Code review for Raspberry Pi USB driver
Deval Shah
deval.maker at gmail.com
Sat Jun 25 05:13:40 UTC 2016
On Friday 24 June 2016, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Deval Shah and others,
> On Friday 24 of June 2016 10:45:34 Deval Shah wrote:
> > Hello all,
> > I have successfully ported the bcm283x_dwcotg driver for the Raspberry
> Pi.
> > Changes are shown in the commit >
> https://github.com/deval-maker/rtems-libbsd/commit/fd650f7ded413a0d891b5395
> >abb0c8768d71acc7. I need feedback on the code.
> > Also am getting error in mailbox functions (failed to set power state,
> > err=-2). As far as I know Pavel and Mudit are looking into this problem.
> I
> > can not move to next part before solving this issue. Please let me know
> how
> > can I contribute if the problem is not already solved.
> I have pushes workaround patch to mainline to ensure that
> your projects are not blocked by mailbox access problem.
> So the problem should be solved for you.
> I am currently using latest mainline rtems kernel. And I am still getting
this error. Any other possible reason?
> I would work on suggestions/proposal of patches to fix cache
> manager for mainline but testing and acknowledge would require
> help from more people and would take time.
> Your peripherals needs probably to access memory through DMA.
> If you use DMA then check if ARM CP15 operations are used
> directly for data synchronization (they work correctly)
> or if you use portable
> rtems_cache_flush_multiple_data_lines(buf, size);
> rtems_cache_invalidate_multiple_data_lines(buf, size);
> thelater are not working on RPi for now. But I consider these
> after fixing as better choice for long term goal.
> Best wishes,
> Pavel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160625/3ee2dc67/attachment.html>
