sc = pthread_condattr_init( &attr );
+  fatal_posix_service_status( sc, 0, "condattr init" );
+  puts( "pthread_condattr_setclock (bad clock)- EINVAL" );
+  sc = pthread_condattr_setclock( &attr, -1 );
+  puts( "pthread_condattr_setclock (CLOCK_PROCESS_CPUTIME_ID)- EINVAL" );
+  sc = pthread_condattr_setclock( &attr, CLOCK_PROCESS_CPUTIME_ID );
+  puts( "pthread_condattr_setclock (CLOCK_THREAD_CPUTIME_ID)- EINVAL" );
+  sc = pthread_condattr_setclock( &attr, CLOCK_THREAD_CPUTIME_ID );
+static void test_exercise_clock_attribute(void)
+  int                 sc;
+  puts( "pthread_condattr_setclock (CLOCK_REALTIME)- OK" );
+  sc = pthread_condattr_setclock( &attr, CLOCK_REALTIME );
+  fatal_posix_service_status( sc, 0, "condattr setclock" );
+  puts( "pthread_condattr_setclock (CLOCK_MONOTONIC)- OK" );
+  sc = pthread_condattr_setclock( &attr, CLOCK_MONOTONIC );
+void *POSIX_Init(
+  void *argument
+  TEST_BEGIN();
+  test_exercise_clock_attribute_errors();
+  test_exercise_clock_attribute();
+  TEST_END();
+  rtems_test_exit( 0 );
+  return NULL; /* just so the compiler thinks we returned something */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxcond02/psxcond02.doc b/testsuites/psxtests/psxcond02/psxcond02.doc
index 0000000..9e6f88a
--- /dev/null
+++ b/testsuites/psxtests/psxcond02/psxcond02.doc
@@ -0,0 +1,27 @@
+#  COPYRIGHT (c) 2016
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name:  psxcond02
+directives:
+  pthread_condattr_init
+  pthread_condcondattr_getclock
+  pthread_condcondattr_setclock
+concepts:
++ Verify error conditions in pthread_condattr_getclock
++ Verify error conditions in pthread_condattr_setclock
++ Verify normal paths through pthread_condattr_getclock
++ Verify normal paths through pthread_condattr_setclock
diff --git a/testsuites/psxtests/psxcond02/psxcond02.scn b/testsuites/psxtests/psxcond02/psxcond02.scn
index 0000000..511d1f3
--- /dev/null
+++ b/testsuites/psxtests/psxcond02/psxcond02.scn
@@ -0,0 +1,12 @@
+*** BEGIN OF TEST PSXCOND 2 ***
+pthread_condattr_getclock (NULL attribute) - EINVAL
+pthread_condattr_getclock (NULL clock) - EINVAL
+pthread_condattr_setclock (NULL attribute) - EINVAL
+pthread_condattr_init - OK
+pthread_condattr_setclock (bad clock)- EINVAL
+pthread_condattr_setclock (CLOCK_PROCESS_CPUTIME_ID)- EINVAL
+pthread_condattr_setclock (CLOCK_THREAD_CPUTIME_ID)- EINVAL
+pthread_condattr_setclock (CLOCK_REALTIME)- OK
+pthread_condattr_setclock (CLOCK_MONOTONIC)- OK
+*** END OF TEST PSXCOND 2 ***
1.8.3.1
