[PATCH 25/27] libnetworking: Import current sys/socket.h
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 24 09:38:44 UTC 2016
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
Import the sys/socket.h from current FreeBSD. This allows to build some
current software (e.g. libressl).
 cpukit/libnetworking/sys/socket.h | 452 +++++++++++++++++++++++++++++++-------
 1 file changed, 368 insertions(+), 84 deletions(-)
diff --git a/cpukit/libnetworking/sys/socket.h b/cpukit/libnetworking/sys/socket.h
index 3821d8b..99bfa1c 100644
--- a/cpukit/libnetworking/sys/socket.h
+++ b/cpukit/libnetworking/sys/socket.h
@@ -1,4 +1,4 @@
  * Copyright (c) 1982, 1985, 1986, 1988, 1993, 1994
  *	The Regents of the University of California.  All rights reserved.
@@ -27,16 +27,16 @@
  * SUCH DAMAGE.
  *	@(#)socket.h	8.4 (Berkeley) 2/21/94
- * $FreeBSD: src/sys/sys/socket.h,v 1.88 2005/04/13 00:01:46 mdodd Exp $
+ * $FreeBSD: head/sys/sys/socket.h 301038 2016-05-31 13:32:33Z ed $
 #ifndef _SYS_SOCKET_H_
 #define	_SYS_SOCKET_H_
 #include <sys/cdefs.h>
-#include <rtems/bsdnet/_types.h>
-#include <sys/types.h>
+#include <sys/_types.h>
+#include <sys/_iovec.h>
+#include <machine/_align.h>
  * Definitions related to sockets: types, address families, options.
@@ -45,6 +45,22 @@
  * Data types.
+#if __BSD_VISIBLE
+#ifndef _GID_T_DECLARED
+typedef	__gid_t		gid_t;
+#define	_GID_T_DECLARED
+#endif
+#ifndef _OFF_T_DECLARED
+typedef	__off_t		off_t;
+#define	_OFF_T_DECLARED
+#endif
+#ifndef _PID_T_DECLARED
+typedef	__pid_t		pid_t;
+#define	_PID_T_DECLARED
+#endif
+#endif
 #ifndef _SA_FAMILY_T_DECLARED
 typedef	__sa_family_t	sa_family_t;
@@ -55,6 +71,28 @@ typedef	__sa_family_t	sa_family_t;
 typedef	__socklen_t	socklen_t;
 #define	_SOCKLEN_T_DECLARED
 #endif
+#ifndef _SSIZE_T_DECLARED
+typedef	__ssize_t	ssize_t;
+#define	_SSIZE_T_DECLARED
+#endif
+#if __BSD_VISIBLE
+#ifndef _UID_T_DECLARED
+typedef	__uid_t		uid_t;
+#define	_UID_T_DECLARED
+#endif
+#endif
+#ifndef _UINT32_T_DECLARED
+typedef	__uint32_t	uint32_t;
+#define	_UINT32_T_DECLARED
+#endif
+#ifndef _UINTPTR_T_DECLARED
+typedef	__uintptr_t	uintptr_t;
+#define	_UINTPTR_T_DECLARED
+#endif
  * Types
@@ -67,6 +105,14 @@ typedef	__socklen_t	socklen_t;
 #endif
 #define	SOCK_SEQPACKET	5		/* sequenced packet stream */
+#if __BSD_VISIBLE
+ * Creation flags, OR'ed into socket() and socketpair() type argument.
+#define	SOCK_CLOEXEC	0x10000000
+#define	SOCK_NONBLOCK	0x20000000
+#endif
  * Option flags per-socket.
@@ -88,42 +134,55 @@ typedef	__socklen_t	socklen_t;
 #define	SO_ACCEPTFILTER	0x1000		/* there is an accept filter */
 #define	SO_BINTIME	0x2000		/* timestamp received dgram traffic */
 #endif
+#define	SO_NO_OFFLOAD	0x4000		/* socket cannot be offloaded */
+#define	SO_NO_DDP	0x8000		/* disable direct data placement */
  * Additional options, not kept in so_options.
-#define SO_SNDBUF	0x1001		/* send buffer size */
-#define SO_RCVBUF	0x1002		/* receive buffer size */
-#define SO_SNDLOWAT	0x1003		/* send low-water mark */
-#define SO_RCVLOWAT	0x1004		/* receive low-water mark */
-#define SO_SNDTIMEO	0x1005		/* send timeout */
-#define SO_RCVTIMEO	0x1006		/* receive timeout */
+#define	SO_SNDBUF	0x1001		/* send buffer size */
+#define	SO_RCVBUF	0x1002		/* receive buffer size */
+#define	SO_SNDLOWAT	0x1003		/* send low-water mark */
+#define	SO_RCVLOWAT	0x1004		/* receive low-water mark */
+#define	SO_SNDTIMEO	0x1005		/* send timeout */
+#define	SO_RCVTIMEO	0x1006		/* receive timeout */
 #define	SO_ERROR	0x1007		/* get error status and clear */
 #define	SO_TYPE		0x1008		/* get socket type */
-#define	SO_PRIVSTATE	0x1009		/* get/deny privileged state */
+#if __BSD_VISIBLE
+#define	SO_LABEL	0x1009		/* socket's MAC label */
+#define	SO_PEERLABEL	0x1010		/* socket's peer's MAC label */
+#define	SO_LISTENQLIMIT	0x1011		/* socket's backlog limit */
+#define	SO_LISTENQLEN	0x1012		/* socket's complete queue length */
+#define	SO_LISTENINCQLEN	0x1013	/* socket's incomplete queue length */
+#define	SO_SETFIB	0x1014		/* use this FIB to route */
+#define	SO_USER_COOKIE	0x1015		/* user cookie (dummynet etc.) */
+#define	SO_PROTOCOL	0x1016		/* get socket protocol (Linux name) */
+#define	SO_PROTOTYPE	SO_PROTOCOL	/* alias for SO_PROTOCOL (SunOS name) */
+#endif
- * RTEMS addition: get and set wakeup functions.
+ * Space reserved for new socket options added by third-party vendors.
+ * This range applies to all socket option levels.  New socket options
+ * in FreeBSD should always use an option value less than SO_VENDOR.
-#define SO_SNDWAKEUP	0x1020		/* wakeup when ready to send */
-#define SO_RCVWAKEUP	0x1021		/* wakeup when ready to receive */
+#if __BSD_VISIBLE
+#define	SO_VENDOR	0x80000000
+#endif
  * Structure used for manipulating linger option.
-struct	linger {
+struct linger {
 	int	l_onoff;		/* option on/off */
 	int	l_linger;		/* linger time */
- * RTEMS addition: structure used to get and set wakeup function.
-struct socket;
-struct	sockwakeup {
-	void	(*sw_pfn)(struct socket *, void *);
-	void	*sw_arg;
+#if __BSD_VISIBLE
+struct accept_filter_arg {
+	char	af_name[16];
+	char	af_arg[256-16];
+#endif
  * Level number for (get/set)sockopt() to apply to socket itself.
@@ -169,18 +228,87 @@ struct	sockwakeup {
 #define	pseudo_AF_KEY	27		/* Internal key-management function */
 #endif
 #define	AF_INET6	28		/* IPv6 */
-#define	AF_MAX		29
+#if __BSD_VISIBLE
+#define	AF_NATM		29		/* native ATM access */
+#define	AF_ATM		30		/* ATM */
+#define pseudo_AF_HDRCMPLT 31		/* Used by BPF to not rewrite headers
+					 * in interface output routine
+#define	AF_NETGRAPH	32		/* Netgraph sockets */
+#define	AF_SLOW		33		/* 802.3ad slow protocol */
+#define	AF_SCLUSTER	34		/* Sitara cluster protocol */
+#define	AF_ARP		35
+#define	AF_BLUETOOTH	36		/* Bluetooth sockets */
+#define	AF_IEEE80211	37		/* IEEE 802.11 protocol */
+#define	AF_INET_SDP	40		/* OFED Socket Direct Protocol ipv4 */
+#define	AF_INET6_SDP	42		/* OFED Socket Direct Protocol ipv6 */
+#define	AF_MAX		42
+ * When allocating a new AF_ constant, please only allocate
+ * even numbered constants for FreeBSD until 134 as odd numbered AF_
+ * constants 39-133 are now reserved for vendors.
+#define AF_VENDOR00 39
+#define AF_VENDOR01 41
+#define AF_VENDOR02 43
+#define AF_VENDOR03 45
+#define AF_VENDOR04 47
+#define AF_VENDOR05 49
+#define AF_VENDOR06 51
+#define AF_VENDOR07 53
+#define AF_VENDOR08 55
+#define AF_VENDOR09 57
+#define AF_VENDOR10 59
+#define AF_VENDOR11 61
+#define AF_VENDOR12 63
+#define AF_VENDOR13 65
+#define AF_VENDOR14 67
+#define AF_VENDOR15 69
+#define AF_VENDOR16 71
+#define AF_VENDOR17 73
+#define AF_VENDOR18 75
+#define AF_VENDOR19 77
+#define AF_VENDOR20 79
+#define AF_VENDOR21 81
+#define AF_VENDOR22 83
+#define AF_VENDOR23 85
+#define AF_VENDOR24 87
+#define AF_VENDOR25 89
+#define AF_VENDOR26 91
+#define AF_VENDOR27 93
+#define AF_VENDOR28 95
+#define AF_VENDOR29 97
+#define AF_VENDOR30 99
+#define AF_VENDOR31 101
+#define AF_VENDOR32 103
+#define AF_VENDOR33 105
+#define AF_VENDOR34 107
+#define AF_VENDOR35 109
+#define AF_VENDOR36 111
+#define AF_VENDOR37 113
+#define AF_VENDOR38 115
+#define AF_VENDOR39 117
+#define AF_VENDOR40 119
+#define AF_VENDOR41 121
+#define AF_VENDOR42 123
+#define AF_VENDOR43 125
+#define AF_VENDOR44 127
+#define AF_VENDOR45 129
+#define AF_VENDOR46 131
+#define AF_VENDOR47 133
+#endif
  * Structure used by kernel to store most
  * addresses.
 struct sockaddr {
-	unsigned char	sa_len;			/* total length */
-	sa_family_t	sa_family;		/* address family */
-	char	sa_data[14];		/* actually longer; address value */
+	unsigned char	sa_len;		/* total length */
+	sa_family_t	sa_family;	/* address family */
+	char		sa_data[14];	/* actually longer; address value */
+#if __BSD_VISIBLE
+#define	SOCK_MAXADDRLEN	255		/* longest possible addresses */
  * Structure used by kernel to pass protocol
@@ -190,7 +318,11 @@ struct sockproto {
 	unsigned short	sp_family;		/* address family */
 	unsigned short	sp_protocol;		/* protocol */
+#endif
+#include <sys/_sockaddr_storage.h>
+#if __BSD_VISIBLE
  * Protocol families, same as address families for now.
@@ -225,6 +357,16 @@ struct sockproto {
 #define	PF_ISDN		AF_ISDN
 #define	PF_KEY		pseudo_AF_KEY
 #define	PF_INET6	AF_INET6
+#define	PF_NATM		AF_NATM
+#define	PF_ATM		AF_ATM
+#define	PF_NETGRAPH	AF_NETGRAPH
+#define	PF_SLOW		AF_SLOW
+#define PF_SCLUSTER	AF_SCLUSTER
+#define	PF_ARP		AF_ARP
+#define	PF_BLUETOOTH	AF_BLUETOOTH
+#define	PF_IEEE80211	AF_IEEE80211
+#define	PF_INET_SDP	AF_INET_SDP
+#define	PF_INET6_SDP	AF_INET6_SDP
 #define	PF_MAX		AF_MAX
@@ -234,40 +376,8 @@ struct sockproto {
  * Second level is protocol family.
  * Third level is protocol number.
- * Further levels are defined by the individual families below.
+ * Further levels are defined by the individual families.
-#define NET_MAXID	AF_MAX
-#define CTL_NET_NAMES { \
-	{ 0, 0 }, \
-	{ "unix", CTLTYPE_NODE }, \
-	{ "inet", CTLTYPE_NODE }, \
-	{ "implink", CTLTYPE_NODE }, \
-	{ "pup", CTLTYPE_NODE }, \
-	{ "chaos", CTLTYPE_NODE }, \
-	{ "xerox_ns", CTLTYPE_NODE }, \
-	{ "iso", CTLTYPE_NODE }, \
-	{ "emca", CTLTYPE_NODE }, \
-	{ "datakit", CTLTYPE_NODE }, \
-	{ "ccitt", CTLTYPE_NODE }, \
-	{ "ibm_sna", CTLTYPE_NODE }, \
-	{ "decnet", CTLTYPE_NODE }, \
-	{ "dec_dli", CTLTYPE_NODE }, \
-	{ "lat", CTLTYPE_NODE }, \
-	{ "hylink", CTLTYPE_NODE }, \
-	{ "appletalk", CTLTYPE_NODE }, \
-	{ "route", CTLTYPE_NODE }, \
-	{ "link_layer", CTLTYPE_NODE }, \
-	{ "xtp", CTLTYPE_NODE }, \
-	{ "coip", CTLTYPE_NODE }, \
-	{ "cnt", CTLTYPE_NODE }, \
-	{ "rtip", CTLTYPE_NODE }, \
-	{ "ipx", CTLTYPE_NODE }, \
-	{ "sip", CTLTYPE_NODE }, \
-	{ "pip", CTLTYPE_NODE }, \
-	{ "isdn", CTLTYPE_NODE }, \
-	{ "key", CTLTYPE_NODE }, \
  * PF_ROUTE - Routing table
@@ -280,14 +390,10 @@ struct sockproto {
 #define NET_RT_DUMP	1		/* dump; may limit to a.f. */
 #define NET_RT_FLAGS	2		/* by flags, e.g. RESOLVING */
 #define NET_RT_IFLIST	3		/* survey interface list */
-#define	NET_RT_MAXID	4
-#define CTL_NET_RT_NAMES { \
-	{ 0, 0 }, \
-	{ "dump", CTLTYPE_STRUCT }, \
-	{ "flags", CTLTYPE_STRUCT }, \
-	{ "iflist", CTLTYPE_STRUCT }, \
+#define	NET_RT_IFMALIST	4		/* return multicast address list */
+#define	NET_RT_IFLISTL	5		/* Survey interface list, using 'l'en
+					 * versions of msghdr structs. */
+#endif /* __BSD_VISIBLE */
  * Maximum queue length specifiable by listen.
@@ -300,12 +406,12 @@ struct sockproto {
 struct msghdr {
 	void		*msg_name;		/* optional address */
-	socklen_t	msg_namelen;		/* size of address */
-	struct	iovec *msg_iov;		/* scatter/gather array */
-	int	msg_iovlen;		/* # elements in msg_iov */
+	socklen_t	 msg_namelen;		/* size of address */
+	struct iovec	*msg_iov;		/* scatter/gather array */
+	int		 msg_iovlen;		/* # elements in msg_iov */
 	void		*msg_control;		/* ancillary data, see below */
-	socklen_t	msg_controllen;		/* ancillary data buffer len */
-	int	msg_flags;		/* flags on received message */
+	socklen_t	 msg_controllen;	/* ancillary data buffer len */
+	int		 msg_flags;		/* flags on received message */
 #define	MSG_OOB		0x1		/* process out-of-band data */
@@ -315,10 +421,20 @@ struct msghdr {
 #define	MSG_TRUNC	0x10		/* data discarded before delivery */
 #define	MSG_CTRUNC	0x20		/* control data lost before delivery */
 #define	MSG_WAITALL	0x40		/* wait for full request or error */
+#if __POSIX_VISIBLE >= 200809
+#define	MSG_NOSIGNAL	0x20000		/* do not generate SIGPIPE on EOF */
+#endif
 #if __BSD_VISIBLE
 #define	MSG_DONTWAIT	0x80		/* this message should be nonblocking */
 #define	MSG_EOF		0x100		/* data completes connection */
-#define MSG_COMPAT      0x8000		/* used in sendit() */
+#define	MSG_NOTIFICATION 0x2000         /* SCTP notification */
+#define	MSG_NBIO	0x4000		/* FIONBIO mode, used by fifofs */
+#define	MSG_COMPAT      0x8000		/* used in sendit() */
+#define	MSG_CMSG_CLOEXEC 0x40000	/* make received fds close-on-exec */
+#define	MSG_WAITFORONE	0x80000		/* for recvmmsg() */
+#endif
+#ifdef _KERNEL
+#define	MSG_SOCALLBCK   0x10000		/* for use by socket callbacks - soreceive (TCP) */
 #endif
@@ -329,32 +445,102 @@ struct msghdr {
 struct cmsghdr {
 	socklen_t	cmsg_len;		/* data byte count, including hdr */
-	int	cmsg_level;		/* originating protocol */
-	int	cmsg_type;		/* protocol-specific type */
+	int		cmsg_level;		/* originating protocol */
+	int		cmsg_type;		/* protocol-specific type */
 /* followed by	u_char  cmsg_data[]; */
+#if __BSD_VISIBLE
+ * While we may have more groups than this, the cmsgcred struct must
+ * be able to fit in an mbuf and we have historically supported a
+ * maximum of 16 groups.
+#define CMGROUP_MAX 16
+ * Credentials structure, used to verify the identity of a peer
+ * process that has sent us a message. This is allocated by the
+ * peer process but filled in by the kernel. This prevents the
+ * peer from lying about its identity. (Note that cmcred_groups[0]
+ * is the effective GID.)
+struct cmsgcred {
+	pid_t	cmcred_pid;		/* PID of sending process */
+	uid_t	cmcred_uid;		/* real UID of sending process */
+	uid_t	cmcred_euid;		/* effective UID of sending process */
+	gid_t	cmcred_gid;		/* real GID of sending process */
+	short	cmcred_ngroups;		/* number or groups */
+	gid_t	cmcred_groups[CMGROUP_MAX];	/* groups */
+ * Socket credentials.
+struct sockcred {
+	uid_t	sc_uid;			/* real user id */
+	uid_t	sc_euid;		/* effective user id */
+	gid_t	sc_gid;			/* real group id */
+	gid_t	sc_egid;		/* effective group id */
+	int	sc_ngroups;		/* number of supplemental groups */
+	gid_t	sc_groups[1];		/* variable length */
+ * Compute size of a sockcred structure with groups.
+#define	SOCKCREDSIZE(ngrps) \
+	(sizeof(struct sockcred) + (sizeof(gid_t) * ((ngrps) - 1)))
 /* given pointer to struct cmsghdr, return pointer to data */
-#define	CMSG_DATA(cmsg)		((u_char *)((cmsg) + 1))
+#define	CMSG_DATA(cmsg)		((unsigned char *)(cmsg) + \
+				 _ALIGN(sizeof(struct cmsghdr)))
 /* given pointer to struct cmsghdr, return pointer to next cmsghdr */
 #define	CMSG_NXTHDR(mhdr, cmsg)	\
-	(((caddr_t)(cmsg) + (cmsg)->cmsg_len + sizeof(struct cmsghdr) > \
-	    (mhdr)->msg_control + (mhdr)->msg_controllen) ? \
-	    (struct cmsghdr *)NULL : \
-	    (struct cmsghdr *)((caddr_t)(cmsg) + ALIGN((cmsg)->cmsg_len)))
+	((char *)(cmsg) == (char *)0 ? CMSG_FIRSTHDR(mhdr) : \
+	    ((char *)(cmsg) + _ALIGN(((struct cmsghdr *)(cmsg))->cmsg_len) + \
+	  _ALIGN(sizeof(struct cmsghdr)) > \
+	    (char *)(mhdr)->msg_control + (mhdr)->msg_controllen) ? \
+	    (struct cmsghdr *)0 : \
+	    (struct cmsghdr *)(void *)((char *)(cmsg) + \
+	    _ALIGN(((struct cmsghdr *)(cmsg))->cmsg_len)))
+ * RFC 2292 requires to check msg_controllen, in case that the kernel returns
+ * an empty list for some reasons.
+#define	CMSG_FIRSTHDR(mhdr) \
+	((mhdr)->msg_controllen >= sizeof(struct cmsghdr) ? \
+	 (struct cmsghdr *)(mhdr)->msg_control : \
+	 (struct cmsghdr *)0)
-#define	CMSG_FIRSTHDR(mhdr)	((struct cmsghdr *)(mhdr)->msg_control)
+#if __BSD_VISIBLE
+/* RFC 2292 additions */
+#define	CMSG_SPACE(l)		(_ALIGN(sizeof(struct cmsghdr)) + _ALIGN(l))
+#define	CMSG_LEN(l)		(_ALIGN(sizeof(struct cmsghdr)) + (l))
+#endif
+#ifdef _KERNEL
+#define	CMSG_ALIGN(n)	_ALIGN(n)
+#endif
 /* "Socket"-level control message types: */
 #define	SCM_RIGHTS	0x01		/* access rights (array of int) */
+#if __BSD_VISIBLE
 #define	SCM_TIMESTAMP	0x02		/* timestamp (struct timeval) */
+#define	SCM_CREDS	0x03		/* process creds (struct cmsgcred) */
+#define	SCM_BINTIME	0x04		/* timestamp (struct bintime) */
+#endif
+#if __BSD_VISIBLE
  * 4.3 compat sockaddr, move to compat file later
 struct osockaddr {
-	unsigned short	sa_family;		/* address family */
+	unsigned short sa_family;	/* address family */
 	char	sa_data[14];		/* up to 14 bytes of direct address */
@@ -369,6 +555,7 @@ struct omsghdr {
 	char	*msg_accrights;		/* access rights sent/received */
 	int	msg_accrightslen;
+#endif
  * howto arguments for shutdown(2), specified by Posix.1g.
@@ -377,12 +564,61 @@ struct omsghdr {
 #define	SHUT_WR		1		/* shut down the writing side */
 #define	SHUT_RDWR	2		/* shut down both sides */
+#if __BSD_VISIBLE
+/* for SCTP */
+/* we cheat and use the SHUT_XX defines for these */
+#define PRU_FLUSH_RD     SHUT_RD
+#define PRU_FLUSH_WR     SHUT_WR
+#define PRU_FLUSH_RDWR   SHUT_RDWR
+#endif
+#if __BSD_VISIBLE
+ * sendfile(2) header/trailer struct
+struct sf_hdtr {
+	struct iovec *headers;	/* pointer to an array of header struct iovec's */
+	int hdr_cnt;		/* number of header iovec's */
+	struct iovec *trailers;	/* pointer to an array of trailer struct iovec's */
+	int trl_cnt;		/* number of trailer iovec's */
+ * Sendfile-specific flag(s)
+#define	SF_NODISKIO     0x00000001
+#define	SF_MNOWAIT	0x00000002	/* obsolete */
+#define	SF_SYNC		0x00000004
+#define	SF_NOCACHE	0x00000010
+#define	SF_FLAGS(rh, flags)	(((rh) << 16) | (flags))
+#ifdef _KERNEL
+#define	SF_READAHEAD(flags)	((flags) >> 16)
+#endif /* _KERNEL */
+ * Sendmmsg/recvmmsg specific structure(s)
+struct mmsghdr {
+	struct msghdr	msg_hdr;		/* message header */
+	ssize_t		msg_len;		/* message length */
 #ifndef	_KERNEL
+#include <sys/cdefs.h>
 __BEGIN_DECLS
 int	accept(int, struct sockaddr * __restrict, socklen_t * __restrict);
 int	bind(int, const struct sockaddr *, socklen_t);
 int	connect(int, const struct sockaddr *, socklen_t);
+#if __BSD_VISIBLE
+int	accept4(int, struct sockaddr * __restrict, socklen_t * __restrict, int);
+int	bindat(int, int, const struct sockaddr *, socklen_t);
+int	connectat(int, int, const struct sockaddr *, socklen_t);
+#endif
 int	getpeername(int, struct sockaddr * __restrict, socklen_t * __restrict);
 int	getsockname(int, struct sockaddr * __restrict, socklen_t * __restrict);
 int	getsockopt(int, int, int, void * __restrict, socklen_t * __restrict);
@@ -390,16 +626,64 @@ int	listen(int, int);
 ssize_t	recv(int, void *, size_t, int);
 ssize_t	recvfrom(int, void *, size_t, int, struct sockaddr * __restrict, socklen_t * __restrict);
 ssize_t	recvmsg(int, struct msghdr *, int);
+#if __BSD_VISIBLE
+struct timespec;
+ssize_t	recvmmsg(int, struct mmsghdr * __restrict, size_t, int,
+    const struct timespec * __restrict);
+#endif
 ssize_t	send(int, const void *, size_t, int);
 ssize_t	sendto(int, const void *,
 	    size_t, int, const struct sockaddr *, socklen_t);
 ssize_t	sendmsg(int, const struct msghdr *, int);
+#if __BSD_VISIBLE
+int	sendfile(int, int, off_t, size_t, struct sf_hdtr *, off_t *, int);
+ssize_t	sendmmsg(int, struct mmsghdr * __restrict, size_t, int);
+int	setfib(int);
+#endif
 int	setsockopt(int, int, int, const void *, socklen_t);
 int	shutdown(int, int);
+int	sockatmark(int);
 int	socket(int, int, int);
 int	socketpair(int, int, int, int *);
 __END_DECLS
 #endif /* !_KERNEL */
+#ifdef _KERNEL
+struct socket;
+struct tcpcb *so_sototcpcb(struct socket *so);
+struct inpcb *so_sotoinpcb(struct socket *so);
+struct sockbuf *so_sockbuf_snd(struct socket *);
+struct sockbuf *so_sockbuf_rcv(struct socket *);
+int so_state_get(const struct socket *);
+void so_state_set(struct socket *, int);
+int so_options_get(const struct socket *);
+void so_options_set(struct socket *, int);
+int so_error_get(const struct socket *);
+void so_error_set(struct socket *, int);
+int so_linger_get(const struct socket *);
+void so_linger_set(struct socket *, int);
+struct protosw *so_protosw_get(const struct socket *);
+void so_protosw_set(struct socket *, struct protosw *);
+void so_sorwakeup_locked(struct socket *so);
+void so_sowwakeup_locked(struct socket *so);
+void so_sorwakeup(struct socket *so);
+void so_sowwakeup(struct socket *so);
+void so_lock(struct socket *so);
+void so_unlock(struct socket *so);
+void so_listeners_apply_all(struct socket *so, void (*func)(struct socket *, void *), void *arg);
+#endif
 #endif /* !_SYS_SOCKET_H_ */
1.8.4.5
