[PATCH 03/10] Make rtems_fprintf_plugin() static
Tue Jun 21 13:57:48 UTC 2016
 cpukit/include/rtems/bspIo.h           | 13 -------------
 cpukit/libcsupport/src/print_fprintf.c |  2 +-
 2 files changed, 1 insertion(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/bspIo.h b/cpukit/include/rtems/bspIo.h
index fad4e9d..112dde6 100644
--- a/cpukit/include/rtems/bspIo.h
+++ b/cpukit/include/rtems/bspIo.h
@@ -141,19 +141,6 @@ extern void rtems_putc(char c);
 typedef int (*rtems_print_plugin_t)(void *, const char *format, va_list ap);
- * @brief Reporting Methods fprintf() Plugin
- * This is a standard plug-in to support using fprintf() for output
- * instead of printk().
- * @param[in] context The file stream.
- * @param[in] fmt is a printf()-style format string
- * @return The number of characters printed.
-extern int rtems_fprintf_plugin(void *context, const char *fmt, va_list ap);
 #ifdef __cplusplus
diff --git a/cpukit/libcsupport/src/print_fprintf.c b/cpukit/libcsupport/src/print_fprintf.c
index 757293e..3ff80f7 100644
--- a/cpukit/libcsupport/src/print_fprintf.c
+++ b/cpukit/libcsupport/src/print_fprintf.c
@@ -22,7 +22,7 @@
-int rtems_fprintf_plugin(void *context, const char *fmt, va_list ap)
+static int rtems_fprintf_plugin(void *context, const char *fmt, va_list ap)
   return vfprintf(context, fmt, ap);
1.8.4.5
