[PATCH 03/27] testsuite: Add test for getnameinfo().
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 24 09:38:22 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 testsuites/libtests/Makefile.am                   |   1 +
 testsuites/libtests/configure.ac                  |   1 +
 testsuites/libtests/networking01/Makefile.am      |  22 +++
 testsuites/libtests/networking01/init.c           | 161 ++++++++++++++++++++++
 testsuites/libtests/networking01/networking01.doc |  26 ++++
 testsuites/libtests/networking01/networking01.scn |   9 ++
 6 files changed, 220 insertions(+)
 create mode 100644 testsuites/libtests/networking01/Makefile.am
 create mode 100644 testsuites/libtests/networking01/init.c
 create mode 100644 testsuites/libtests/networking01/networking01.doc
 create mode 100644 testsuites/libtests/networking01/networking01.scn
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index d775c77..4eae14e 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -41,6 +41,7 @@ if HAS_POSIX
 _SUBDIRS += mghttpd01
 endif
 _SUBDIRS += ftp01
+_SUBDIRS += networking01
 _SUBDIRS += syscall01
 endif
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 5ac2dfd..a136749 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -79,6 +79,7 @@ AM_CONDITIONAL(DLTESTS,[test x"$TEST_LIBDL" = x"yes"])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+networking01/Makefile
 libfdt01/Makefile
 defaultconfig01/Makefile
 pwdgrp02/Makefile
diff --git a/testsuites/libtests/networking01/Makefile.am b/testsuites/libtests/networking01/Makefile.am
new file mode 100644
index 0000000..0f1fb70
--- /dev/null
+++ b/testsuites/libtests/networking01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = networking01
+networking01_SOURCES = init.c
+dist_rtems_tests_DATA = networking01.scn
+dist_rtems_tests_DATA += networking01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+AM_CPPFLAGS += -I$(top_srcdir)/termios04
+LINK_OBJS = $(networking01_OBJECTS)
+LINK_LIBS = $(networking01_LDLIBS)
+networking01$(EXEEXT): $(networking01_OBJECTS) $(networking01_DEPENDENCIES)
+	@rm -f networking01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/networking01/init.c b/testsuites/libtests/networking01/init.c
index 0000000..800d785
--- /dev/null
+++ b/testsuites/libtests/networking01/init.c
@@ -0,0 +1,161 @@
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/socket.h>
+#include <netdb.h>
+#include <string.h>
+#include <netinet/in.h>
+#include <rtems.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "NETWORKING 1";
+/* forward declarations to avoid warnings */
+static rtems_task Init(rtems_task_argument argument);
+static void fill_sa(struct sockaddr *sa, sa_family_t family)
+  memset(sa, 0, sizeof(struct sockaddr));
+  sa->sa_len = sizeof(struct sockaddr);
+  sa->sa_family = family;
+static void fill_sa_in(struct sockaddr_in *sa_in,
+  in_addr_t addr, in_port_t port)
+  fill_sa((struct sockaddr *)sa_in, AF_INET);
+  sa_in->sin_port = port;
+  sa_in->sin_addr.s_addr = addr;
+static void test_getnameinfo(
+  const struct sockaddr *sa,
+  int flags,
+  bool ask_node,
+  bool ask_service,
+  int expected_returnvalue,
+  const char *expected_node,
+  const char *expected_service
+  char node[] = "255.255.255.255";
+  char service[] = "65535";
+  socklen_t salen = sa->sa_len;
+  int rv;
+  char *node_p = node;
+  char *service_p = service;
+  size_t node_l = sizeof(node);
+  size_t service_l = sizeof(service);
+  if(ask_node == false) {
+    node_p = NULL;
+    node_l = 0;
+  if(ask_service == false) {
+    service_p = NULL;
+    service_l = 0;
+  rv = getnameinfo(sa, salen, node_p, node_l, service_p, service_l, flags);
+  rtems_test_assert(rv == expected_returnvalue);
+  if(expected_node != NULL) {
+    rtems_test_assert(strcmp(expected_node, node) == 0);
+  if(expected_service != NULL) {
+    rtems_test_assert(strcmp(expected_service, service) == 0);
+static void test(void)
+  struct sockaddr sa;
+  struct sockaddr_in sa_in;
+  struct sockaddr *sa_in_p = (struct sockaddr *) &sa_in;
+  const in_addr_t ip1_num = 0x7F000001u;
+  const char ip1_string[] = "127.0.0.1";
+  const in_addr_t ip2_num = 0xC0A86464u;
+  const char ip2_string[] = "192.168.100.100";
+  const in_port_t port1_num = 7u;
+  const char port1_string[] = "7";
+  const in_port_t port2_num = 65534u;
+  const char port2_string[] = "65534";
+  printk("Try AF_INET6\n");
+  fill_sa(&sa, AF_INET6);
+  test_getnameinfo(&sa, 0, true, true, EAI_FAMILY, NULL, NULL);
+  printk("force node name\n");
+  fill_sa_in(&sa_in, ip1_num, port1_num);
+  test_getnameinfo(sa_in_p, NI_NAMEREQD, true, true, EAI_NONAME, NULL, NULL);
+  printk("force service name\n");
+  printk("get node only\n");
+  test_getnameinfo(sa_in_p, 0, true, false, 0, ip1_string, NULL);
+  printk("get service only\n");
+  test_getnameinfo(sa_in_p, 0, false, true, 0, NULL, port1_string);
+  printk("get node and service\n");
+  test_getnameinfo(sa_in_p, 0, true, true, 0, ip1_string, port1_string);
+  printk("get node and service with maximum number of characters for IP\n");
+  fill_sa_in(&sa_in, ip2_num, port2_num);
+  test_getnameinfo(sa_in_p, 0, true, true, 0, ip2_string, port2_string);
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_INIT
+#define CONFIGURE_MICROSECONDS_PER_TICK 10000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_DRIVERS 2
+#define CONFIGURE_MAXIMUM_TASKS (1)
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/networking01/networking01.doc b/testsuites/libtests/networking01/networking01.doc
index 0000000..949a32c
--- /dev/null
+++ b/testsuites/libtests/networking01/networking01.doc
@@ -0,0 +1,26 @@
+# Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+#  embedded brains GmbH
+#  Dornierstr. 4
+#  82178 Puchheim
+#  Germany
+#  <rtems at embedded-brains.de>
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: networking
+directives:
++ getnameinfo()
+concepts:
++ Try to get some valid and invalid name infos.
+NOTE: This test works without a network connection.
diff --git a/testsuites/libtests/networking01/networking01.scn b/testsuites/libtests/networking01/networking01.scn
index 0000000..75e8457
--- /dev/null
+++ b/testsuites/libtests/networking01/networking01.scn
@@ -0,0 +1,9 @@
+*** BEGIN OF TEST LIBNETWORKING 1 ***
+Try AF_INET6
+force node name
+force service name
+get node only
+get service only
+get node and service
+get node and service with maximum number of characters for IP
+*** END OF TEST LIBNETWORKING 1 ***
1.8.4.5
