[PATCH 10/10] sptests/sp20: Use printer task
Tue Jun 21 13:57:55 UTC 2016
This avoids test failures due to slow output devices.
 testsuites/sptests/sp20/init.c   | 30 +++++++++++++++++--
 testsuites/sptests/sp20/sp20.scn | 36 +++++++++++-----------
 testsuites/sptests/sp20/system.h |  4 ++-
 testsuites/sptests/sp20/task1.c  | 64 ++++++++++++++++++++++++----------------
 4 files changed, 88 insertions(+), 46 deletions(-)
diff --git a/testsuites/sptests/sp20/init.c b/testsuites/sptests/sp20/init.c
index e88c6c2..d3bdab8 100644
--- a/testsuites/sptests/sp20/init.c
+++ b/testsuites/sptests/sp20/init.c
@@ -28,14 +28,40 @@
 const char rtems_test_name[] = "SP 20";
+rtems_printer rtems_test_printer;
+#define BUFFER_COUNT 20
+#define BUFFER_SIZE 100
+static rtems_printer_task_context printer_task;
+static long buffers[ BUFFER_COUNT ][ BUFFER_SIZE / sizeof(long) ];
+void end_of_test( void )
+  rtems_test_printf( TEST_END_STRING );
+  rtems_printer_task_drain( &printer_task );
+  rtems_test_exit( 0 );
 rtems_task Init(
   rtems_task_argument argument
-  uint32_t    index;
+  int               error;
+  uint32_t          index;
   rtems_status_code status;
-  TEST_BEGIN();
+  rtems_printer_task_set_priority( &printer_task, 254 );
+  rtems_printer_task_set_file_descriptor( &printer_task, 1 );
+  rtems_printer_task_set_buffer_table( &printer_task, &buffers[ 0 ][ 0 ] );
+  rtems_printer_task_set_buffer_count( &printer_task, BUFFER_COUNT );
+  rtems_printer_task_set_buffer_size( &printer_task, BUFFER_SIZE );
+  error = rtems_print_printer_task( &rtems_test_printer, &printer_task );
+  rtems_test_assert( error == 0 );
+  rtems_test_printf( TEST_BEGIN_STRING );
   Task_name[ 1 ] =  rtems_build_name( 'T', 'A', '1', ' ' );
   Task_name[ 2 ] =  rtems_build_name( 'T', 'A', '2', ' ' );
diff --git a/testsuites/sptests/sp20/sp20.scn b/testsuites/sptests/sp20/sp20.scn
index d0726f7..f3d7afb 100644
--- a/testsuites/sptests/sp20/sp20.scn
+++ b/testsuites/sptests/sp20/sp20.scn
@@ -1,40 +1,40 @@
-*** TEST 20 ***
+*** BEGIN OF TEST SP 20 ***
 TA1 - rtems_rate_monotonic_create id = 0x42010001
 TA1 - rtems_rate_monotonic_ident id = 0x42010001
-TA1 - (0x2c010001) period 2
+TA1 - (0x42010001) period 2
 TA2 - rtems_rate_monotonic_create id = 0x42010002
 TA2 - rtems_rate_monotonic_ident id = 0x42010002
-TA2 - (0x2c010002) period 2
+TA2 - (0x42010002) period 2
 TA3 - rtems_rate_monotonic_create id = 0x42010003
 TA3 - rtems_rate_monotonic_ident id = 0x42010003
-TA3 - (0x2c010003) period 2
+TA3 - (0x42010003) period 2
 TA4 - rtems_rate_monotonic_create id = 0x42010004
 TA4 - rtems_rate_monotonic_ident id = 0x42010004
-TA4 - (0x2c010004) period 2
+TA4 - (0x42010004) period 2
 TA5 - rtems_rate_monotonic_create id = 0x42010005
 TA5 - rtems_rate_monotonic_ident id = 0x42010005
-TA5 - (0x2c010005) period 100
+TA5 - (0x42010005) period 100
 TA6 - rtems_rate_monotonic_create id = 0x42010006
 TA6 - rtems_rate_monotonic_ident id = 0x42010006
-TA6 - (0x2c010006) period 0
+TA6 - (0x42010006) period 0
 TA5 - PERIODS CHECK OK (1)
 TA5 - PERIODS CHECK OK (2)
 TA5 - PERIODS CHECK OK (3)
 TA5 - PERIODS CHECK OK (4)
 TA5 - PERIODS CHECK OK (5)
-TA6 - Actual: 10  Expected: 10 - OK
-TA6 - Actual: 20  Expected: 20 - OK
-TA6 - Actual: 30  Expected: 30 - OK
-TA6 - Actual: 40  Expected: 40 - OK
-TA6 - Actual: 50  Expected: 50 - OK
-TA6 - Actual: 60  Expected: 60 - OK
-TA6 - Actual: 70  Expected: 70 - OK
-TA6 - Actual: 80  Expected: 80 - OK
-TA6 - Actual: 90  Expected: 90 - OK
-TA6 - Actual: 100  Expected: 100 - OK
+TA6 - Actual: 10 Expected: 10 - OK
+TA6 - Actual: 20 Expected: 20 - OK
+TA6 - Actual: 30 Expected: 30 - OK
+TA6 - Actual: 40 Expected: 40 - OK
+TA6 - Actual: 50 Expected: 50 - OK
+TA6 - Actual: 60 Expected: 60 - OK
+TA6 - Actual: 70 Expected: 70 - OK
+TA6 - Actual: 80 Expected: 80 - OK
+TA6 - Actual: 90 Expected: 90 - OK
+TA6 - Actual: 100 Expected: 100 - OK
 TA5 - PERIODS CHECK OK (6)
 TA5 - PERIODS CHECK OK (7)
 TA5 - PERIODS CHECK OK (8)
 TA5 - PERIODS CHECK OK (9)
 TA5 - PERIODS CHECK OK (10)
-*** END OF TEST 20 ***
+*** END OF TEST SP 20 ***
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index 33d07f7..dfefe4b 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
@@ -38,7 +38,7 @@ void Get_all_counters( void );
 #define CONFIGURE_MICROSECONDS_PER_TICK 100000
-#define CONFIGURE_MAXIMUM_TASKS               7
+#define CONFIGURE_MAXIMUM_TASKS               8
 #define CONFIGURE_MAXIMUM_PERIODS             10
 #define CONFIGURE_INIT_TASK_PRIORITY          10
@@ -58,4 +58,6 @@ TEST_EXTERN struct counters Count;       /* iteration counters */
 TEST_EXTERN struct counters Temporary_count;
 extern rtems_task_priority Priorities[ 7 ];
+void end_of_test( void );
 /* end of include file */
diff --git a/testsuites/sptests/sp20/task1.c b/testsuites/sptests/sp20/task1.c
index 6edfd23..497b4f0 100644
--- a/testsuites/sptests/sp20/task1.c
+++ b/testsuites/sptests/sp20/task1.c
@@ -25,6 +25,19 @@ uint32_t      Periods[7]    = { 0,   2,   2,   2,   2, 100, 0 };
 uint32_t      Iterations[7] = { 0,  50,  50,  50,  50,   1, TA6_ITERATIONS };
 rtems_task_priority Priorities[7] = { 0,   1,   1,   3,   4,   5, 1 };
+static char *name( size_t i, char buf[ 4 ] )
+  rtems_name_to_characters(
+    Task_name[ i ],
+    &buf[ 0 ],
+    &buf[ 1 ],
+    &buf[ 2 ],
+    &buf[ 3 ]
+  buf[ 3 ] = '\0';
+  return &buf[ 0 ];
 rtems_task Task_1_through_6(
@@ -35,22 +48,26 @@ rtems_task Task_1_through_6(
   int               pass;
   uint32_t          failed;
+  char              buf[ 4 ];
   status = rtems_rate_monotonic_create( argument, &rmid );
   directive_failed( status, "rtems_rate_monotonic_create" );
-  put_name( Task_name[ argument ], FALSE );
-  printf( "- rtems_rate_monotonic_create id = 0x%08" PRIxrtems_id "\n", rmid );
+    "%s - rtems_rate_monotonic_create id = 0x%08" PRIxrtems_id "\n",
+    name( argument, buf ),
+    rmid
   status = rtems_rate_monotonic_ident( argument, &test_rmid );
   directive_failed( status, "rtems_rate_monotonic_ident" );
-  printf(
-    "- rtems_rate_monotonic_ident id = 0x%08" PRIxrtems_id "\n",
+    "%s - rtems_rate_monotonic_ident id = 0x%08" PRIxrtems_id "\n",
     test_rmid
   if ( rmid != test_rmid ) {
-    printf(
       "RMID's DO NOT MATCH (0x%" PRIxrtems_id " and 0x%" PRIxrtems_id ")\n",
        rmid,
        test_rmid
@@ -58,9 +75,9 @@ rtems_task Task_1_through_6(
-  printf(
-    "- (0x%08" PRIxrtems_id ") period %" PRIu32 "\n",
+    "%s - (0x%08" PRIxrtems_id ") period %" PRIu32 "\n",
     rmid,
     Periods[ argument ]
@@ -98,12 +115,12 @@ rtems_task Task_1_through_6(
         for( index = 1 ; index <= 4 ; index++ ) {
           if ( Temporary_count.count[ index ] != Iterations[ index ] ) {
-            puts_nocr( "FAIL -- " );
-            put_name ( Task_name[ index ], FALSE );
-            printf   ( " Actual=%" PRIu32 ", Expected=%" PRIu32 "\n",
-                       Temporary_count.count[ index ],
-                       Iterations[ index ]
+              "%s - FAIL - Actual=%" PRIu32 ", Expected=%" PRIu32 "\n",
+              name( index, buf ),
+              Temporary_count.count[ index ],
+              Iterations[ index ]
             failed += 1;
@@ -113,13 +130,10 @@ rtems_task Task_1_through_6(
         pass += 1;
-        printf( "TA5 - PERIODS CHECK OK (%d)\n", pass );
-        fflush( stdout );
+        rtems_test_printf( "TA5 - PERIODS CHECK OK (%d)\n", pass );
         if ( pass == 10 ) {
-          TEST_END();
-          rtems_test_exit( 0 );
+          end_of_test();
@@ -134,27 +148,27 @@ rtems_task Task_1_through_6(
         status = rtems_rate_monotonic_period( rmid, period);
         directive_failed( status, "rtems_rate_monotonic_period of TA6" );
         time[0] = _Watchdog_Ticks_since_boot; /* timestamp */
-        /*printf("%d - %d\n", period, time[0]);*/
+        /*rtems_test_printf("%d - %d\n", period, time[0]);*/
         for (index = 1; index <= TA6_ITERATIONS; index++) {
           period = (index+1)*TA6_PERIOD_FACTOR;
           time[index] = _Watchdog_Ticks_since_boot; /* timestamp */
-          /*printf("%d - %d\n", period, time[index]);*/
+          /*rtems_test_printf("%d - %d\n", period, time[index]);*/
           rtems_interval meas = time[index] - time[index-1];
           period = index*TA6_PERIOD_FACTOR;
-          printf(
             "TA6 - Actual: %" PRIdrtems_interval
               " Expected: %" PRIdrtems_interval,
             meas,
             period
-          if (period == meas) printf(" - OK\n");
-          else                printf(" - FAILED\n");
+          if (period == meas) rtems_test_printf(" - OK\n");
+          else                rtems_test_printf(" - FAILED\n");
       rtems_task_suspend(RTEMS_SELF);
1.8.4.5
