[PATCH] Subject: Add PWM driver for beagle bone black
Punit Vara
punitvara at gmail.com
Tue Jun 21 16:26:31 UTC 2016
This patch adds required definitions, registers definitions and testsuit to
test pwm driver for beagle bone black.
c/src/lib/libbsp/arm/beagle/Makefile.am | 3 +
c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c | 345 ++++++++++++++++++++++++++
c/src/lib/libbsp/shared/include/gpio.h | 11 +
c/src/lib/libcpu/arm/shared/include/am335x.h | 349 ++++++++++++++++++++++++++-
testsuites/samples/Makefile.am | 2 +-
testsuites/samples/configure.ac | 1 +
testsuites/samples/pwm/Makefile.am | 19 ++
testsuites/samples/pwm/init.c | 70 ++++++
testsuites/samples/pwm/pwm.doc | 9 +
testsuites/samples/pwm/pwm.scn | 3 +
10 files changed, 810 insertions(+), 2 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
create mode 100644 testsuites/samples/pwm/Makefile.am
create mode 100644 testsuites/samples/pwm/init.c
create mode 100644 testsuites/samples/pwm/pwm.doc
create mode 100644 testsuites/samples/pwm/pwm.scn
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 20d3092..68bdbd4 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -117,6 +117,9 @@ libbsp_a_SOURCES += misc/i2c.c
# GPIO
libbsp_a_SOURCES += gpio/bbb-gpio.c
+#pwm
+libbsp_a_SOURCES += pwm/bbb-pwm.c
#RTC
libbsp_a_SOURCES += rtc.c
libbsp_a_SOURCES += ../../shared/tod.c
diff --git a/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c b/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
new file mode 100644
index 0000000..a2f1107
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/pwm/bbb-pwm.c
@@ -0,0 +1,345 @@
+/* This file is based on following licence
+ * Copyright (c) 2015, Shabaz, VegetableAvenger
+ * Copyright (c) 2016, Punit Vara
+ * Added clock functions and improved pwm_enable function
+ * All rights reserved.
+ * modification, are permitted provided that the following conditions are met:
+ * Redistributions of source code must retain the above copyright notice, this
+ * list of conditions and the following disclaimer.
+ * Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * Neither the name of BBBIOlib nor the names of its
+ * contributors may be used to endorse or promote products derived from
+ * this software without specific prior written permission.
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+ * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
+ * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include<libcpu/am335x.h>
+#include<stdio.h>
+#include<bsp/gpio.h>
+#include<bsp/bbb-gpio.h>
+#include<bsp.h>
+#define BASE_CLOCK 100000000
+ * @brief This function intilize clock and pinmuxing for pwm sub system.
+ * @param PWMSS_ID It is the instance number of EPWM of pwm sub system.
+void pwm_init(unsigned int baseAddr, unsigned int PWMSS_ID)
+ module_clk_config(PWMSS_ID);
+ EPWMPinMuxSetup();
+ EPWM_clock_enable(baseAddr);
+ pwmss_tbclk_enable(PWMSS_ID);
+ * \brief This function Enables TBCLK(Time Base Clock) for specific
+ * EPWM instance of pwmsubsystem.
+ * \param instance It is the instance number of EPWM of pwmsubsystem.
+void pwmss_tbclk_enable(unsigned int instance)
+ switch(instance)
+ case 0:
+ REG(AM335X_PADCONF_BASE + CONTROL_PWMSS_CTRL) |=
+ BBBIO_PWMSS_CTRL_PWMSS0_TBCLKEN;
+ break;
+ case 1:
+ BBBIO_PWMSS_CTRL_PWMSS1_TBCLKEN;
+ break;
+ case 2:
+ BBBIO_PWMSS_CTRL_PWMSS2_TBCLKEN;
+ break;
+ default:
+ break;
+ * \brief This function Enables pinmuxing for PWM module.
+void EPWMPinMuxSetup(void)
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(9)) = BBB_MUXMODE(4);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(8)) = BBB_MUXMODE(4);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(0)) = BBB_MUXMODE(3);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(1)) = BBB_MUXMODE(3);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(11)) = BBB_MUXMODE(2);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(2);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(6);
+ REG(AM335X_PADCONF_BASE + CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(6);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = BBB_MUXMODE(3);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = BBB_MUXMODE(3);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSX) = BBB_MUXMODE(1);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKX) = BBB_MUXMODE(1);
+ * \brief This functions enables clock for EHRPWM module in PWMSS subsystem.
+ * \param baseAdd It is the Memory address of the PWMSS instance used.
+ * \return None.
+void EPWM_clock_enable(unsigned int baseAdd)
+ REG(baseAdd + PWMSS_CLKCONFIG) |= PWMSS_CLK_EN_ACK;
+ * \brief This function configures the L3 and L4_PER system clocks.
+ * It also configures the system clocks for the specified ePWMSS
+ * instance.
+ * \param instanceNum The instance number of ePWMSS whose system clocks
+ * have to be configured.
+ * 'instanceNum' can take one of the following values:
+ * (0 <= instanceNum <= 2)
+ * \return None.
+void module_clk_config(unsigned int instanceNum)
+ if(0 == instanceNum)
+ REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS0_CLKCTRL) |=
+ CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
+ else if(1 == instanceNum)
+ REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS1_CLKCTRL) |=
+ CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
+ else if(2 == instanceNum)
+ REG(BBBIO_CM_PER_ADDR + CM_PER_EPWMSS2_CLKCTRL) |=
+ CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
+ else
+ * \brief This API enables the particular PWM module.
+ * \param baseAddr Base Address of the PWM Module Registers.
+ * \return None
+void ehrPWM_Enable(unsigned int baseAddr)
+ REG16(baseAddr + EHRPWM_AQCTLA) = 0x2 | (0x3 << 4);
+ REG16(baseAddr + EHRPWM_AQCTLB) = 0x2 | (0x3 << 8);
+ REG16(baseAddr + EHRPWM_TBCNT) = 0;
+ REG16(baseAddr + EHRPWM_TBCTL) |= TBCTL_FREERUN | TBCTL_CTRMODE_UP;
+ * \brief This API disables the HR sub-module.
+ * \return None
+void ehrPWM_Disable(unsigned int baseAddr)
+ REG16(baseAddr + EHRPWM_TBCTL) = 0x3;
+ REG16(baseAddr + EHRPWM_AQCTLA) = 0x1 | ( 0x3 << 4 );
+ REG16(baseAddr + EHRPWM_AQCTLB) = 0x1 | ( 0x3 << 8 );
+/* PWMSS setting
+ * set pulse argument of epwm module
+ * @param PWMID : EPWMSS number , 0~2
+ * @param HZ : pulse HZ
+ * @param dutyA : Duty Cycle in ePWM A
+ * @param dutyB : Duty Cycle in ePWM B
+ * @return : 1 for success , 0 for failed
+ * @example : PWMSS_Setting(0 , 50.0f , 50.0f , 25.0f); // Generate 50HZ pwm in PWM0 ,
+ * // duty cycle is 50% for ePWM0A , 25% for ePWM0B
+ * @Note :
+ * find an number nearst 65535 for TBPRD , to improve duty precision,
+ * Using big TBPRD can increase the range of CMPA and CMPB ,
+ * and it means we can get better precision on duty cycle.
+ * EX : 20.25% duty cycle
+ * on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) , real duty : 20.2496% (12656 /62500)
+ * on TBPRD = 6250 , CMPA = 1265.625 ( .625 rejection), real duty : 20.24% (1265 6250)
+ * on TBPRD = 500 , CMPA = 101.25 ( .25 rejection) , real duty : 20.2% (101/500)
+ * Divisor = CLKDIV * HSPCLKDIV
+ * 1 TBPRD : 10 ns (default)
+ * 65535 TBPRD : 655350 ns
+ * 65535 TBPRD : 655350 * Divisor ns = X TBPRD : Cyclens
+ * accrooding to that , we must find a Divisor value , let X nearest 65535 .
+ * so , Divisor must Nearest Cyclens/655350
+int PWMSS_Setting(unsigned int baseAddr, float HZ, float dutyA, float dutyB)
+ unsigned int z,p,y;
+ int param_error =1;
+ if(HZ < 0)
+ param_error =0;
+ if(dutyA < 0.0f || dutyA > 100.0f || dutyB < 0.0f || dutyB > 100.0f)
+ param_error = 0;
+ if(param_error == 0) {
+ printf("ERROR in parameter \n");
+ dutyA /= 100.0f;
+ dutyB /= 100.0f;
+ /*Compute necessary TBPRD*/
+ float Cyclens = 0.0f;
+ float Divisor =0;
+ int i,j;
+ const float CLKDIV_div[] = {1.0,2.0,4.0,8.0,16.0,32.0,64.0,128.0};
+ const float HSPCLKDIV_div[] = {1.0, 2.0, 4.0, 6.0, 8.0, 10.0,12.0, 14.0};
+ int NearCLKDIV =7;
+ int NearHSPCLKDIV =7;
+ int NearTBPRD =0;
+ Cyclens = 1000000000.0f / HZ; /** 10^9 /Hz compute time per cycle (ns)
+ Divisor = (Cyclens / 655350.0f); /** am335x provide (128* 14) divider,
+ * and per TBPRD means 10ns when divider
+ * and max TBPRD is 65535 so max cycle
+ * is 128 * 8 * 14 * 65535 * 10ns
+ if(Divisor > (128 * 14)) {
+ printf("Can't generate %f HZ",HZ);
+ return 0;
+ else {
+ for (i=0;i<8;i++) {
+ for(j=0 ; j<8; j++) {
+ if((CLKDIV_div[i] * HSPCLKDIV_div[j]) < (CLKDIV_div[NearCLKDIV]
+ * HSPCLKDIV_div[NearHSPCLKDIV]) && (CLKDIV_div[i] * HSPCLKDIV_div[j] > Divisor)) {
+ NearCLKDIV = i;
+ NearHSPCLKDIV = j;
+ printf("BBBIO CLKDIV = %d and HSPCLKDIV = %d\n",NearCLKDIV,NearHSPCLKDIV);
+ REG16(baseAddr + EHRPWM_TBCTL) &= ~(TBCTL_CLKDIV_MASK | TBCTL_HSPCLKDIV_MASK);
+ REG16(baseAddr + EHRPWM_TBCTL) = (REG16(baseAddr + EHRPWM_TBCTL) &
+ (~EHRPWM_TBCTL_CLKDIV)) | ((NearCLKDIV << TBCTL_CLKDIV_SHIFT) & EHRPWM_TBCTL_CLKDIV);
+ (~EHRPWM_TBCTL_HSPCLKDIV)) | ((NearHSPCLKDIV <<
+ TBCTL_HSPCLKDIV_SHIFT) & EHRPWM_TBCTL_HSPCLKDIV);
+ NearTBPRD = (Cyclens / (10.0 * CLKDIV_div[NearCLKDIV] * HSPCLKDIV_div[NearHSPCLKDIV]));
+ (~EHRPWM_PRD_LOAD_SHADOW_MASK)) | (((bool)EHRPWM_SHADOW_WRITE_DISABLE <<
+ EHRPWM_TBCTL_PRDLD_SHIFT) & EHRPWM_PRD_LOAD_SHADOW_MASK);
+ (~EHRPWM_COUNTER_MODE_MASK)) | (((unsigned int)EHRPWM_COUNT_UP <<
+ EHRPWM_TBCTL_CTRMODE_SHIFT) & EHRPWM_COUNTER_MODE_MASK);
+ printf("writing TBPRD = %x \n",NearTBPRD);
+ /*setting clock divider and freeze time base*/
+ // configure_tbclk(baseAddr, HZ);
+ REG16(baseAddr + EHRPWM_CMPB) = (unsigned short)((float)(NearTBPRD) * dutyB);
+ z = REG16(baseAddr + EHRPWM_CMPB);
+ printk("read CMPB = %x\t",z);
+ REG16(baseAddr + EHRPWM_CMPA) = (unsigned short)((float)(NearTBPRD) * dutyA);
+ p = REG16(baseAddr + EHRPWM_CMPA);
+ printk("read CMPA = %x\n",p);
+ REG16(baseAddr + EHRPWM_TBPRD) = (unsigned short)NearTBPRD;
+ y = REG16(baseAddr + EHRPWM_TBPRD);
+ printk("TBPRD read = %x \n",y);
+ printf("\nfinished setting \n");
+ return 1;
+int PWMSS_TB_clock_check(unsigned int PWMSS_ID)
+ unsigned int reg_value,value;
+ /*control module check*/
+ reg_value = REG(BBBIO_CONTROL_MODULE + BBBIO_PWMSS_CTRL);
+ value = reg_value & (1 << PWMSS_ID);
+ printf("\n PWMSS_CTRL = %d and reg_value = %d \n",value,reg_value);
+ return (reg_value & (1 << PWMSS_ID));
diff --git a/c/src/lib/libbsp/shared/include/gpio.h b/c/src/lib/libbsp/shared/include/gpio.h
index 7d8f67b..2a89f1d 100644
--- a/c/src/lib/libbsp/shared/include/gpio.h
+++ b/c/src/lib/libbsp/shared/include/gpio.h
@@ -947,6 +947,17 @@ extern rtems_status_code rtems_gpio_bsp_disable_interrupt(
+extern void pwmss_tbclk_enable(unsigned int instance);
+extern void EPWM_clock_enable(unsigned int baseAdd);
+extern void module_clk_config(unsigned int instanceNum);
+extern void EPWMPinMuxSetup(void);
+extern int PWMSS_Setting(unsigned int baseAddr, float HZ, float dutyA, float dutyB);
+extern void ehrPWM_Disable(unsigned int baseAddr);
+extern void ehrPWM_Enable(unsigned int baseAddr);
+extern int PWMSS_TB_clock_check(unsigned int PWMSS_ID);
+extern void pwm_init(unsigned int baseAddr, unsigned int PWMSS_ID);
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index 2009cef..b89a188 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -467,4 +467,351 @@
#define AM335X_CONF_EXT_WAKEUP 0xA00
#define AM335X_CONF_RTC_KALDO_ENN 0xA04
#define AM335X_CONF_USB0_DRVVBUS 0xA1C
-#define AM335X_CONF_USB1_DRVVBUS 0xA34
\ No newline at end of file
+#define AM335X_CONF_USB1_DRVVBUS 0xA34
+/* Added by punit vara
+ PWMSS register definitions */
+#define PWMSS_CLOCK_CONFIG 0x08
+#define PWMSS_CLOCK_STATUS 0x0C
+#define PWMSS_ECAP_CLK_EN_ACK_SHIFT 0x00
+#define PWMSS_ECAP_CLK_STOP_ACK_SHIFT 0x01
+#define PWMSS_EHRPWM_CLK_EN_ACK_SHIFT 0x08
+#define PWMSS_EHRPWM_CLK_STOP_ACK_SHIFT 0x09
+#define PWMSS_ECAP_CLK_EN_ACK 0x01
+#define PWMSS_ECAP_CLK_STOP_ACK 0x02
+#define PWMSS_EHRPWM_CLK_EN_ACK 0x100
+#define PWMSS_EHRPWM_CLK_STOP_ACK 0x200
+/** @brief Base addresses of PWMSS memory mapped registers. */
+#define SOC_PWMSS0_REGS (0x48300000)
+#define SOC_PWMSS1_REGS (0x48302000)
+#define SOC_PWMSS2_REGS (0x48304000)
+#define SOC_ECAP_REGS (0x00000100)
+#define SOC_EQEP_REGS (0x00000180)
+#define SOC_EPWM_REGS (0x00000200)
+#define SOC_ECAP_0_REGS (SOC_PWMSS0_REGS + SOC_ECAP_REGS)
+#define SOC_ECAP_1_REGS (SOC_PWMSS1_REGS + SOC_ECAP_REGS)
+#define SOC_ECAP_2_REGS (SOC_PWMSS2_REGS + SOC_ECAP_REGS)
+#define SOC_EQEP_0_REGS (SOC_PWMSS0_REGS + SOC_EQEP_REGS)
+#define SOC_EQEP_1_REGS (SOC_PWMSS1_REGS + SOC_EQEP_REGS)
+#define SOC_EQEP_2_REGS (SOC_PWMSS2_REGS + SOC_EQEP_REGS)
+#define SOC_EPWM_0_REGS (SOC_PWMSS0_REGS + SOC_EPWM_REGS)
+#define SOC_EPWM_1_REGS (SOC_PWMSS1_REGS + SOC_EPWM_REGS)
+#define SOC_EPWM_2_REGS (SOC_PWMSS2_REGS + SOC_EPWM_REGS)
+#define CONTROL_PWMSS_CTRL (0x664)
+#define CONTROL_PWMSS_CTRL_PWMSS0_TBCLKEN (0x00000001u)
+#define CONTROL_PWMSS_CTRL_PWMMS1_TBCLKEN (0x00000002u)
+#define CONTROL_PWMSS_CTRL_PWMSS2_TBCLKEN (0x00000004u)
+#define SOC_PRCM_REGS (0x44E00000)
+#define CM_PER_EPWMSS0_CLKCTRL (0xd4)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST (0x00030000u)
+#define CM_PER_EPWMSS1_CLKCTRL (0xcc)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST (0x00030000u)
+/* TBCTL */
+#define EHRPWM_TBCTL_FREE_SOFT (0xC000u)
+#define EHRPWM_TBCTL_FREE_SOFT_SHIFT (0x000Eu)
+#define EHRPWM_TBCTL_PHSDIR (0x2000u)
+#define EHRPWM_TBCTL_PHSDIR_SHIFT (0x000Du)
+#define EHRPWM_TBCTL_CLKDIV (0x1C00u)
+#define EHRPWM_TBCTL_CLKDIV_SHIFT (0x000Au)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY1 (0x0000u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY2 (0x0001u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY4 (0x0002u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY8 (0x0003u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY16 (0x0004u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY32 (0x0005u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY64 (0x0006u)
+#define EHRPWM_TBCTL_CLKDIV_DIVBY128 (0x0007u)
+#define EHRPWM_TBCTL_HSPCLKDIV (0x0380u)
+#define EHRPWM_TBCTL_HSPCLKDIV_SHIFT (0x0007u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY1 (0x0000u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY2 (0x0001u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY4 (0x0002u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY6 (0x0003u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY8 (0x0004u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY10 (0x0005u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY12 (0x0006u)
+#define EHRPWM_TBCTL_HSPCLKDIV_DIVBY14 (0x0007u)
+#define EHRPWM_TBCTL_SWFSYNC (0x0040u)
+#define EHRPWM_TBCTL_SWFSYNC_SHIFT (0x0006u)
+#define EHRPWM_TBCTL_SYNCOSEL (0x0030u)
+#define EHRPWM_TBCTL_SYNCOSEL_SHIFT (0x0004u)
+#define EHRPWM_TBCTL_SYNCOSEL_EPWMXSYNCI (0x0000u)
+#define EHRPWM_TBCTL_SYNCOSEL_TBCTRZERO (0x0001u)
+#define EHRPWM_TBCTL_SYNCOSEL_TBCTRCMPB (0x0002u)
+#define EHRPWM_TBCTL_SYNCOSEL_DISABLE (0x0003u)
+#define EHRPWM_TBCTL_PRDLD (0x0008u)
+#define EHRPWM_TBCTL_PRDLD_SHIFT (0x0003u)
+#define EHRPWM_TBCTL_PHSEN (0x0004u)
+#define EHRPWM_TBCTL_PHSEN_SHIFT (0x0002u)
+#define EHRPWM_TBCTL_CTRMODE (0x0003u)
+#define EHRPWM_TBCTL_CTRMODE_SHIFT (0x0000u)
+#define EHRPWM_TBCTL_CTRMODE_UP (0x0000u)
+#define EHRPWM_TBCTL_CTRMODE_DOWN (0x0001u)
+#define EHRPWM_TBCTL_CTRMODE_UPDOWN (0x0002u)
+#define EHRPWM_TBCTL_CTRMODE_STOPFREEZE (0x0003u)
+/* TBPRD */
+#define EHRPWM_TBPRD_TBPRD (0xFFFFu)
+#define EHRPWM_TBPRD_TBPRD_SHIFT (0x0000u)
+/* CMPA */
+#define EHRPWM_CMPA_CMPA (0xFFFFu)
+#define EHRPWM_CMPA_CMPA_SHIFT (0x0000u)
+/* CMPB */
+#define EHRPWM_CMPB_CMPB (0xFFFFu)
+#define EHRPWM_CMPB_CMPB_SHIFT (0x0000u)
+/* REVID */
+#define EHRPWM_REVID_REV (0xFFFFFFFFu)
+#define EHRPWM_REVID_REV_SHIFT (0x00000000u)
+#define EHRPWM_TBCTL (0x0)
+#define EHRPWM_TBSTS (0x2)
+#define EHRPWM_TBPHSHR (0x4)
+#define EHRPWM_TBPHS (0x6)
+#define EHRPWM_TBCTR (0x8)
+#define EHRPWM_TBPRD (0xA)
+#define EHRPWM_CMPCTL (0xE)
+#define EHRPWM_CMPAHR (0x10)
+#define EHRPWM_CMPA (0x12)
+#define EHRPWM_CMPB (0x14)
+#define EHRPWM_AQCTLA (0x16)
+#define EHRPWM_AQCTLB (0x18)
+#define EHRPWM_AQSFRC (0x1A)
+#define EHRPWM_AQCSFRC (0x1C)
+#define EHRPWM_DBCTL (0x1E)
+#define EHRPWM_DBRED (0x20)
+#define EHRPWM_DBFED (0x22)
+#define EHRPWM_TZSEL (0x24)
+#define EHRPWM_TZCTL (0x28)
+#define EHRPWM_TZEINT (0x2A)
+#define EHRPWM_TZFLG (0x2C)
+#define EHRPWM_TZCLR (0x2E)
+#define EHRPWM_TZFRC (0x30)
+#define EHRPWM_ETSEL (0x32)
+#define EHRPWM_ETPS (0x34)
+#define EHRPWM_ETFLG (0x36)
+#define EHRPWM_ETCLR (0x38)
+#define EHRPWM_ETFRC (0x3A)
+#define EHRPWM_PCCTL (0x3C)
+#define EHRPWM_HRCNFG (0x1040)
+/* TB Period load */
+#define EHRPWM_PRD_LOAD_SHADOW_MASK EHRPWM_TBCTL_PRDLD
+/* Counter mode */
+#define EHRPWM_COUNTER_MODE_MASK EHRPWM_TBCTL_CTRMODE
+#define EHRPWM_COUNT_UP (EHRPWM_TBCTL_CTRMODE_UP << \
+#define EHRPWM_COUNT_DOWN (EHRPWM_TBCTL_CTRMODE_DOWN << \
+#define EHRPWM_COUNT_UP_DOWN (EHRPWM_TBCTL_CTRMODE_UPDOWN << \
+#define EHRPWM_COUNT_STOP (EHRPWM_TBCTL_CTRMODE_STOPFREEZE << \
+/* Synchronization */
+#define EHRPWM_SYNC_ENABLE EHRPWM_TBCTL_PHSEN
+//#define EHRPWM_SW_FORCED_SYNC 0x1
+#define EHRPWM_SYNCOUT_MASK EHRPWM_TBCTL_SYNCOSEL
+#define EHRPWM_SYNCOUT_SYNCIN (EHRPWM_TBCTL_SYNCOSEL_EPWMXSYNCI << \
+ EHRPWM_TBCTL_SYNCOSEL_SHIFT)
+#define EHRPWM_SYNCOUT_COUNTER_EQUAL_ZERO (EHRPWM_TBCTL_SYNCOSEL_TBCTRZERO << \
+#define EHRPWM_SYNCOUT_COUNTER_EQUAL_COMPAREB (EHRPWM_TBCTL_SYNCOSEL_TBCTRCMPB << \
+#define EHRPWM_SYNCOUT_DISABLE (EHRPWM_TBCTL_SYNCOSEL_DISABLE << \
+/* Shadow */
+#define EHRPWM_SHADOW_WRITE_ENABLE 0x0
+#define EHRPWM_SHADOW_WRITE_DISABLE 0x1
+/* Time base clock */
+#define EHRPWM_TBCTL_CLKDIV_1 (0x0001u)
+#define EHRPWM_TBCTL_CLKDIV_2 (0x0002u)
+#define EHRPWM_TBCTL_CLKDIV_4 (0x0004u)
+#define EHRPWM_TBCTL_CLKDIV_8 (0x0008u)
+#define EHRPWM_TBCTL_CLKDIV_16 (0x0010u)
+#define EHRPWM_TBCTL_CLKDIV_32 (0x0020u)
+#define EHRPWM_TBCTL_CLKDIV_64 (0x0040u)
+#define EHRPWM_TBCTL_CLKDIV_128 (0x0080u)
+#define EHRPWM_TBCTL_HSPCLKDIV_1 (0x0001u)
+#define EHRPWM_TBCTL_HSPCLKDIV_2 (0x0002u)
+#define EHRPWM_TBCTL_HSPCLKDIV_4 (0x0004u)
+#define EHRPWM_TBCTL_HSPCLKDIV_6 (0x0006u)
+#define EHRPWM_TBCTL_HSPCLKDIV_8 (0x0008u)
+#define EHRPWM_TBCTL_HSPCLKDIV_10 (0x000Au)
+#define EHRPWM_TBCTL_HSPCLKDIV_12 (0x000Cu)
+#define EHRPWM_TBCTL_HSPCLKDIV_14 (0x000Eu)
+/* Count direction after sync */
+#define EHRPWM_COUNT_DOWN_AFTER_SYNC 0x0
+#define EHRPWM_COUNT_UP_AFTER_SYNC 0x1
+/* Counter Compare */
+#define EHRPWM_SHADOW_A_EMPTY (0x0 << EHRPWM_CMPCTL_SHDWAFULL_SHIFT)
+#define EHRPWM_SHADOW_A_FULL (EHRPWM_CMPCTL_SHDWAFULL)
+#define EHRPWM_SHADOW_B_EMPTY (0x0 << EHRPWM_CMPCTL_SHDWBFULL_SHIFT)
+#define EHRPWM_SHADOW_B_FULL (EHRPWM_CMPCTL_SHDWBFULL)
+#define EHRPWM_CMPCTL_NOT_OVERWR_SH_FL 0x0
+#define EHRPWM_CMPCTL_OVERWR_SH_FL 0x1
+/* Compare register load */
+#define EHRPWM_COMPB_LOAD_MASK EHRPWM_CMPCTL_LOADBMODE
+#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_ZERO (EHRPWM_CMPCTL_LOADBMODE_TBCTRZERO << \
+ EHRPWM_CMPCTL_LOADBMODE_SHIFT)
+#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_PERIOD (EHRPWM_CMPCTL_LOADBMODE_TBCTRPRD << \
+#define EHRPWM_COMPB_LOAD_COUNT_EQUAL_ZERO_OR_PERIOD \
+ (EHRPWM_CMPCTL_LOADBMODE_ZEROORPRD << \
+#define EHRPWM_COMPB_NO_LOAD (EHRPWM_CMPCTL_LOADBMODE_FREEZE << \
+#define EHRPWM_COMPA_LOAD_MASK EHRPWM_CMPCTL_LOADAMODE
+#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_ZERO (EHRPWM_CMPCTL_LOADAMODE_TBCTRZERO << \
+ EHRPWM_CMPCTL_LOADAMODE_SHIFT)
+#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_PERIOD (EHRPWM_CMPCTL_LOADAMODE_TBCTRPRD << \
+#define EHRPWM_COMPA_LOAD_COUNT_EQUAL_ZERO_OR_PERIOD \
+ (EHRPWM_CMPCTL_LOADAMODE_ZEROORPRD << \
+#define EHRPWM_COMPA_NO_LOAD (EHRPWM_CMPCTL_LOADAMODE_FREEZE << \
+#define CM_PER_EPWMSS2_CLKCTRL (0xd8)
+/* EPWMSS1_CLKCTRL */
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_DISABLE (0x3u)
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_IDLE (0x2u)
+#define CM_PER_EPWMSS1_CLKCTRL_IDLEST_TRANS (0x1u)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_SHIFT (0x00000000u)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_DISABLED (0x0u)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_RESERVED (0x3u)
+#define CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_RESERVED_1 (0x1u)
+/* EPWMSS0_CLKCTRL */
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_DISABLED (0x3u)
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_IDLE (0x2u)
+#define CM_PER_EPWMSS0_CLKCTRL_IDLEST_TRANS (0x1u)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_SHIFT (0x00000000u)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_DISABLE (0x0u)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_RESERVED (0x3u)
+#define CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_RESERVED_1 (0x1u)
+/* EPWMSS2_CLKCTRL */
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST (0x00030000u)
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_DISABLE (0x3u)
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC (0x0u)
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_IDLE (0x2u)
+#define CM_PER_EPWMSS2_CLKCTRL_IDLEST_TRANS (0x1u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE (0x00000003u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_SHIFT (0x00000000u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_DISABLED (0x0u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_RESERVED (0x3u)
+#define CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_RESERVED_1 (0x1u)
+#define CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4))
+#define CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4))
+#define EHRPWM_TBCNT 0x8
+#define BBBIO_CONTROL_MODULE 0x44e10000
+#define BBBIO_PWMSS_CTRL 0x664
+#define BBBIO_CM_PER_ADDR 0x44e00000
+#define BBBIO_CM_PER_EPWMSS1_CLKCTRL 0xcc
+#define BBBIO_CM_PER_EPWMSS0_CLKCTRL 0xd4
+#define BBBIO_CM_PER_EPWMSS2_CLKCTRL 0xd8
+#define PWMSS0_MMAP_ADDR 0x48300000
+#define PWMSS1_MMAP_ADDR 0x48302000
+#define PWMSS2_MMAP_ADDR 0x48304000
+#define BBBIO_PWMSS_CTRL_PWMSS0_TBCLKEN (0x00000001u)
+#define BBBIO_PWMSS_CTRL_PWMSS1_TBCLKEN (0x00000002u)
+#define BBBIO_PWMSS_CTRL_PWMSS2_TBCLKEN (0x00000004u)
+#define PWMSS_CLKCONFIG 0x8
+#define PWMSS_CLK_EN_ACK 0x100
+#define TBCTL_CLKDIV (0x1C00u)
+#define TBCTL_CLKDIV_SHIFT (0x000Au)
+#define TBCTL_CLKDIV_DIVBY1 (0x0000u)
+#define TBCTL_CLKDIV_DIVBY2 (0x0001u)
+#define TBCTL_CLKDIV_DIVBY4 (0x0002u)
+#define TBCTL_CLKDIV_DIVBY8 (0x0003u)
+#define TBCTL_CLKDIV_DIVBY16 (0x0004u)
+#define TBCTL_CLKDIV_DIVBY32 (0x0005u)
+#define TBCTL_CLKDIV_DIVBY64 (0x0006u)
+#define TBCTL_CLKDIV_DIVBY128 (0x0007u)
+#define TBCTL_HSPCLKDIV (0x0380u)
+#define TBCTL_HSPCLKDIV_SHIFT (0x0007u)
+#define TBCTL_HSPCLKDIV_DIVBY1 (0x0000u)
+#define TBCTL_HSPCLKDIV_DIVBY2 (0x0001u)
+#define TBCTL_HSPCLKDIV_DIVBY4 (0x0002u)
+#define TBCTL_HSPCLKDIV_DIVBY6 (0x0003u)
+#define TBCTL_HSPCLKDIV_DIVBY8 (0x0004u)
+#define TBCTL_HSPCLKDIV_DIVBY10 (0x0005u)
+#define TBCTL_HSPCLKDIV_DIVBY12 (0x0006u)
+#define TBCTL_HSPCLKDIV_DIVBY14 (0x0007u)
+#define TBCTL_CLKDIV(x) ((x) << 10)
+#define TBCTL_CLKDIV_MASK (3 << 10)
+#define TBCTL_HSPCLKDIV(x) ((x) << 7)
+#define TBCTL_HSPCLKDIV_MASK (3 << 7)
+#define TBCTL_FREERUN (2 << 14)
+#define TBCTL_CTRMODE_UP (0 << 0)
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 374617b..70ebe57 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -1,6 +1,6 @@
ACLOCAL_AMFLAGS = -I ../aclocal
-_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio
+_SUBDIRS = hello capture ticker base_sp unlimited minimum fileio pwm
if MPTESTS
## base_mp is a sample multiprocessing test
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index 91a3661..72a64a0 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -62,6 +62,7 @@ AC_CHECK_SIZEOF([time_t])
AC_CONFIG_FILES([Makefile
base_sp/Makefile
hello/Makefile
+pwm/Makefile
loopback/Makefile
minimum/Makefile
fileio/Makefile
diff --git a/testsuites/samples/pwm/Makefile.am b/testsuites/samples/pwm/Makefile.am
index 0000000..85d0fc1
--- /dev/null
+++ b/testsuites/samples/pwm/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = pwm
+pwm_SOURCES = init.c
+dist_rtems_tests_DATA = pwm.scn
+dist_rtems_tests_DATA += pwm.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+LINK_OBJS = $(pwm_OBJECTS)
+LINK_LIBS = $(pwm_LDLIBS)
+hello$(EXEEXT): $(pwm_OBJECTS) $(pwm_DEPENDENCIES)
+ @rm -f pwm$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/samples/pwm/init.c b/testsuites/samples/pwm/init.c
index 0000000..0814720
--- /dev/null
+++ b/testsuites/samples/pwm/init.c
@@ -0,0 +1,70 @@
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include<rtems/test.h>
+#include<bsp.h>
+#include<stdio.h>
+#include<stdlib.h>
+const char rtems_test_name[] = "Punit PWM test GSOC 2016";
+rtems_printer rtems_test_printer;
+static void inline delay_sec(int sec)
+ rtems_task_wake_after(sec*rtems_clock_get_ticks_per_second());
+rtems_task Init(rtems_task_argument argument);
+rtems_task Init(
+ rtems_task_argument ignored
+ rtems_test_begin();
+ printf("Starting PWM Testing");
+/* Initialization PWM API*/
+rtems_gpio_initialize();
+pwm_init(PWMSS2_MMAP_ADDR, 2);
+PWMSS_TB_clock_check(2);
+ float PWM_HZ = 1.0f ;
+ float duty_A = 50.0f ; /* 50% Duty cycle for PWM 2_A output */
+ const float duty_B = 50.0f ; /* 50% Duty cycle for PWM 2_B output*/
+ for(PWM_HZ=1; PWM_HZ <=100000000; PWM_HZ= PWM_HZ*3)
+ printf("\n Generating frequency : %f\n",PWM_HZ);
+ PWMSS_Setting(SOC_EPWM_2_REGS, PWM_HZ ,duty_A , duty_B);
+ printf("PWM enable for 10s ....\n");
+ ehrPWM_Enable(SOC_EPWM_2_REGS);
+ delay_sec(10);
+ ehrPWM_Disable(SOC_EPWM_2_REGS);
+ printf("close\n");
+/* NOTICE: the clock driver is enabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (2 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/samples/pwm/pwm.doc b/testsuites/samples/pwm/pwm.doc
index 0000000..9812864
--- /dev/null
+++ b/testsuites/samples/pwm/pwm.doc
@@ -0,0 +1,9 @@
+# COPYRIGHT (c) 1989-1999.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
diff --git a/testsuites/samples/pwm/pwm.scn b/testsuites/samples/pwm/pwm.scn
index 0000000..057ab6e
--- /dev/null
+++ b/testsuites/samples/pwm/pwm.scn
@@ -0,0 +1,3 @@
+*** GPIO TEST ***
+Gpio Testing
+*** END OF GPIO TEST ***
2.7.1
