[PATCH v2 2/4] bsp/tms570: update pinmux to provide support for initialization lists and clear of alt outputs.
pisa at cmp.felk.cvut.cz pisa at cmp.felk.cvut.cz
Mon Jun 20 19:52:27 UTC 2016
 c/src/lib/libbsp/arm/tms570/Makefile.am            |   3 +
 .../lib/libbsp/arm/tms570/include/tms570-pinmux.h  | 136 +++++++++++----------
 c/src/lib/libbsp/arm/tms570/include/tms570.h       |   3 +
 c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c        | 123 ++++++++++++++++++-
 4 files changed, 196 insertions(+), 69 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index 568ce11..c4d39bc 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -43,6 +43,9 @@ include_bsp_HEADERS += include/tms570-sci-driver.h
 include_bsp_HEADERS += include/system-clocks.h
 include_bsp_HEADERS += include/tms570-pinmux.h
+include_bsp_HEADERS += include/tms570-pins.h
+include_bsp_HEADERS += include/tms570ls3137zwt-pins.h
 include_bsp_ti_hercules_HEADERS = include/ti_herc/reg_adc.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_ccmsr.h
 include_bsp_ti_hercules_HEADERS += include/ti_herc/reg_crc.h
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h b/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
index 8979f23..2c049c4 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h
@@ -31,79 +31,35 @@ extern "C" {
 #endif /* __cplusplus */
-#define TMS570_PIN_NUM_SHIFT 0
-#define TMS570_PIN_NUM_MASK  0x0fff
+#define TMS570_PIN_NUM_SHIFT    0
+#define TMS570_PIN_NUM_MASK     0x000007ff
-#define TMS570_PIN_FNC_SHIFT 12
-#define TMS570_PIN_FNC_MASK  0xf000
-#define TMS570_PIN_FNC_AUTO  (-1)
-#define TMS570_PIN_AND_FNC(pin, fnc) \
-  ((pin) | ((fnc)<<TMS570_PIN_FNC_SHIFT))
-#define TMS570_BALL_WITH_MMR(mmrx, pos) \
-  ((pos) | ((mmrx)<<2))
-/* Definition for pins/balls which has to be set for Ethernet MII */
-#define TMS570_BALL_C3  TMS570_BALL_WITH_MMR(0, 2)
-#define TMS570_BALL_C3_MIBSPI3NCS_3 TMS570_PIN_AND_FNC(TMS570_BALL_C3, 0)
-#define TMS570_BALL_C3_I2C_SCL TMS570_PIN_AND_FNC(TMS570_BALL_C3, 1)
-#define TMS570_BALL_F3 TMS570_BALL_WITH_MMR(20, 2)
-#define TMS570_BALL_F3_MII_COL TMS570_PIN_AND_FNC(TMS570_BALL_F3, 2)
-#define TMS570_BALL_B4 TMS570_BALL_WITH_MMR(17, 2)
-#define TMS570_BALL_B4_MII_CRS TMS570_PIN_AND_FNC(TMS570_BALL_B4, 1)
-#define TMS570_BALL_B11 TMS570_BALL_WITH_MMR(19, 1)
-#define TMS570_BALL_B11_MII_RX_DV TMS570_PIN_AND_FNC(TMS570_BALL_B11, 1)
-#define TMS570_BALL_N19 TMS570_BALL_WITH_MMR(10, 0)
-#define TMS570_BALL_N19_MII_RX_ER TMS570_PIN_AND_FNC(TMS570_BALL_N19, 1)
-#define TMS570_BALL_K19 TMS570_BALL_WITH_MMR(14, 1)
-#define TMS570_BALL_K19_MII_RX_CLK TMS570_PIN_AND_FNC(TMS570_BALL_K19, 1)
-#define TMS570_BALL_P1 TMS570_BALL_WITH_MMR(11, 3)
-#define TMS570_BALL_P1_MII_RXD_0 TMS570_PIN_AND_FNC(TMS570_BALL_P1, 2)
-#define TMS570_BALL_A14 TMS570_BALL_WITH_MMR(12, 0)
-#define TMS570_BALL_A14_MII_RXD_1 TMS570_PIN_AND_FNC(TMS570_BALL_A14, 1)
-#define TMS570_BALL_G19 TMS570_BALL_WITH_MMR(12, 2)
-#define TMS570_BALL_G19_MII_RXD_2 TMS570_PIN_AND_FNC(TMS570_BALL_G19, 2)
-#define TMS570_BALL_H18 TMS570_BALL_WITH_MMR(12, 3)
-#define TMS570_BALL_H18_MII_RXD_3 TMS570_PIN_AND_FNC(TMS570_BALL_H18, 2)
-#define TMS570_BALL_D19 TMS570_BALL_WITH_MMR(17, 0)
-#define TMS570_BALL_D19_MII_TX_CLK TMS570_PIN_AND_FNC(TMS570_BALL_D19, 1)
-#define TMS570_BALL_J18 TMS570_BALL_WITH_MMR(13, 0)
-#define TMS570_BALL_J18_MII_TXD_0 TMS570_PIN_AND_FNC(TMS570_BALL_J18, 2)
+ * Request clear of interconnection in setup
+ * to ensure that previous peripehar to pin
+ * connection is not enabled in parallel to other one.
+ * Mask is ored with pin number in such list.
+#define TMS570_PIN_CLEAR_RQ_MASK 0x00000800
-#define TMS570_BALL_J19 TMS570_BALL_WITH_MMR(13, 1)
-#define TMS570_BALL_J19_MII_TXD_1 TMS570_PIN_AND_FNC(TMS570_BALL_J19, 2)
+#define TMS570_PIN_FNC_SHIFT    12
+#define TMS570_PIN_FNC_MASK     0x0000f000
-#define TMS570_BALL_R2 TMS570_BALL_WITH_MMR(13, 3)
-#define TMS570_BALL_R2_MII_TXD_2 TMS570_PIN_AND_FNC(TMS570_BALL_R2, 2)
+#define TMS570_PIN_NUM_FNC_MASK 0x0000ffff
-#define TMS570_BALL_E18 TMS570_BALL_WITH_MMR(14, 0)
-#define TMS570_BALL_E18_MII_TXD_3 TMS570_PIN_AND_FNC(TMS570_BALL_E18, 2)
+#define TMS570_PIN_IN_ALT_SHIFT 16
+#define TMS570_PIN_IN_ALT_MASK  0xffff0000
-#define TMS570_BALL_H19 TMS570_BALL_WITH_MMR(13, 2)
-#define TMS570_BALL_H19_MII_TXEN TMS570_PIN_AND_FNC(TMS570_BALL_H19, 2)
+#define TMS570_PIN_FNC_AUTO  (-1)
-#define TMS570_BALL_V5 TMS570_BALL_WITH_MMR(7, 1)
-#define TMS570_BALL_V5_MDCLK TMS570_PIN_AND_FNC(TMS570_BALL_V5, 2)
+#define TMS570_PIN_AND_FNC(pin, fnc) \
+  ((pin) | ((fnc) << TMS570_PIN_FNC_SHIFT))
-#define TMS570_BALL_G3 TMS570_BALL_WITH_MMR(8, 1)
-#define TMS570_BALL_G3_MDIO TMS570_PIN_AND_FNC(TMS570_BALL_G3, 2)
+#define TMS570_PIN_WITH_IN_ALT(pin_num_and_fnc, pin_in_alt_num_and_fnc) \
+  ((pin_num_and_fnc) | ((pin_in_alt_num_and_fnc) << TMS570_PIN_IN_ALT_SHIFT))
-#define TMS570_BALL_XX TMS570_BALL_WITH_MMR(29, 3)
-#define TMS570_BALL_XX_GMII_SEL TMS570_PIN_AND_FNC(TMS570_BALL_XX, 0)
+#define TMS570_BALL_WITH_MMR(mmrx, pos) \
+  ((pos) | ((mmrx) << 2))
 /* Generic functions select pin to peripheral connection */
@@ -111,6 +67,10 @@ void tms570_bsp_pin_set_function(int pin_num, int pin_fnc);
 void tms570_bsp_pin_clear_function(int pin_num, int pin_fnc);
+void tms570_bsp_pin_config_one(uint32_t pin_num_and_fnc);
+void tms570_bsp_pinmmr_config(const uint32_t *pinmmr_values, int reg_start, int reg_count);
 static inline void
 tms570_bsp_pin_to_pinmmrx(volatile uint32_t **pinmmrx, unsigned int *pin_shift,
                           int pin_num)
@@ -120,6 +80,52 @@ tms570_bsp_pin_to_pinmmrx(volatile uint32_t **pinmmrx, unsigned int *pin_shift,
   *pin_shift = (pin_num & 0x3)*8;
+#define TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) \
+  (((((pin) & TMS570_PIN_NUM_MASK) >> 2 != (reg)) || ((pin) & TMS570_PIN_CLEAR_RQ_MASK))? 0: \
+   1 << ((((pin) & TMS570_PIN_FNC_MASK) >> TMS570_PIN_FNC_SHIFT) + \
+   ((pin) & 3) * 8) \
+#define TMS570_PINMMR_REG_VAL_ACTION(reg, pin) \
+  TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) | \
+  ((pin) & TMS570_PIN_IN_ALT_MASK? \
+  TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, (pin) >> TMS570_PIN_IN_ALT_SHIFT ): \
+  0) |
+ * Macro which computes value for PINMMRx register from pin list
+ * which is defined as macro calling action macro for each pin
+ * @param reg      PINMMR register number (0 .. 30 for TMS570LS3137)
+ * @param pin_list declared as macro with parameters
+ *                 \c per_pin_action and \c common_arg which expands
+ *                 to list of \c per_pin_action(\c common_arg, \c TMS570_BALL_xx_function)
+ * @retval number which represents connections which should be enabled
+ *                in given PINMMR register. Pin setup for other registers than specified
+ *                are ignored
+#define TMS570_PINMMR_REG_VAL(reg, pin_list) \
+  pin_list(TMS570_PINMMR_REG_VAL_ACTION, reg) 0
+#define TMS570_PINMMR_COMA_LIST_ACTION(reg, pin) \
+  (pin),
+ * Macro which generates list of pin and function specification from
+ * from pin list which is defined as macro calling action macro for each pin
+ * @retval list of coma separated pin+function combined values which is terminated by coma
+ *              at the end
+#define TMS570_PINMMR_COMA_LIST(pin_list) \
+  pin_list(TMS570_PINMMR_COMA_LIST_ACTION, 0)
 #endif
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570.h b/c/src/lib/libbsp/arm/tms570/include/tms570.h
index 439387e..f3daac1 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570.h
@@ -38,6 +38,9 @@
 #ifndef LIBBSP_ARM_TMS570
 #define LIBBSP_ARM_TMS570
+#include <bsp/tms570-pins.h>
 #include <bsp/ti_herc/reg_adc.h>
 #include <bsp/ti_herc/reg_ccmsr.h>
 #include <bsp/ti_herc/reg_crc.h>
diff --git a/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c b/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
index fed23fa..0778d3a 100644
--- a/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
+++ b/c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c
@@ -22,6 +22,10 @@
 #include <bsp/tms570.h>
 #include <bsp/tms570-pinmux.h>
+#include <bsp/irq.h>
+uint32_t tms570_bsp_pinmmr_kick_key0 = 0x83E70B13U;
+uint32_t tms570_bsp_pinmmr_kick_key1 = 0x95A4F1E0U;
  * @brief select desired function of pin/ball
@@ -29,14 +33,14 @@
  * The function setups multiplexer to interconnect pin with
  * specified function/peripheral. Pin number is index into pinmux
  * entries array. Predefined values for pins are in a format
- * TMS570_BALL_<column><row> (for example TMS570_BALL_N19).
+ * TMS570_BALL_ \c column \c row (for example \c TMS570_BALL_N19).
  * The multiplexer allows to interconnect one pin to multiple
  * signal sources/sinks in the theory but it is usually bad choice.
  * The function sets only specified function and clears all other
  * connections.
- * @param[in] pin_num  pin/ball identifier (index into pinmux array)
- * @param[in] pin_fnc  function number 0 .. 7, if value TMS570_PIN_FNC_AUTO
+ * @param[in] pin_num  pin/ball identifier (index into pinmux array),
+ * @param[in] pin_fnc  function number 0 .. 7, if value \c TMS570_PIN_FNC_AUTO
  *                     is specified then pin function is extracted from
  *                     pin_num argument
  * @retval Void
@@ -61,7 +65,7 @@ tms570_bsp_pin_set_function(int pin_num, int pin_fnc)
  * of multiplexer setup intact.
  *                     pin_num argument
  * @retval Void
@@ -78,3 +82,114 @@ tms570_bsp_pin_clear_function(int pin_num, int pin_fnc)
   tms570_bsp_pin_to_pinmmrx(&pinmmrx, &pin_shift, pin_num);
   *pinmmrx = *pinmmrx & ~(1 << (pin_fnc+pin_shift));
+ * @brief configure one pin according to its function specification
+ * The function setups multiplexer to interconnect pin with
+ * specified function/peripheral. Predefined values for pins combined with
+ * function are in a format TMS570_BALL_ \c column \c row \c function
+ * (for example \c TMS570_BALL_W3_SCIRX).
+ * If the function can be connected to more pins then specification
+ * includes infomation which allows to disconnect alternative pin to peripheral
+ * input connection or switch input multiplexer to right pin.
+ * @param[in] pin_num_and_fnc pin function descriptor is build by macro
+ *               \c TMS570_PIN_AND_FNC which takes pin/pinmmr specification
+ *               build by \c TMS570_BALL_WITH_MMR and function index in output
+ *               multiplexer. If the peripheral can be connected to other input
+ *               alternative then actual pin description and alternative to
+ *               disconnected/reconnect are combined together by
+ *               \c TMS570_PIN_WITH_IN_ALT macro. If clear of alternative
+ *               connection is required then flag \c TMS570_PIN_CLEAR_RQ_MASK
+ *               is orred to alternative description.
+ * @retval Void
+void
+tms570_bsp_pin_config_one(uint32_t pin_num_and_fnc)
+  rtems_interrupt_level intlev;
+  uint32_t pin_in_alt;
+  rtems_interrupt_disable(intlev);
+  TMS570_IOMM.KICK_REG0 = tms570_bsp_pinmmr_kick_key0;
+  TMS570_IOMM.KICK_REG1 = tms570_bsp_pinmmr_kick_key1;
+  pin_in_alt = pin_num_and_fnc & TMS570_PIN_IN_ALT_MASK;
+  if ( pin_in_alt & TMS570_PIN_CLEAR_RQ_MASK) {
+    pin_in_alt >>= TMS570_PIN_IN_ALT_SHIFT;
+    if ( pin_in_alt & TMS570_PIN_CLEAR_RQ_MASK ) {
+      tms570_bsp_pin_clear_function(pin_in_alt, TMS570_PIN_FNC_AUTO);
+    } else {
+      tms570_bsp_pin_set_function(pin_in_alt, TMS570_PIN_FNC_AUTO);
+  pin_num_and_fnc &= TMS570_PIN_NUM_FNC_MASK;
+  if ( pin_num_and_fnc & TMS570_PIN_CLEAR_RQ_MASK ) {
+    tms570_bsp_pin_clear_function(pin_num_and_fnc, TMS570_PIN_FNC_AUTO);
+  } else {
+    tms570_bsp_pin_set_function(pin_num_and_fnc, TMS570_PIN_FNC_AUTO);
+  TMS570_IOMM.KICK_REG0 = 0;
+  TMS570_IOMM.KICK_REG1 = 0;
+  rtems_interrupt_enable(intlev);
+ * @brief configure block or whole pin multiplexer
+ * Function change multiplexer content. It is intended for initial
+ * chip setup and does not use locking. If complete reconfiguration
+ * is required at runtime then it is application responsibility
+ * to protect and serialize change with peripherals drivers
+ * and parallel calls
+ * @param[in] pinmmr_values pointer to array with required multiplexer setup
+ * @param[in] reg_start starting register, this allows to configure non-consecutive
+ *                      registers groups found on some MCU family members
+ * @param[in] reg_count number of words in initialization array to set
+ *                      to corresponding registers
+ * @retval Void
+void
+tms570_bsp_pinmmr_config(const uint32_t *pinmmr_values, int reg_start, int reg_count)
+  volatile uint32_t *pinmmrx;
+  const uint32_t *pval;
+  int cnt;
+  if ( reg_count <= 0)
+    return;
+  pinmmrx = (&TMS570_IOMM.PINMUX.PINMMR0) + reg_start;
+  pval = pinmmr_values;
+  cnt = reg_count;
+  do {
+    *pinmmrx = *pinmmrx & *pval;
+    pinmmrx++;
+    pval++;
+  } while( --cnt );
+  cnt = reg_count;
+  do {
+    *pinmmrx = *pval;
+    pinmmrx++;
+    pval++;
+  } while( --cnt );
1.9.1
