[PATCH 03/16] posix: Delete POSIX_API_Control::ss_high_priority
Fri Jun 17 10:51:40 UTC 2016
This field was unused.
 cpukit/posix/include/rtems/posix/threadsup.h | 5 -----
 cpukit/posix/src/pthreadsetschedparam.c      | 4 ----
 2 files changed, 9 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
index 51c9564..60bf0e4 100644
--- a/cpukit/posix/include/rtems/posix/threadsup.h
+++ b/cpukit/posix/include/rtems/posix/threadsup.h
@@ -52,11 +52,6 @@ typedef struct {
   /** This is the thread's current set of scheduling parameters. */
   struct sched_param      schedparam;
-   * This is the high priority to execute at when using the sporadic
-   * scheduler.
-  int                     ss_high_priority;
    * This is the timer which controls when the thread executes at
    * high and low priority when using the sporadic scheduler.
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index a6882b9..55019dd 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -100,10 +100,6 @@ int pthread_setschedparam(
         rtems_configuration_get_ticks_per_timeslice();
       new_priority = _POSIX_Priority_To_core( api->schedparam.sched_priority );
       break;
-    case SCHED_SPORADIC:
-      api->ss_high_priority = api->schedparam.sched_priority;
-      break;
   _Thread_State_release( the_thread, &lock_context );
1.8.4.5
