[PATCH] pc386: Add virtio network driver
Pavel Pisa ppisa4lists at pikron.com
Wed Jun 22 07:52:00 UTC 2016
Hello Jin-Hyun,
On Wednesday 22 of June 2016 04:10:00 Jinhyun wrote:
> Thanks for the comments.
> We are trying to either use the compiler memory barrier as you people
> suggested or simply define the variables as volatile. We plan to repost the
> revised patch in a week.
> Since new patch would be no longer architecture-independent, we are
> thinking to locate the files at c/src/lib/ilbbsp/shared/. Hope this makes
> sense.
> Thanks,
> Jin-Hyun
that is great. I like much possibility that it could be used
with ARM or PowerPC in longer term perspective. I expect that
it may require some minor tweaks but use of bsp shared location
prevents code duplication.
Best wishes,
             Pavel
