tester failures
Thu Jun 23 15:24:51 UTC 2016
I also had 10 new timeouts. I'll build a clean head and compare results..
On Thu, Jun 23, 2016 at 11:23 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I ran tester for sis last night after a rebase and see 4 new failures.
> I have some local changes, but I suspect the failures affect the
> vanilla HEAD too. log snippets below:
>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/libtests/mghttpd01/mghttpd01.exe
> ] *** BEGIN OF TEST MGHTTPD 1 ***
> ] Loading tarfs image ... successful
> ] === Get the index.html from second Mongoose instance:
> ] HTTP/1.1 200 OK
> ] Date: Fri, 01 Jan 1988 00:00:00 GMT
> ] Last-Modified: Fri, 01 Jan 1988 00:0Unexpected trap ( 9) at address 0x02026EB8
> ] data access exception at 0x0000000C
>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/psxtests/psxualarm/psxualarm.exe
> ] *** BEGIN OF TEST PSXUALARM ***
> ] Init's ID is 0x0b010001
> ] Init: ualarm in 500000 us
> ] Init: Unblock SIGALRM
> ] Init: clear ualarm with 0, 0
> ] Unexpected trap ( 9) at address 0x0200C8D8
> ] data access exception at 0x00000008
> Result: failed     Time: 0:00:01.058878 psxualarm.exe
>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/sptests/sp12/sp12.exe
> ] *** BEGIN OF TEST SP 12 ***
> ] INIT - Forward priority queue test
> ] PRI1 - rtems_semaphore_obtain - wait forever on SM2
> ] PRI2 - rtems_semaphore_obtain - wait forever on SM2
> ] PRI3 - rtems_semaphore_obtain - wait forever on SM2
> ] PRI4 - rtems_semaphore_obtain - wait forever on SM2
> ] PRI5 - rtems_semaphore_obtain - wait forever on SM2
> ] INIT - Backward priority queue test
> ] Unexpected trap ( 2) at address 0x00000000
> ] illegal instruction
> Result: failed     Time: 0:00:01.018473 sp12.exe
>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/sptests/spintrcritical06/spintrcritical06.exe
> ] *** BEGIN OF TEST SPINTRCRITICAL 6 ***
> ] Init - Trying to generate semaphore release from ISR while blocking
> ] Init - There is no way for the test to know if it hits the case
> ] Init - Variation is: Priority/Restart Search Task (Forward)
> ] Unexpected trap ( 9) at address 0x0200D1D4
> Result: failed     Time: 0:00:01.061426 spintrcritical06.exe
