tester failures
Thu Jun 23 16:04:40 UTC 2016
Nevermind! The problems appear to be in my changes. Guess I found my
own bugs to fix.
On Thu, Jun 23, 2016 at 11:24 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I also had 10 new timeouts. I'll build a clean head and compare results..
> On Thu, Jun 23, 2016 at 11:23 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> I ran tester for sis last night after a rebase and see 4 new failures.
>> I have some local changes, but I suspect the failures affect the
>> vanilla HEAD too. log snippets below:
>>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/libtests/mghttpd01/mghttpd01.exe
>> ] *** BEGIN OF TEST MGHTTPD 1 ***
>> ] Loading tarfs image ... successful
>> ] === Get the index.html from second Mongoose instance:
>> ] HTTP/1.1 200 OK
>> ] Date: Fri, 01 Jan 1988 00:00:00 GMT
>> ] Last-Modified: Fri, 01 Jan 1988 00:0Unexpected trap ( 9) at address 0x02026EB8
>> ] data access exception at 0x0000000C
>>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/psxtests/psxualarm/psxualarm.exe
>> ] *** BEGIN OF TEST PSXUALARM ***
>> ] Init's ID is 0x0b010001
>> ] Init: ualarm in 500000 us
>> ] Init: Unblock SIGALRM
>> ] Init: clear ualarm with 0, 0
>> ] Unexpected trap ( 9) at address 0x0200C8D8
>> ] data access exception at 0x00000008
>> Result: failed     Time: 0:00:01.058878 psxualarm.exe
>>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/sptests/sp12/sp12.exe
>> ] *** BEGIN OF TEST SP 12 ***
>> ] INIT - Forward priority queue test
>> ] PRI1 - rtems_semaphore_obtain - wait forever on SM2
>> ] PRI2 - rtems_semaphore_obtain - wait forever on SM2
>> ] PRI3 - rtems_semaphore_obtain - wait forever on SM2
>> ] PRI4 - rtems_semaphore_obtain - wait forever on SM2
>> ] PRI5 - rtems_semaphore_obtain - wait forever on SM2
>> ] INIT - Backward priority queue test
>> ] Unexpected trap ( 2) at address 0x00000000
>> ] illegal instruction
>> Result: failed     Time: 0:00:01.018473 sp12.exe
>>> run: /home/gedare/install/bin/sparc-rtems4.12-run -a -nouartrx ../../builds/b-sis/sparc-rtems4.12/c/sis/testsuites/sptests/spintrcritical06/spintrcritical06.exe
>> ] *** BEGIN OF TEST SPINTRCRITICAL 6 ***
>> ] Init - Trying to generate semaphore release from ISR while blocking
>> ] Init - There is no way for the test to know if it hits the case
>> ] Init - Variation is: Priority/Restart Search Task (Forward)
>> ] Unexpected trap ( 9) at address 0x0200D1D4
>> Result: failed     Time: 0:00:01.061426 spintrcritical06.exe
