Beagle bone black BSP broken
punit vara
punitvara at gmail.com
Thu Jun 23 20:55:22 UTC 2016
Recently I updated rtems from mainline repo. and tried to build BBB
BSP but got following errors. It seems BSP is broken. Up to 17th June
I was successfully able to compile BSP.
../../../../../../../../../../rtems-src/c/src/lib/libbsp/arm/beagle/console/console-config.c:151:1:
error: unknown type name 'BSP_output_char_function_type'
BSP_output_char_function_type BSP_output_char = _BSP_put_char;
../../../../../../../../../../rtems-src/c/src/lib/libbsp/arm/beagle/console/console-config.c:151:49:
warning: initialization makes integer from pointer without a cast
[-Wint-conversion]
../../../../../../../../../../rtems-src/c/src/lib/libbsp/arm/beagle/console/console-config.c:153:1:
error: unknown type name 'BSP_polling_getchar_function_type'
BSP_polling_getchar_function_type BSP_poll_char = _BSP_get_char;
../../../../../../../../../../rtems-src/c/src/lib/libbsp/arm/beagle/console/console-config.c:153:51:
[-Wint-conversion]
Can you look into this please?
Thank you,
Punit Vara
