[PATCH 09/16] score: Delete unused _Scheduler_Priority_compare()
    Sebastian Huber
    Fri Jun 17 10:51:46 UTC 2016
By convention, thread priorities must be integers in RTEMS.  Smaller
values represent more important threads.
 cpukit/score/Makefile.am                           |  2 -
 cpukit/score/include/rtems/score/scheduler.h       |  6 ---
 cpukit/score/include/rtems/score/schedulercbs.h    |  1 -
 cpukit/score/include/rtems/score/scheduleredf.h    | 14 ------
 .../score/include/rtems/score/scheduleredfimpl.h   |  5 +++
 cpukit/score/include/rtems/score/schedulerimpl.h   | 51 ----------------------
 .../score/include/rtems/score/schedulerpriority.h  | 13 ------
 .../rtems/score/schedulerpriorityaffinitysmp.h     |  1 -
 .../include/rtems/score/schedulerpriorityimpl.h    | 17 --------
 .../include/rtems/score/schedulerprioritysmp.h     |  1 -
 cpukit/score/include/rtems/score/schedulersimple.h |  1 -
 .../score/include/rtems/score/schedulersimplesmp.h |  1 -
 .../score/include/rtems/score/schedulerstrongapa.h |  1 -
 cpukit/score/src/schedulercbsunblock.c             |  9 ++--
 cpukit/score/src/scheduleredf.c                    | 22 ++++++++++
 cpukit/score/src/scheduleredfprioritycompare.c     | 47 --------------------
 cpukit/score/src/scheduleredfunblock.c             | 10 +++--
 .../score/src/schedulerpriorityprioritycompare.c   | 29 ------------
 18 files changed, 37 insertions(+), 194 deletions(-)
 delete mode 100644 cpukit/score/src/scheduleredfprioritycompare.c
 delete mode 100644 cpukit/score/src/schedulerpriorityprioritycompare.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 537cf60..7166d72 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -239,7 +239,6 @@ libscore_a_SOURCES += src/schedulerdefaultupdate.c
 libscore_a_SOURCES += src/schedulerpriority.c \
     src/schedulerpriorityblock.c \
     src/schedulerprioritychangepriority.c \
-    src/schedulerpriorityprioritycompare.c \
     src/schedulerpriorityschedule.c \
     src/schedulerpriorityunblock.c \
     src/schedulerpriorityupdate.c \
@@ -258,7 +257,6 @@ libscore_a_SOURCES += src/scheduleredf.c \
     src/scheduleredfnodeinit.c \
     src/scheduleredfblock.c \
     src/scheduleredfchangepriority.c \
-    src/scheduleredfprioritycompare.c \
     src/scheduleredfreleasejob.c \
     src/scheduleredfschedule.c \
     src/scheduleredfunblock.c \
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 1e6236f..2e9aba5 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -129,12 +129,6 @@ typedef struct {
     Priority_Control
-  /** @see _Scheduler_Priority_compare() */
-  int ( *priority_compare )(
-    Priority_Control,
-    Priority_Control
   /** @see _Scheduler_Release_job() */
   void ( *release_job ) (
     const Scheduler_Control *,
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index e390532..397488f 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -59,7 +59,6 @@ extern "C" {
     _Scheduler_CBS_Node_initialize,  /* node initialize entry point */ \
     _Scheduler_default_Node_destroy, /* node destroy entry point */ \
     _Scheduler_EDF_Update_priority,  /* update priority entry point */ \
-    _Scheduler_EDF_Priority_compare, /* compares two priorities */ \
     _Scheduler_CBS_Release_job,      /* new period of task */ \
     _Scheduler_default_Tick,         /* tick entry point */ \
     _Scheduler_default_Start_idle    /* start idle entry point */ \
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 137ea3a..7d513ca 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -52,7 +52,6 @@ extern "C" {
     _Scheduler_EDF_Node_initialize,  /* node initialize entry point */ \
     _Scheduler_EDF_Release_job,      /* new period of task */ \
@@ -226,19 +225,6 @@ Scheduler_Void_or_thread _Scheduler_EDF_Yield(
- *  @brief Explicitly compare absolute dedlines (priorities) of threads.
- * This routine explicitly compares absolute dedlines (priorities) of threads.
- * In case of EDF scheduling time overflow is taken into account.
- * @retval >0 for p1 > p2; 0 for p1 == p2; <0 for p1 < p2.
-int _Scheduler_EDF_Priority_compare (
-  Priority_Control p1,
-  Priority_Control p2
  *  @brief Called when a new job of task is released.
  *  This routine is called when a new job of task is released.
diff --git a/cpukit/score/include/rtems/score/scheduleredfimpl.h b/cpukit/score/include/rtems/score/scheduleredfimpl.h
index 4feea71..e831caf 100644
--- a/cpukit/score/include/rtems/score/scheduleredfimpl.h
+++ b/cpukit/score/include/rtems/score/scheduleredfimpl.h
@@ -44,6 +44,11 @@ RTEMS_INLINE_ROUTINE Scheduler_EDF_Node *_Scheduler_EDF_Thread_get_node(
   return (Scheduler_EDF_Node *) _Scheduler_Thread_get_node( the_thread );
+int _Scheduler_EDF_Priority_compare (
+  Priority_Control p1,
+  Priority_Control p2
 RBTree_Compare_result _Scheduler_EDF_Compare(
   const RBTree_Node* n1,
   const RBTree_Node* n2
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index bfc6df3..50061fb 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -482,31 +482,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority(
- * @brief Compares two priority values.
- * @param[in] scheduler The scheduler instance.
- * @param[in] p1 The first priority value.
- * @param[in] p2 The second priority value.
- * @retval negative The value @a p1 encodes a lower priority than @a p2 in the
- * intuitive sense of priority.
- * @retval 0 The priorities @a p1 and @a p2 are equal.
- * @retval positive The value @a p1 encodes a higher priority than @a p2 in the
- * @see _Scheduler_Is_priority_lower_than() and
- * _Scheduler_Is_priority_higher_than().
-RTEMS_INLINE_ROUTINE int _Scheduler_Priority_compare(
-  const Scheduler_Control *scheduler,
-  return ( *scheduler->Operations.priority_compare )( p1, p2 );
  * @brief Releases a job of a thread with respect to the scheduler.
  * @param[in] the_thread The thread.
@@ -746,32 +721,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Generic_block(
- * @brief Returns true if @a p1 encodes a lower priority than @a p2 in the
-RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_lower_than(
-  return _Scheduler_Priority_compare( scheduler, p1,  p2 ) < 0;
- * @brief Returns true if @a p1 encodes a higher priority than @a p2 in the
-RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_higher_than(
-  return _Scheduler_Priority_compare( scheduler, p1,  p2 ) > 0;
 RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_processor_count(
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 5859af1..0759941 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -49,7 +49,6 @@ extern "C" {
     _Scheduler_default_Node_initialize,   /* node initialize entry point */ \
     _Scheduler_priority_Update_priority,  /* update priority entry point */ \
-    _Scheduler_priority_Priority_compare, /* compares two priorities */ \
     _Scheduler_default_Release_job,       /* new period of task */ \
@@ -189,18 +188,6 @@ Scheduler_Void_or_thread _Scheduler_priority_Yield(
   Thread_Control          *the_thread
- *  @brief Compare two priorities.
- *  This routine compares two priorities.
-int _Scheduler_priority_Priority_compare(
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
index dd0085a6..e2d6f3b 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
     _Scheduler_priority_affinity_SMP_Node_initialize, \
     _Scheduler_default_Node_destroy, \
     _Scheduler_priority_SMP_Update_priority, \
-    _Scheduler_priority_Priority_compare, \
     _Scheduler_default_Release_job, \
     _Scheduler_default_Tick, \
     _Scheduler_SMP_Start_idle, \
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
index a18840f..d709818 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
@@ -219,23 +219,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update(
- * @brief Priority comparison.
- * This routine implements priority comparison for priority-based
- * scheduling.
- * @return >0 for higher priority, 0 for equal and <0 for lower priority.
-RTEMS_INLINE_ROUTINE int _Scheduler_priority_Priority_compare_body(
-  /* High priority in priority scheduler is represented by low numbers. */
-  return ( p2 - p1 );
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index d8ce7dc..d550c78 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -88,7 +88,6 @@ typedef struct {
     _Scheduler_priority_SMP_Node_initialize, \
     _Scheduler_SMP_Start_idle \
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index a546ed6..9e40c4a 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
     _Scheduler_default_Update_priority,   /* update priority entry point */ \
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 342a574..b943353 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -71,7 +71,6 @@ typedef struct {
     _Scheduler_simple_SMP_Node_initialize, \
     _Scheduler_simple_SMP_Update_priority, \
diff --git a/cpukit/score/include/rtems/score/schedulerstrongapa.h b/cpukit/score/include/rtems/score/schedulerstrongapa.h
index 5222cd0..4f95aac 100644
--- a/cpukit/score/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/score/include/rtems/score/schedulerstrongapa.h
     _Scheduler_strong_APA_Node_initialize, \
     _Scheduler_strong_APA_Update_priority, \
diff --git a/cpukit/score/src/schedulercbsunblock.c b/cpukit/score/src/schedulercbsunblock.c
index 7898588..05e155a 100644
--- a/cpukit/score/src/schedulercbsunblock.c
+++ b/cpukit/score/src/schedulercbsunblock.c
@@ -79,11 +79,10 @@ Scheduler_Void_or_thread _Scheduler_CBS_Unblock(
    *    a pseudo-ISR system task, we need to do a context switch.
   if (
-    _Scheduler_Is_priority_higher_than(
-       scheduler,
-       the_thread->current_priority,
-       _Thread_Heir->current_priority
+    _Scheduler_EDF_Priority_compare(
+      the_thread->current_priority,
+      _Thread_Heir->current_priority
+    ) == 1
     _Scheduler_Update_heir(
       the_thread,
diff --git a/cpukit/score/src/scheduleredf.c b/cpukit/score/src/scheduleredf.c
index 00b6181..3726128 100644
--- a/cpukit/score/src/scheduleredf.c
+++ b/cpukit/score/src/scheduleredf.c
@@ -20,6 +20,28 @@
+  Watchdog_Interval time = _Watchdog_Ticks_since_boot;
+   * Reorder priorities to separate deadline driven and background tasks.
+   * The background tasks have p1 or p2 > SCHEDULER_EDF_PRIO_MSB.
+   * The deadline driven tasks need to have subtracted current time in order
+   * to see which deadline is closer wrt. current time.
+  if (!(p1 & SCHEDULER_EDF_PRIO_MSB))
+    p1 = (p1 - time) & ~SCHEDULER_EDF_PRIO_MSB;
+  if (!(p2 & SCHEDULER_EDF_PRIO_MSB))
+    p2 = (p2 - time) & ~SCHEDULER_EDF_PRIO_MSB;
+  return ((p1<p2) - (p1>p2));
diff --git a/cpukit/score/src/scheduleredfprioritycompare.c b/cpukit/score/src/scheduleredfprioritycompare.c
deleted file mode 100644
index 0fbfaa6..0000000
--- a/cpukit/score/src/scheduleredfprioritycompare.c
+++ /dev/null
@@ -1,47 +0,0 @@
- * @file
- * @brief Compares Priorities of Threads
- * @ingroup ScoreScheduler
- *  Copyright (C) 2011 Petr Benes.
- *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/score/scheduleredf.h>
-#include <rtems/score/watchdogimpl.h>
-  Watchdog_Interval time = _Watchdog_Ticks_since_boot;
-   * Reorder priorities to separate deadline driven and background tasks.
-   * The background tasks have p1 or p2 > SCHEDULER_EDF_PRIO_MSB.
-   * The deadline driven tasks need to have subtracted current time in order
-   * to see which deadline is closer wrt. current time.
-  if (!(p1 & SCHEDULER_EDF_PRIO_MSB))
-    p1 = (p1 - time) & ~SCHEDULER_EDF_PRIO_MSB;
-  if (!(p2 & SCHEDULER_EDF_PRIO_MSB))
-    p2 = (p2 - time) & ~SCHEDULER_EDF_PRIO_MSB;
-  return ((p1<p2) - (p1>p2));
diff --git a/cpukit/score/src/scheduleredfunblock.c b/cpukit/score/src/scheduleredfunblock.c
index 9775342..43d9753 100644
--- a/cpukit/score/src/scheduleredfunblock.c
+++ b/cpukit/score/src/scheduleredfunblock.c
@@ -42,10 +42,12 @@ Scheduler_Void_or_thread _Scheduler_EDF_Unblock(
    *    Even if the thread isn't preemptible, if the new heir is
-  if ( _Scheduler_Is_priority_lower_than(
-         scheduler,
-         _Thread_Heir->current_priority,
-         the_thread->current_priority )) {
+  if (
+    ) == 1
       the_thread,
       the_thread->current_priority == PRIORITY_PSEUDO_ISR
diff --git a/cpukit/score/src/schedulerpriorityprioritycompare.c b/cpukit/score/src/schedulerpriorityprioritycompare.c
index 6879d01..0000000
--- a/cpukit/score/src/schedulerpriorityprioritycompare.c
+++ /dev/null
@@ -1,29 +0,0 @@
- *  @file
- *  @brief Scheduler Priority Compare Two Priorities
- *  COPYRIGHT (c) 2011.
- *  On-Line Applications Research Corporation (OAR).
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/schedulerpriorityimpl.h>
-  return _Scheduler_priority_Priority_compare_body( p1, p2 );
1.8.4.5
