Error Running HelloWorld on new BSP
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Fri Jun 17 17:44:40 UTC 2016
Hi Joel,
When I set the breakpoint at boot_card, this how far I could get;
(gdb) step
_Terminate (the_source=RTEMS_FATAL_SOURCE_EXCEPTION,
is_internal=false, the_error=536874976)
at
../../../../../../../rtems.git/c/src/../../cpukit/score/src/interr.c:52
52 _CPU_Fatal_halt( the_source, the_error );
(gdb) step
arm_interrupt_disable ()
at ../../cpukit/../../../tm4c129e/lib/include/rtems/score/cpu.h:345
345 uint32_t basepri = 0x80;
(gdb) step
347 __asm__ volatile (
(gdb) step
357 return level;
(gdb) step
358 }
(gdb) step
And the backtrace is below
Program received signal SIGINT, Interrupt.
0x0000a6ac in _Terminate (
the_source=RTEMS_FATAL_SOURCE_EXCEPTION, is_internal=false,
at
(gdb) bt
#0 0x0000a6ac in _Terminate (
at
#1 0x000085b0 in rtems_fatal (
source=RTEMS_FATAL_SOURCE_EXCEPTION, error=536874976)
at
../../../../../../../rtems.git/c/src/../../cpukit/sapi/src/fatal2.c:34
#2 0x00013bfc in _ARM_Exception_default (frame=0x20000fe0)
at
../../../../../../../../../rtems.git/c/src/../../cpukit/score/cpu/arm/arm-exception-default.c:24
#3 <signal handler called>
#4 0x00000000 in bsp_start_vector_table_begin ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
Regards,
Habeeb
On Fri, Jun 17, 2016 at 12:51 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jun 17, 2016 at 11:33 AM, Olufowobi, Habeeb <
> habeeb.olufowobi at bison.howard.edu> wrote:
>> Hi,
>> I was able to print the frame and below is the result. Also, I realised
>> the problem is from the uart. Any ideas on how to resolve this?
>> (gdb) print *frame
>> $1 = {register_r0 = 115200, register_r1 = 1, register_r2 = 0,
>> register_r3 = 1073790976, register_r4 = 0, register_r5 = 0,
>> register_r6 = 0, register_r7 = 536875096, register_r8 = 0,
>> register_r9 = 0, register_r10 = 0, register_r11 = 0,
>> register_r12 = 536894384, register_sp = 120,
>> register_lr = 0x138d <initialize+60>,
>> register_pc = 0x1290 <get_baud_div>,
>> register_xpsr = 1090519040, vector = 3,
>> vfp_context = 0x0 <bsp_start_vector_table_begin>,
>> reserved_for_stack_alignment = 536875056}
> Not knowing this particular BSP, can you set a breakpoint at various
> points in
> the assembly startup? At boot_card? How far do you get?
> Does the code in memory look like it is supposed to versus
> arm-rtems4.12-objdump?
>> On Wed, Jun 15, 2016 at 12:04 PM, Olufowobi, Habeeb <
>>> Hi,
>>> I have been working on getting the console running for the past few days
>>> but I am still getting some errors.
>>> I realized that the system control configuration of the board family
>>> (LM3S69XX) was different so I had to rewrite the bspstart.c and the
>>> lm3s69xx.h to suit the TM4C129E I am working on.
>>> Presently, HelloWorld halt at "CPU_FATAL_HALT(the_source, the_error)"
>>> and I am getting RTEMS_FATAL_SOURCE_EXCEPTION in the_source and an error
>>> code. I am not sure how to debug this but reading about it.
>>> Below is the backtrace of the error message.
>>> Kindly assist.
>>> ^C
>>> 0x00004b22 in _Terminate (
>>> the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>>> is_internal=is_internal at entry=false, the_error=536875064)
>>> at
>>> (gdb) bt
>>> #0 0x00004b22 in _Terminate (
>>> at
>>> #1 0x0000404a in rtems_fatal (
>>> source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>>> error=<optimized out>)
>>> at
>>> #2 0x00007be2 in _ARM_Exception_default (frame=<optimized out>)
>>> at
>>> #4 0x00000080 in bsp_start_vector_table_begin ()
>>> #5 0x00000000 in ?? ()
>>> (gdb)
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160617/58710391/attachment-0001.html>
