SD driver status
Mudit Jain
muditjain18011995 at gmail.com
Sun Jun 26 07:38:04 UTC 2016
An update regarding the driver is that, Pavel's patch has fixed the mailbox
error that was occurring.
Previously, set power gave a -2 error.
*** LIBBSD SDHCI 01 TEST ***
nexus0: <RTEMS Nexus device>
bcm_dma0: <BCM2835 DMA Controller> on nexus0
sdhci_bcm0: <Broadcom 2708 SDHCI controller> on nexus0
Enable the power returns 0
mmc0: <MMC/SD bus> on sdhci_bcm0
Sleeping to see what happens
Stack usage by thread
ID NAME LOW HIGH CURRENT AVAILABLE USED
0x09010001 IDLE 0x12c668 - 0x12d667 0x12d600 4080 128
0x0a010001 UI1 0x12d880 - 0x13587f 0x1354a8 32752 1008
0x0a010002 TIME 0x135fd0 - 0x13dfcf 0x13df10 32752 332
0x0a010003 IRQS 0x13dfd8 - 0x145fd7 0x145f18 32752 308
0x0a010004 _BSD 0x158678 - 0x160677 0x1605b0 32752 336
0x0a010005 _BSD 0x1607d0 - 0x1687cf 0x168708 32752 240
0x0a010006 _BSD 0x16a9f8 - 0x1729f7 0x172938 32752 232
0x0a010007 _BSD 0x172ab8 - 0x17aab7 0x17a9f8 32752 232
0x0a010008 _BSD 0x17ac58 - 0x182c57 0x182b90 32752 240
0x0a010009 _BSD 0x182df8 - 0x18adf7 0x18ad30 32752 240
*** END OF TEST LIBBSD SDHCI 01 ***
Thanks
Mudit
On Tue, Jun 21, 2016 at 4:24 PM, Sebastian Huber <
> For an example see media01 test.
> On 21/06/16 12:40, Mudit Jain wrote:
>> Hi all,
>> This is what I get on minicom.
>> RTEMS Shell on /dev/console. Use 'help' to list commands.
>> [/] # ls /dev
>> bpf bpf0 console ttyS0
>> The app code -
>> https://github.com/spark1729/rtems-libbsd/blob/ae67c8bf554b3d59ab5c8a0da70d244a5ffbbc4b/testsuite/sdhci01/test_main.c
>> Ideally an mmc device should be initialized. It would be great if someone
>> could direct me in the right direction here.
>> Thanks.
>> Mudit
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160626/e2def267/attachment.html>
