[PATCH] rtems: ensure that rtems_cache_aligned_malloc do not align less than to CPU_CACHE_LINE_BYTES.
Wed Jun 29 05:28:46 UTC 2016
Hallo Pavel,
On 25/06/16 17:06, Pavel Pisa wrote:
> There are architectures (for example some/many ARM Cortex-A) which have
> different cache line sizes for data and instruction caches.
> CPU kit and even BSP can be build for group of CPUs which differs
> in cache line sizes as well and there are situations when maximum
> alignment is not reported by rtems_cache_get_data_line_size.
> Ensure, that allocated memory is aligned at least to CPU_CACHE_LINE_BYTES
> which is in pair with compile time data structures allocation.
> Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
>   cpukit/libcsupport/src/cachealignedalloc.c | 3 +++
>   1 file changed, 3 insertions(+)
> diff --git a/cpukit/libcsupport/src/cachealignedalloc.c b/cpukit/libcsupport/src/cachealignedalloc.c
> index a704859..bb93937 100644
> --- a/cpukit/libcsupport/src/cachealignedalloc.c
> +++ b/cpukit/libcsupport/src/cachealignedalloc.c
> @@ -18,6 +18,9 @@ void *rtems_cache_aligned_malloc( size_t nbytes )
>     size_t line_size = rtems_cache_get_data_line_size();
>     if ( line_size > 0 ) {
> +    if ( line_size < CPU_CACHE_LINE_BYTES )
> +      line_size = CPU_CACHE_LINE_BYTES;
>       /* Assume that the cache line size is a power of two */
>       size_t m = line_size - 1;
so, in case rtems_cache_get_data_line_size() returns a non-zero value,
then you assume that it lies to the user and fix it here in this place only?
The purpose of CPU_CACHE_LINE_BYTES is to provide a worst-case cache
line size at cpukit compile-time.
We have
  * @brief Returns the data cache line size in bytes.
  * For multi-level caches this is the maximum of the cache line sizes
of all
  * levels.
  * @retval 0 No data cache is present.
  * @retval positive The data cache line size in bytes.
size_t rtems_cache_get_data_line_size( void );
  * @brief Returns the instruction cache line size in bytes.
of all
  * levels.
  * @retval 0 No instruction cache is present.
  * @retval positive The instruction cache line size in bytes.
size_t rtems_cache_get_instruction_line_size( void );
I think the documentation is pretty clear. In case a BSP implements
these functions wrongly, then we should fix this BSP.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
