Error Running HelloWorld on new BSP
Olufowobi, Habeeb habeeb.olufowobi at bison.howard.edu
Wed Jun 15 16:04:28 UTC 2016
Hi,
I have been working on getting the console running for the past few days
but I am still getting some errors.
I realized that the system control configuration of the board family
(LM3S69XX) was different so I had to rewrite the bspstart.c and the
lm3s69xx.h to suit the TM4C129E I am working on.
Presently, HelloWorld halt at "CPU_FATAL_HALT(the_source, the_error)" and I
am getting RTEMS_FATAL_SOURCE_EXCEPTION in the_source and an error code. I
am not sure how to debug this but reading about it.
Below is the backtrace of the error message.
Kindly assist.
^C
Program received signal SIGINT, Interrupt.
0x00004b22 in _Terminate (
    the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
    is_internal=is_internal at entry=false, the_error=536875064)
    at
../../../../../../../rtems.git/c/src/../../cpukit/score/src/interr.c:52
52  _CPU_Fatal_halt( the_source, the_error );
(gdb) bt
#0  0x00004b22 in _Terminate (
    at
#1  0x0000404a in rtems_fatal (
    source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
    error=<optimized out>)
    at
../../../../../../../rtems.git/c/src/../../cpukit/sapi/src/fatal2.c:34
#2  0x00007be2 in _ARM_Exception_default (frame=<optimized out>)
    at
../../../../../../../../../rtems.git/c/src/../../cpukit/score/cpu/arm/arm-exception-default.c:24
#3  <signal handler called>
#4  0x00000080 in bsp_start_vector_table_begin ()
#5  0x00000000 in ?? ()
(gdb)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160615/ec7c10c5/attachment.html>
